Creating an API Group
Before creating an API, you must create an API group. An API group contains different APIs used for the same service.
Each API can only belong to one API group.
- Click in the upper left corner and choose API Gateway.
- In the navigation pane, choose Dedicated Gateways. Then click Access Console in the upper right corner of a dedicated gateway.
- In the navigation pane, choose API Publishing > API Groups.
- Click Create API Group, and set the parameters described in Table 1.
- Click OK.
After the API group is created, it is displayed in the API group list.
- The system automatically allocates a subdomain name to the API group for internal testing. The subdomain name can be accessed 1000 times a day.
- To make your APIs available for users to access, bind independent domain names to the API group to which the APIs belong.
Follow-Up Operations
After the API group is created, bind independent domain names to it so that API callers can use the domain names to call APIs in the group. For more information, see Binding a Domain Name.
