Domain Expansion Package
A domain expansion package can protect up to 10 domain names. If the cloud WAF edition you are using cannot meet your business requirements, you can purchase domain expansion packages to increase the quota. For example, if you are using the standard edition, 10 domain names can be protected, including only one top-level domain name. If you want to protect 30 domain names, you can buy two domain name expansion packages to increase the quota.
    You can scale down or unsubscribe from packages you have. For details, see Changing the Edition and Specifications of a Cloud WAF Instance.
