Help Center/
API Gateway/
User Guide (Kuala Lumpur Region)/
API Opening/
Signature Key Management/
Deleting a Signature Key
Updated on 2022-08-12 GMT+08:00
You can delete signature keys you no longer require.
You have created a signature key.
- Click
in the upper left corner and choose API Gateway.
- In the navigation pane, choose Dedicated Gateways. Then click Access Console in the upper right corner of a dedicated gateway.
- In the navigation pane, choose API Publishing > Signature Keys.
- Delete a signature key. You can use one of the following methods:
- In the Operation column of the signature key you want to delete, click Delete.
- Click the name of the target signature key, and click Delete in the upper right corner of the displayed signature key details page.
If the signature key has been bound to any APIs, unbind it and then delete it.
- Click Yes.
Parent topic: Signature Key Management
