Can I Access an API Published in a Non-RELEASE Environment?
Yes. To access an API published in a non-RELEASE environment, add the x-stage header to the API request.
Example:
r.Header.Add("x-stage", "RELEASE")
 You can also refer to examples of section "Quickly Opening and Calling APIs" in the "Getting Started" chapter of the API Gateway User Guide.
