Creating a Policy
APIG provides flexible API control policies.
Policy parameters will be stored as plaintext. To prevent information leakage, do not contain sensitive information in these parameters.
Guidelines
- An API can be bound with only one policy of the same type.
- Policies are independent of APIs. A policy takes effect for an API only after they are bound to each other. When binding a policy to an API, you must specify an environment where the API has been published. The policy takes effect for the API only in the specified environment.
- After you bind a policy to an API, unbind the policy from the API, or update the policy, you do not need to publish the API again.
- Taking an API offline does not affect the policies bound to it. The policies are still bound to the API if the API is published again.
- Policies that have been bound to APIs cannot be deleted.
Creating a Policy
- Log in to the APIG console.
- Select a gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > API Policies.
- On the Policies tab, click Create Policy.
- Click the desired policy type.
- Plug-in policies
Set the policy information.
Table 1 Policy configuration Parameter
Name
Enter a policy name that conforms to specific rules to facilitate search.
Type
Type of the policy, which determines the extension capabilities.
NOTE:If a policy type is not supported by your gateway, contact technical support to upgrade the gateway to the latest version.
- CORS: Provides the capabilities of specifying preflight request headers and response headers and automatically creating preflight request APIs for cross-origin API access.
- HTTP Response Header Management: Enables you to customize HTTP response headers that will be displayed in an API response.
- Request Throttling 2.0: Limits the number of times that an API can be called within a specific time period. Parameter-based, basic, and excluded throttling is supported.
- Kafka Log Push: Pushes API calling logs to Kafka so that you can view these logs.
- Circuit Breaker: Protects your backend service when a performance issue occurs.
Description about the plug-in.
Policy Content
Content of the plug-in, which can be configured in a form or using a script.
The plug-in content varies depending on the plug-in type:
- Traditional policies
The policy content varies depending on the policy type:
- Plug-in policies
- Click OK.
After the policy is created, perform the operations described in Binding a Policy to APIs for the policy to take effect for the API.
- Click a policy name to go to the policy details page.
- In the APIs area, select an environment and click Select APIs.
- Select an API group and then select APIs.
- Click OK.
- If an API no longer needs this policy, click Unbind in the row that contains the API.
- If there are multiple APIs that no longer need this policy, select these APIs, and click Unbind above the API list. You can unbind a policy from a maximum of 1000 APIs at a time.
