DESCRIBE
Function
This command shows detailed information or statistics about a table.
Syntax
Show statistics about a table:
DESCRIBE [EXTENDED|FORMATTED] [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`;
Show detailed information about a table:
DESCRIBE DETAIL [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`;
Required Permissions
- SQL permissions
| Permission Description |
| DESCRIBE_TABLE permission on a table |
- Fine-grained permission: dli:table:describeTable
- Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Examples
DESCRIBE FORMATTED delta_table0; DESCRIBE FORMATTED delta.`obs://bucket_name0/db0/delta_table0`; DESCRIBE DETAIL delta_table0;
System Response
Returns details or statistics about a table.
| Parameter | Description |
| format | Format of the table, which is delta in this example |
| id | Unique ID of the table |
| name | Table name defined in MetaServer |
| description | Description about the table |
| location | Storage path of the table |
| createdAt | Timestamp when the table was created |
| lastModified | Timestamp when the table was last modified |
| partitionColumns | Partition column |
| numFiles | Number of files in the latest version of the table |
| sizeInBytes | Size of the latest snapshot of the table, in bytes |
| properties | All the attributes set for this table |
| minReaderVersion | Earliest reader version that can read the table |
| minWriterVersion | Earliest writer version that can write the table |
