Viewing a Resource Operation Ticket
After a batch operation is performed on resources such as ECSs, RDS DB instances, FlexusL instances, and BMSs in batches, a service ticket is generated for you to record the batch operation results. If you want to monitor and record the execution objects and results of a batch resource operation, you can use the resource operation ticket function.
Viewing the Execution Records of a Resource Operation Ticket
- Log in to COC.
 - In the navigation pane, choose Task Management > Execution Records.
 - Click Resource Operation Tickets.
 - Locate the target ticket and click the resource operation ID.
 - Perform the following operations based on the service ticket status:
- Abnormal: Click Forcibly End in the upper right corner to terminate the service ticket.
- Executing: Click Pause or Forcibly End in the upper right corner to pause or terminate the service ticket.
 - Paused: Click Continue or Forcibly End in the upper right corner to continue or terminate the service ticket.
