IPv6 Protection
Enable IPv6 Protection if the domain name is accessible using an IPv6 address. After you enable it, WAF assigns an IPv6 address to the domain name.
- If you select IPv6 for Server Address, IPv6 Protection is enabled by default.
- If you select IPv4 for Server Address and enable IPv6 Protection, WAF will assign an IPv6 address to the domain name so that the website is accessible over the IPv6 address. In this way, requests to the IPv6 address are routed by WAF to the IPv4 address of the origin server.
If an origin server uses IPv6 addresses, IPv6 protection is enabled by default. In this case, to prevent IPv6 service interruptions, IPv6 protection cannot be disabled.
