Help Center/ Web Application Firewall/ Drawer/ Buying WAF/ Cloud - CNAME Access Overview
Updated on 2025-07-04 GMT+08:00
You can easily deploy WAF within several minutes to protect web applications and websites on and off the cloud.
Mode: Reverse proxy (in-path deployment)
Protected objects: web applications or websites that can be directly accessed through domain names
Supported protocols: HTTP and HTTPS
Traffic forwarding method: CNAME records in DNS
Port: Specified Port (Only the professional and enterprise editions allow you to specify ports.)
Advantages: Protection for cloud and off-cloud websites | Ready for use
