Help Center>
API Gateway>
User Guide (Kuala Lumpur Region)>
Getting Started>
Calling APIs>
Creating an App and Getting Authorized
Updated on 2022-08-12 GMT+08:00
Creating an App
- In the navigation pane, choose API Calling > Apps.
- Click Create App and set basic app information.
Table 1 App information Parameter
Name
App name. It is recommended that you enter a name based on naming rules to facilitate search.
Description of the app.
- Click OK.
Binding an App to an API
- At the top of the API list, click Select API.
- Select the environment, API group, and API created in Opening APIs, and click OK.
Parent topic: Calling APIs
