Rule Expansion Package
If the quota for IP address whitelist and blacklist rules provided by your cloud WAF cannot meet your requirements, you can purchase rule expansion packages under the current WAF instance edition to increase such quota.
A rule expansion package allows you to configure up to 10 IP address blacklist and whitelist rules.
You can buy rule expansion packages when you purchase or change a cloud WAF instance.
    You can scale down or unsubscribe from packages you have. For details, see Changing the Edition and Specifications of a Cloud WAF Instance.
