Help Center>
API Gateway>
User Guide (Kuala Lumpur Region)>
API Opening>
Access Control>
Deleting an Access Control Policy
Updated on 2022-08-12 GMT+08:00
You can delete access control policies you no longer require.
You have created an access control policy.
- Click
in the upper left corner and choose API Gateway.
- In the navigation pane, choose Dedicated Gateways. Then click Access Console in the upper right corner of a dedicated gateway.
- In the navigation pane, choose API Publishing > Access Control.
- Delete an access control policy using one of the following methods:
- In the Operation column of the access control policy you want to delete, click Delete.
- Click the name of the target access control policy, and click Delete in the upper right corner of the displayed access control policy details page.
- If an access control policy has been bound to APIs, unbind it and then delete it.
- To delete multiple access control policies, select the policies, and click Delete. You can delete a maximum of 1000 access control policies at a time.
- Click Yes.
Parent topic: Access Control
