Checking Whether the CNAME Record Has Taken Effect
The length of time before the CNAME record takes effect depends on the DNS provider. To check whether a CNAME record has taken effect:
Open the Windows Command Prompt (cmd) and run the following command:
nslookup -qt=cname Acceleration domain name
If the CNAME is displayed, the CNAME record has taken effect.
If the CNAME record has taken effect, your domain name has been successfully connected to CDN for acceleration.
