Help Center>
API Gateway>
User Guide (Kuala Lumpur Region)>
Getting Started>
Opening APIs>
Creating an API Group
Updated on 2022-08-12 GMT+08:00
- Log in to the API Gateway console.
- Access the dedicated gateway you created.
- In the navigation pane, choose API Publishing > API Groups.
- Click Create API Group and configure group information.
Table 1 API group information Parameter
Name
API group name. It is recommended that you enter a name based on naming rules to facilitate search.
Description of the API group.
- Click OK. The system automatically allocates a subdomain name to the API group. APIs in the group can be debugged using the subdomain name.
Parent topic: Opening APIs
