هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
On this page
Node Configuration Consistency
Updated on 2024-01-04 GMT+08:00
Check Items
When you upgrade a cluster to v1.19 or later, the system checks whether the following configuration files have been modified on the backend:
  • /opt/cloud/cce/kubernetes/kubelet/kubelet
  • /opt/cloud/cce/kubernetes/kubelet/kubelet_config.yaml
  • /opt/cloud/cce/kubernetes/kube-proxy/kube-proxy
  • /etc/containerd/default_runtime_spec.json
  • /etc/sysconfig/docker
  • /etc/default/docker
  • /etc/docker/daemon.json
If you modify some parameters in these files, the cluster upgrade may fail or services may be abnormal after the upgrade. If you confirm that the modification does not affect services, continue the upgrade.
CCE uses the standard image script to check node configuration consistency. If you use other custom images, the check may fail.
The expected modification will not be intercepted. The following table lists the parameters that can be modified.
Table 1 Parameters that can be modified
Component
Configuration File
Upgrade Version
kubelet
cpuManagerPolicy
Later than v1.19
kubelet
maxPods
Later than v1.19
kubelet
kubeAPIQPS
Later than v1.19
kubelet
kubeAPIBurst
Later than v1.19
kubelet
podPidsLimit
Later than v1.19
kubelet
topologyManagerPolicy
Later than v1.19
kubelet
resolvConf
Later than v1.19
kubelet
eventRecordQPS
Later than v1.21
kubelet
topologyManagerScope
Later than v1.21
kubelet
allowedUnsafeSysctls
Later than v1.19
Docker
dm.basesize
Later than v1.19
Solution
If you modify some parameters in these files, exceptions may occur after the upgrade. If you are not sure whether the modified parameters will affect the upgrade, contact technical support.
