هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Automated O&M/
Parameter Management/
Parameter Center/
Viewing Parameter Details
- Log in to COC.
- In the navigation pane, choose Resource O&M > Automatic O&M and click Parameter Center. Click the name of a parameter to go to the details page. You can view the parameter details and version history.
Figure 1 Parameter list
- On the Parameter Details page, click
next to the parameter value to view the value of the sensitive parameter, click Collapse to expand the tag list, and click Viewing Decrypted Data to view the values of all parameter versions.
Figure 2 Parameter details
Parent topic: Parameter Center
