Updated on 2024-04-18 GMT+08:00
Exporting Monitoring Data
If you want to analyze the bandwidth or traffic usage of EIPs to locate faults, you can export EIP monitoring data.
- Hover on the upper left corner to display Service List and choose Management & Deployment > Cloud Eye.
- In the navigation pane on the left, choose Cloud Service Monitoring > Elastic IP and Bandwidth.
- On the Cloud Service Monitoring page, click Export Data.
- Configure the time range, period, resource type, dimension, monitored object, and metric.
- Click Export.
![](https://support.huaweicloud.com/intl/en-us/ae-ad-1-usermanual-eip/public_sys-resources/note_3.0-en-us.png)
You can export data for multiple metrics at a time to a CSV file.
- The first row in the exported CSV file displays the username, region, service, instance name, instance ID, metric name, metric data, time, and timestamp. You can view historical monitoring data.
- To convert the time using a Unix timestamp to the time of the target time zone, perform the following steps:
Parent topic: Monitoring
