Help Center>
API Gateway>
User Guide (Kuala Lumpur Region)>
API Opening>
Environment Management>
Deleting an Environment
Updated on 2022-08-12 GMT+08:00
You can delete environments you no longer require.
You have created an environment.
- Click
in the upper left corner and choose API Gateway.
- In the navigation pane, choose Dedicated Gateways. Then click Access Console in the upper right corner of a dedicated gateway.
- In the navigation pane, choose API Publishing > Environments.
- In the Operation column of the environment you want to delete, click Delete.
You can delete an environment only if no APIs have been published in the environment.
- Click Yes.
Parent topic: Environment Management
