ADD CONSTRAINT
Function
This command adds a CHECK constraint. Before such a constraint is added to a table, the system verifies whether all existing rows meet the constraint.
Precautions
Before adding a constraint to a table, the system verifies whether all existing rows meet the constraint. If any row fails to meet the constraint, the system will not add the constraint. Therefore, you need to delete the rows that do not meet the constraint before adding it.
Syntax
ALTER TABLE [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`
ADD CONSTRAINT constraint_name
CHECK(boolExpression)
Parameter Description
| Parameter | Description |
| database_name | Name of the database, consisting of letters, numbers, and underscores (_) |
| table_name | Name of the table in the database, consisting of letters, numbers, and underscores (_) |
| bucket_name | OBS bucket name |
| tbl_path | Storage location of the Delta table in the OBS bucket |
| constraint_name | Constraint name |
| boolExpression | Constraint expression |
Required Permissions
- SQL permissions
| Permission Description |
| ALTER permission on a table |
- Fine-grained permission: dli:table:alter
- Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Example
alter table delta_table0 add constraint const_price check(price>0); alter table delta.`obs://bucket1/dbgms/h0` add constraint const_id check(id>0);
System Response
Displays whether the task is successfully executed in the execution history or job list.
