- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Permissions Management
- Elastic IP
- EIP Billing
- EIP Pool
- Shared Bandwidth
- Shared Data Package
- Global EIPs
- Global Internet Gateways
- Global Internet Bandwidths
- Global Connection Bandwidths
- Cloud Eye Monitoring
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- APIs
- API V3
- Native OpenStack Neutron APIs V2.0
- Application Examples
- Appendix
- SDK Reference
Product Consultation
- Managing Quotas
- How Do I Assign or Retrieve a Specific EIP?
- Why Is an EIP Newly Assigned the Same as the One I Released?
- Can I Buy a Specific EIP?
- Does an EIP Change Over Time?
- Why Can't I Find My Purchased EIP on the Management Console?
- What Is the EIP Assignment Policy?
- Can an EIP Be Used or Migrated Across Accounts?
- How Do I Query the Traffic Usage of My EIP?
- Do I Need to Configure a Shared Data Package for Use After It Is Purchased?
- Can I Change the Dedicated Bandwidth Used by an EIP to a Shared Bandwidth?
- How Many ECSs Can I Bind an EIP To?
- What Are the Differences Between EIP, Private IP Address, and Virtual IP Address?
- What Are the Differences Among a Bandwidth Add-On Package, Shared Data Package, and Shared Bandwidth?
- When Should I Use Premium BGP and Are There Any Limitations on Using Premium BGP?
- Why My EIPs Are Frozen? How Do I Unfreeze My EIPs?
Billing and Payments
- How Is an EIP Billed?
- How Do I Change My EIP Billing Mode Between Pay-per-Use and Yearly/Monthly?
- How Do I Change the Billing Option of a Pay-per-Use EIP Between By Bandwidth and By Traffic?
- Why Am I Still Being Billed After My EIP Has Been Unbound or Released?
- When Will I Be Billed for Reservation Price?
EIP Binding and Unbinding
- How Do I Access an ECS with an EIP Bound from the Internet?
- How Can I Unbind an Existing EIP from an Instance and Bind Another EIP to the Instance?
- Can I Bind an EIP of an ECS to Another ECS?
- Can I Bind an EIP to a Cloud Resource in Another Region?
- Can Multiple EIPs Be Bound to an ECS?
- What Are the Differences Between Unbinding and Releasing an EIP?
Bandwidth
- How Do I Increase a Bandwidth to Be More Than 300 Mbit/s?
- What Bandwidth Types Are Available?
- How Many EIPs Can I Add to Each Shared Bandwidth?
- What Are the Differences Between a Dedicated Bandwidth and a Shared Bandwidth?
- What Are Inbound Bandwidth and Outbound Bandwidth?
- How Do I Know If My EIP Bandwidth Has Been Exceeded?
- What Are the Differences Between Public Bandwidth and Private Bandwidth?
- Can I Increase a Yearly/Monthly Bandwidth and Decrease It Later?
- What Is the Relationship Between Bandwidth and Upload/Download Rate?
- What Are the Differences Among Static BGP, Dynamic BGP, and Premium BGP?
Connectivity
- What Are the Priorities of the Custom Route and EIP If Both Are Configured for an ECS to Enable the ECS to Access the Internet?
- Why Can't My ECS Access the Internet Even After an EIP Is Bound?
- What Should I Do If an EIP Cannot Be Pinged?
- How Do I Unblock an EIP?
- Why Is There Network Jitter or Packet Loss During Cross-Border Communications?
- Why Does the Download Speed of My ECS Is Slow?
- Videos
- Glossary
More Documents
- Quick Start
- EIP Overview
- Assigning an EIP and Binding It to an ECS
- Assigning an EIP
- Binding an EIP to an Instance
- Unbinding an EIP from an Instance
- Releasing an EIP
- Changing Dedicated Bandwidth Size of an EIP
- Unbinding an EIP from an ECS and Releasing the EIP
- Modifying an EIP Bandwidth
- Exporting EIP Information
- Managing EIP Tags
- Shared Bandwidth
- Monitoring
- What Is a Quota?
- Can an EIP That Uses Dedicated Bandwidth Be Changed to Use Shared Bandwidth?
- Can I Bind an EIP to Multiple ECSs?
- What Are the Differences Between the Primary and Extension NICs of ECSs?
- Can I Assign a Specific EIP?
- Can a Bandwidth Be Used by Multiple Accounts?
- How Do I Unbind an EIP from an Instance and Bind a New EIP to the Instance?
- Why Can't I Find My Assigned EIP on the Management Console?
- EIP Binding and Unbinding
Bandwidth
- What Is the Bandwidth Size Range?
- Is There a Limit to the Number of EIPs That Can Be Added to Each Shared Bandwidth?
- How Do I Know If My EIP Bandwidth Limit Has Been Exceeded?
- Connectivity
- Change History
- API Reference (ME-Abu Dhabi Region)
- Quick Start
- EIP
- Shared Bandwidth
- Monitoring
- Product Consultation
Bandwidth
- What Are the Differences Between a Dedicated Bandwidth and a Shared Bandwidth? Can a Dedicated Bandwidth Be Changed to a Shared Bandwidth or the Other Way Around?
- Connectivity
- Change History
- API Reference (Kuala Lumpur Region)
- User Guide (Ankara Region)
- API Reference (Ankara Region)
Viewing Metrics
View related metrics to see bandwidth and EIP usage information.
- Hover on the upper left corner to display Service List and choose Management & Deployment > Cloud Eye.
- Click Cloud Service Monitoring on the left of the page, and choose Elastic IP and Bandwidth.
- Locate the row that contains the target bandwidth or EIP and click View Metric in the Operation column to check the bandwidth or EIP monitoring information.
Parent topic: Monitoring
