هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
Easily Switch Between Product Types
You can click the drop-down list box to switch between different product types.
Configuring SNI for a LoadBalancer Service
An SNI certificate is an extended server certificate that allows the same IP address and port number to provide multiple access domain names for external systems. Different security certificates can be used based on the domain names requested by clients to ensure HTTPS communication security.
When configuring SNI, you need to add a certificate associated with a domain name. The client submits the requested domain name information when initiating an SSL handshake request. After receiving the SSL request, the load balancer searches for the certificate based on the domain name. If the certificate is found, the load balancer will return it to the client. If the certificate is not found, the load balancer will return the default server certificate.
After SNI is configured, if you delete the SNI configuration on the CCE console or delete the target annotation from the YAML file, the configuration on the ELB will be retained.
  • A Kubernetes cluster is available and the cluster version meets the following requirements:
    • v1.23: v1.23.13-r0 or later
    • v1.25: v1.25.8-r0 or later
    • v1.27: v1.27.5-r0 or later
    • v1.28: v1.28.3-r0 or later
    • Other clusters of later versions
  • You have created one or more SNI certificates in ELB and specified a domain name in these certificates.
  • To create a cluster using commands, ensure kubectl is used. For details, see Connecting to a Cluster Using kubectl.
Using the CCE Console
  2. In the navigation pane, choose Services & Ingresses. In the upper right corner, click Create Service.
  3. Configure Service parameters. In this example, only mandatory parameters required for using SNI are listed. For details about how to configure other parameters, see Creating a LoadBalancer Service.
    • Service Name: Specify a Service name, which can be the same as the workload name.
    • Service Type: Select LoadBalancer.
    • Selector: Add a label and click Confirm. The Service will use this label to select pods. You can also click Reference Workload Label to use the label of an existing workload. In the dialog box that is displayed, select a workload and click OK.
    • Load Balancer: Select a load balancer type and creation mode.
      • A load balancer can be dedicated or shared. To enable HTTP/HTTPS on the listener port of a dedicated load balancer, the type of the load balancer must be Application (HTTP/HTTPS) or Network (TCP/UDP) & Application (HTTP/HTTPS).
      • This section uses an existing load balancer as an example. For details about the parameters for automatically creating a load balancer, see Table 1.
    • Ports
      • Protocol: Select TCP. If you select UDP, HTTP and HTTPS will be unavailable.
      • Service Port: port used by the Service. The port number ranges from 1 to 65535.
      • Container Port: listener port of the workload. For example, Nginx uses port 80 by default.
      • Frontend Protocol: In this example, HTTPS must be enabled for the Service to use SNI. For a dedicated load balancer, to use HTTP/HTTPS, the type of the load balancer must be Application (HTTP/HTTPS).
    • Listener
      • SSL Authentication: Select this option if HTTPS is enabled on the listener port. This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions.
        • One-way authentication: Only the backend server is authenticated. If you also need to authenticate the identity of the client, select mutual authentication.
        • Mutual authentication: If you want the clients and the load balancer to authenticate each other, select this option. Only authenticated clients will be allowed to access the load balancer.
      • CA Certificate: If SSL Authentication is set to Mutual authentication, add a CA certificate to authenticate the client. A CA certificate is issued by a certificate authority (CA) and used to verify the certificate issuer. If HTTPS mutual authentication is required, HTTPS connections can be established only when the client provides a certificate issued by a specific CA.
      • Server Certificate: Select a server certificate as the default certificate.
      • SNI: Add an SNI certificate containing a domain name.
        If an SNI certificate cannot be found based on the domain name requested by the client, the server certificate will be returned by default.
      • Security Policy: If HTTPS is enabled on the listener port, you can select a security policy. This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions.
      • Backend Protocol: If HTTPS is enabled on the listener port, HTTP or HTTPS can be used to access the backend server. The default value is HTTP. This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions.
  4. Click OK.
Using kubectl
This section uses an existing load balancer as an example. An example YAML file of a SNI-compliant Service is as follows:
apiVersion: v1
kind: Service
  labels:
    app: test
  namespace: default
  annotations:
    kubernetes.io/elb.class: performance        # Load balancer type
    kubernetes.io/elb.id: 65318265-4f01-4541-a654-fa74e439dfd3  # ID of an existing load balancer
    kubernetes.io/elb.protocol-port: https:80    # Port where SNI is to be enabled
    kubernetes.io/elb.cert-id: b64ab636f1614e1a960b5249c497a880    # HTTPS server certificate
    kubernetes.io/elb.tls-certificate-ids: 5196aa70b0f143189e4cb54991ba2286,8125d71fcc124aabbe007610cba42d60    # SNI certificate IDs
    kubernetes.io/elb.lb-algorithm: ROUND_ROBIN
  selector:
    app: test
  externalTrafficPolicy: Cluster
  ports:
    - name: cce-service-0
      targetPort: 80
      nodePort: 0
      port: 80
      protocol: TCP
  type: LoadBalancer
  loadBalancerIP: **.**.**.**       #  Private IP address of the load balancer
Table 1 Key parameters
Type
String
If a Service is HTTP/HTTPS-compliant, configure the protocol and port number in the format of "protocol:port".
where,
  • protocol: specifies the protocol used by the listener port. The value can be http or https.
  • ports: Service ports specified by spec.ports[].port.
For example, to use SNI, the Service protocol must be https and the Service port must be 80. Therefore, the parameter value is https:80.
String
ID of an ELB certificate, which is used as the HTTPS server certificate.
To obtain the certificate, log in to the CCE console, choose Service List > Networking > Elastic Load Balance, and click Certificates in the navigation pane. In the load balancer list, copy the ID under the target certificate name.
String
In ELB, the IDs of SNI certificates that must contain a domain name are separated by commas (,).
