Updated on 2025-07-04 GMT+08:00
WAF Specifications
The dedicated WAF supports two specifications: WI-500 and WI-100. The following table lists the applicable service scales.
Table 1 Applicable service scales
Service Scale
Dedicated Mode
Peak rate of normal service requests
Specifications of a single instance:
  • Specifications: WI-500. Referenced performance:
    • HTTP services: 5,000 QPS (recommended)
    • HTTPS services: 4,000 QPS (recommended)
    • WebSocket service - Maximum concurrent connections: 5,000
    • Maximum WAF-to-server persistent connections: 60,000
  • Specifications: WI-100. Referenced performance:
    • HTTP services: 1,000 QPS (recommended)
    • HTTPS services: 800 QPS (recommended)
    • WebSocket service - Maximum concurrent connections: 1,000
Number of domain names
2,000
Back-to-source IP address quantity (the number of WAF IP addresses that can be allowed by a protected domain name)
Quantity of supported ports
  • Standard ports: two (80 and 443)
  • Non-standard ports: You can use as many ports as you want as long as the port is supported by WAF. For details, see Ports Supported by WAF.
Peak rate of CC attack protection
    Maximum QPS: 20,000
    Maximum QPS: 4,000
CC attack prevention rules
100
Precise protection rules
100
Reference table rules
100
IP address blacklist and whitelist rules
1,000
Geolocation access control rules
100
Web tamper protection rules
100
Information leakage prevention rules
100
Number of global protection whitelist (formerly false alarm masking) rules
1,000
Data masking rules
100
Security report templates
20
