هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Creating a Patch Baseline
Patch Baseline allows you to customize the rules for scanning and installing patches. Only patches that are compliant with the baseline can be scanned and repaired.
You can create patch baselines for ECS instances, CCE instances, and BMS instances as required.
Cloud Operations Center has provided the public patch baselines of all OSs as the preset patch baseline when ECS and BMS instances are used initially. Patch baseline for CCE instances needs to be manually created.
Create a patch baseline on Cloud Operations Center.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. Click Patch management.
- Click the Patch Baseline tab to view the baseline list.
Figure 1 Patch baseline list
- Click Creating Patch Baseline.
Figure 2 Creating a patch baseline
- Set the patch baseline information as prompted.
Figure 3 Setting the patch baseline information
Table 1 OS installation rule baseline Field
Options
Product
- Huawei Cloud EulerOS
- All
- Huawei Cloud EulerOS 1.1
- Huawei Cloud EulerOS 2.0
- CentOS
- All
- CentOS7.2
- CentOS7.3
- CentOS7.4
- CentOS7.5
- CentOS7.6
- CentOS7.7
- CentOS7.8
- CentOS7.9
- CentOS8.0
- CentOS8.1
- CentOS8.2
- EulerOS
- All
- EulerOS 2.2
- EulerOS 2.5
- EulerOS 2.8
- EulerOS 2.9
- EulerOS 2.10
OS of patches. Only the patches of the selected OS can be scanned and repaired.
Category
- All
- Security
- Bugfix
- Enhancement
- Recommended
- Newpackage
Category of patches. The patches of the selected category are scanned and repaired.
Severity
- All
- Critical
- Important
- Moderate
- Low
- None
Severity level of patches. The patches of the selected severity level can be scanned and repaired.
Automatic Approval
- Approve the patch after a specified number of days.
- Approve patches released before the specified date.
Automatically approve patches that meet specified conditions.
Specified Days
0 to 365
This parameter is mandatory when Approve the patch after a specified number of days. is selected.
Specified Date
None
This parameter is mandatory when Approve patches released before the specified date. is selected.
Compliance Reporting
- Unspecified
- Critical
- High
- Medium
- Low
- Suggestion
Level of a patch that meets the patch baseline in the compliance report
Install Non-Security Patches
None
If you do not select this option, the patches with vulnerabilities will not be upgraded during patch repairing.
Exceptional Patches
None
The formats of the software packages of approved patches and rejected patches are as follows:
- The format of a complete software package name: example-1.0.0-1.r1.hce2.x86_64.
- The format of the software package name that contains a single wildcard: example-1.0.0*.x86_64.
Table 2 Customized installation rule Field
Options
Product
- All
- CentOS
- All
- CentOS 7.2
- CentOS 7.3
- CentOS 7.4
- CentOS 7.5
- CentOS 7.6
- CentOS 7.7
- CentOS 7.8
- CentOS 7.9
- CentOS 8.0
- CentOS 8.1
- CentOS 8.2
- EulerOS
- All
- EulerOS 2.2
- EulerOS 2.5
- EulerOS 2.8
- EulerOS 2.9
- EulerOS 2.10
Product attribute of the patch. Only the patches of the selected OS can be scanned and repaired.
Unspecified
Critical
High
Medium
Low
Suggestion
Baseline patch
None
You can customize the version and release number of a baseline path. Only the patches that match the customized baseline patch can be scanned and installed.
- A maximum of 1,000 baseline patches can be uploaded for a baseline.
- The patch name can contain a maximum of 200 characters, including letters, digits, underscores (_), hyphens (-), dots (.), asterisks (*), and plus signs (+).
- The data in the second column consists of the version number (including letters, digits, underscores, dots, and colons) and the release number (including letters, digits, underscores, and dots) that are separated by a hyphen (-). Both two types of numbers can contain a maximum of 50 characters.
- Click Submit.
Figure 4 Creating a customized patching baseline
