Updated on 2025-01-22 GMT+08:00
bin
This function is used to return the binary format of a.
Syntax
bin(BIGINT a)
Parameters
Table 1 Parameter
Mandatory
Type
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value is an integer.
If the value is not of the BIGINT type, the system will implicitly convert it to the BIGINT type for calculation.
Return Values
The return value is of the STRING type.
If the value of a is NULL, NULL is returned.
Example Code
The value 1 is returned.
select bin(1);
The value NULL is returned.
select bin(null);
The value 1000 is returned.
select bin(8);
select bin(8.123456);
