Creating an Nginx Ingress Using kubectl
This section uses an Nginx workload as an example to describe how to create an Nginx ingress using kubectl.
- The NGINX Ingress Controller add-on has been installed in a cluster. For details, see Installing the Add-on.
- An ingress provides network access for backend workloads. Ensure that a workload is available in a cluster. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
- A ClusterIP or NodePort Service has been configured for the workload. For details about how to configure the Service, see ClusterIP or NodePort.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
Starting from cluster v1.23, the ingress version is switched from networking.k8s.io/v1beta1 to networking.k8s.io/v1. For details about the differences between v1 and v1beta1, see Ingress API Version Upgrade in CCE Clusters v1.23.
The following uses HTTP as an example to describe how to configure the YAML file:
For clusters of v1.23 or later:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test spec: rules: - host: '' http: paths: - path: / backend: service: name: <your_service_name> # Replace it with the name of your target Service. port: number: <your_service_port> # Replace it with the port number of your target Service. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: nginx # Nginx ingresses are used. If multiple NGINX Ingress Controllers are installed in the cluster, replace nginx with the custom names of the controllers associated with the ingresses.
For clusters of v1.21 or earlier:apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/ingress.class: nginx # Nginx Ingress is used. spec: rules: - host: '' http: paths: - path: '/' backend: serviceName: <your_service_name> # Replace it with the name of your target Service. servicePort: <your_service_port> # Replace it with the port number of your target Service.
Table 1 Key parameters Parameter
Mandatory
Type
Yes (only for clusters of v1.21 or earlier)
String
nginx: indicates that Nginx Ingress is used. This option is available only after the NGINX Ingress Controller add-on is installed.
This parameter is mandatory when an ingress is created by calling the API.
ingressClassName
Yes
(only for clusters of v1.23 or later)
String
Multiple NGINX Ingress Controller add-ons can be installed in a single cluster if the add-on version is 2.5.4 or later. In this case, the value of this parameter must be the controller name customized during controller installation, indicating that the ingress is managed by that specific controller.
host
No
String
Domain name for accessing the Service. By default, this parameter is left blank, and the domain name needs to be fully matched. Ensure that the domain name has been registered and licensed. Once a forwarding policy is configured with a domain name specified, you must use the domain name for access.
path
Yes
String
User-defined route path. All external access requests must match host and path.
NOTE:- The access path matching rule of Nginx Ingress is based on the path prefix separated by the slash (/) and is case-sensitive. If the subpath separated by a slash (/) matches the prefix, the access is normal. However, if the prefix is only a part of the character string in the subpath, the access is not matched. For example, if the URL is set to /healthz, /healthz/v1 is matched, but /healthzv1 is not matched.
- The access path added here must exist in the backend application. Otherwise, the forwarding fails.
For example, the default access URL of the Nginx application is /usr/share/nginx/html. When adding /test to the ingress forwarding policy, ensure the access URL of your Nginx application contains /usr/share/nginx/html/test. Otherwise, error 404 will be returned.
No
String
Route matching policy.
Default: STARTS_WITH (prefix match)
Options:
- EQUAL_TO: exact match
- STARTS_WITH: prefix match
pathType
Yes
String
Path type. This field is supported only by clusters of v1.23 or later.- ImplementationSpecific: The matching method depends on Ingress Controller. The matching method defined by ingress.beta.kubernetes.io/url-match-mode is used in CCE.
- Exact: exact matching of the URL, which is case-sensitive.
- Prefix: prefix matching, which is case-sensitive. With this method, the URL path is separated into multiple elements by slashes (/) and the elements are matched one by one. If each element in the URL matches the path, the subpaths of the URL can be routed normally.
- During prefix matching, each element must be exactly matched. If the last element of the URL is the substring of the last element in the request path, no matching is performed. For example, /foo/bar matches /foo/bar/baz but does not match /foo/barbaz.
- When elements are separated by slashes (/), if the URL or request path ends with a slash (/), the slash (/) at the end is ignored. For example, /foo/bar matches /foo/bar/.
See examples of ingress path matching.
- Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress/ingress-test created
- Check the created ingress.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test nginx * 121.**.**.** 80 10s
- Enter http://121.**.**.**:80 in the address box of the browser to access the workload (for example, Nginx workload).
121.**.**.** indicates the IP address of the unified load balancer.
