Adding a CNAME Record on Huawei Cloud DNS
If your domain name is resolved using Huawei Cloud DNS, follow the steps in this section to add a CNAME record. www.example.com is used as an example.
Step 1 Obtain the CNAME for your acceleration domain.
- Log in to the CDN console.
- In the navigation pane, choose Domains.
- In the domain name list, search for www.example.com and copy the CNAME www.example.com.9c****e7.c.cdnhwc1.com in the CNAME column.
Step 2 Add the CNAME record in your DNS service.
- Log in to the DNS console.
In the navigation pane, choose Public Zones.
The public zone list is displayed.
- Click the domain name you want to add a record set to.
- Click Add Record Set in the upper right corner.
- Set the parameters as prompted. The following is an example:
Type: Select CNAME – Map one domain to another.
Line: Select Default.
TTL (s): Retain the default value.
Value: Enter www.example.com.9c****e7.c.cdnhwc1.com.
- Click OK.
- After the CNAME record takes effect, the status changes to
. However, CNAME resolution may fail the verification and the status changes to
, indicating that no CNAME record is configured for the domain name. If you have correctly configured the CNAME record, ignore the error message. - A CNAME record takes effect immediately after being added. If you modify the CNAME record, then the change takes effect within 72 hours.
- If you encounter a resolution conflict, see Rules for Handling Record Set Conflicts.
