Cloud Mode Overview
You can easily deploy WAF within several minutes. WAF protects web applications and websites on and off the cloud.
Mode: Reverse proxy (in-path deployment)
Protected objects: web applications or websites that can be directly accessed through domain names
Supported protocols: HTTP and HTTPS
Traffic forwarding method: CNAME records in DNS
Port: Specified Port (Only the professional and enterprise editions allow you to specify ports.)
Advantages: Protection for cloud and off-cloud websites | Ready for use
You can easily deploy WAF within several minutes. WAF protects only web applications and websites on the cloud.
Mode: Transparent proxy (out-of-path deployment)
Protected objects: web applications or websites that can be directly accessed through domain names or IP addresses
Traffic forwarding method: Mirrored ELB traffic
Port: All Ports
Advantages: Real-time blocking, high-reliability networking, no risk of service interruptions
