Using a Secret
After secrets are created, they can be mounted as data volumes or be exposed as environment variables to be used by a container in a pod.
Do not perform any operation on the following secrets. For details, see Cluster Secrets.
- Do not operate secrets under kube-system.
- Do not operate default-secret and paas.elb in any of the namespaces. The default-secret is used to pull the private image of SWR, and the paas.elb is used to connect the service in the namespace to the ELB service.
The following example shows how to use a secret.
apiVersion: v1 kind: Secret metadata: name: mysecret type: Opaque data: username: ****** #The value must be Base64-encoded. password: ****** #The value must be encoded using Base64.
- When a secret is used in a pod, the pod and secret must be in the same cluster and namespace.
- When a secret is updated, Kubernetes updates the data in the data volume at the same time.
However, when a secret data volume mounted in subPath mode is updated, Kubernetes cannot automatically update the data in the data volume.
Configuring Environment Variables of a Workload
Using the CCE console
- In the navigation pane, choose Workloads. In the dialog box displayed, click Create Workload in the upper right corner.
When creating a workload, click Environment Variables in the Container Settings area, and click Add Variable.
- Added from secret: Select a secret and import all keys in the secret as environment variables.
- Added from secret key: Import the value of a key in a secret as the value of an environment variable.
- Variable Name: name of an environment variable in the workload. The name can be customized and is set to the key name selected in the secret by default.
- Variable Value/Reference: Select a secret and the key to be imported. The corresponding value is imported as a workload environment variable.
For example, after you import the value of username in secret mysecret as the value of workload environment variable username, an environment variable named username exists in the container.
- Configure other workload parameters and click Create Workload.
After the workload runs properly, log in to the container and run the following statement to check whether the secret has been set as an environment variable of the workload:
printenv username
If the output is the same as the content in the secret, the secret has been set as an environment variable of the workload.
Using kubectl
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a file named nginx-secret.yaml and edit it.
vi nginx-secret.yaml
Content of the YAML file:
- Added from secret: To add all data in a secret to environment variables, use the envFrom parameter. The keys in the secret will become names of environment variables in a workload.
apiVersion: apps/v1 kind: Deployment metadata: name: nginx-secret spec: replicas: 1 selector: matchLabels: app: nginx-secret template: metadata: labels: app: nginx-secret spec: containers: - name: container-1 image: nginx:latest envFrom: # Use envFrom to specify a secret to be referenced by environment variables. - secretRef: name: mysecret # Name of the referenced secret. imagePullSecrets: - name: default-secret - Added from secret key: When creating a workload, you can use a secret to set environment variables and use the valueFrom parameter to reference the key-value pair in the secret separately.
apiVersion: apps/v1 kind: Deployment metadata: name: nginx-secret spec: replicas: 1 selector: matchLabels: app: nginx-secret template: metadata: labels: app: nginx-secret spec: containers: - name: container-1 image: nginx:latest env: # Set the environment variable in the workload. - name: SECRET_USERNAME # Name of the environment variable in the workload. valueFrom: # Use valueFrom to specify a secret to be referenced by environment variables. secretKeyRef: name: mysecret # Name of the referenced secret. key: username # Key in the referenced secret. - name: SECRET_PASSWORD # Add multiple environment variables to import them at the same time. valueFrom: secretKeyRef: name: mysecret key: password imagePullSecrets: - name: default-secret
- Create a workload.
kubectl apply -f nginx-secret.yaml
- View the environment variables in the pod.
- Run the following command to view the created pod:
kubectl get pod | grep nginx-secret
Expected output:nginx-secret-*** 1/1 Running 0 2m18s
- Run the following command to view the environment variables in the pod:
kubectl exec nginx-secret-*** -- printenv SPECIAL_USERNAME SPECIAL_PASSWORD
Configuring the Data Volume of a Workload
You can mount a secret as a volume to the specified container path. Contents in a secret are user-defined. Before that, create a secret. For details, see Creating a Secret.
- Choose Workloads in the navigation pane. In the right pane, click the Deployments tab. Click Create Workload in the upper right corner.
When creating a workload, click Data Storage in the Container Settings area. Click Add Volume and choose Secret from the drop-down list.
- Select parameters for mounting a secret volume, as shown in Table 1.
Table 1 Mounting a secret volume Parameter
Secret
Select the desired secret.
A secret must be created beforehand. For details, see Creating a Secret.
Mount Path
Enter a mount path. After the secret volume is mounted, a secret file with the key as the file name and value as the file content is generated in the mount path of the container.
This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. This may lead to container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.NOTICE:If the container is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
Subpath
Enter a subpath of the mount path.
- A subpath is used to mount a local volume so that the same data volume is used in a single pod. If this parameter is left blank, the root path will be used by default.
- The subpath can be the key and value of a secret. If the subpath is a key-value pair that does not exist, the data import does not take effect.
- The data imported by specifying a subpath will not be updated along with the secret updates.
Permission
Read-only, indicating that data volume in the path is read-only.
Figure 1 Mounting a secret to a workload data volume
- After the configuration, click Create Workload.
After the workload runs properly, the username and password files will be generated in the /etc/foo directory in this example. The contents of the files are secret values.
Access the container and run the following statement to view the username or password file in the container:
cat /etc/foo/usernameThe expected output is the same as the content in the secret.
Using kubectl
In the following example, the username and password in the mysecret secret are saved in the /etc/foo directory as files.apiVersion: apps/v1 kind: Deployment metadata: name: nginx-secret spec: replicas: 1 selector: matchLabels: app: nginx-secret template: metadata: labels: app: nginx-secret spec: containers: - name: container-1 image: nginx:latest volumeMounts: - name: foo mountPath: /etc/foo # Mount to the /etc/foo directory. readOnly: true volumes: - name: foo secret: secretName: mysecret # Name of the referenced secret.You can also use the items field to control the mapping path of secret keys. For example, store username in the /etc/foo/my-group/my-username directory in the container.
- If you use the items field to specify the mapping path of the secret keys, the keys that are not specified will not be created as files. For example, if the password key in the following example is not specified, the file will not be created.
- If you want to use all keys in a secret, you must list all keys in the items field.
- All keys listed in items must exist in target secrets. Otherwise, the volume is not created.
apiVersion: apps/v1 kind: Deployment metadata: name: nginx-secret spec: replicas: 1 selector: matchLabels: app: nginx-secret template: metadata: labels: app: nginx-secret spec: containers: - name: container-1 image: nginx:latest volumeMounts: - name: foo mountPath: /etc/foo # Mount to the /etc/foo directory. readOnly: true volumes: - name: foo secret: secretName: mysecret # Name of the referenced secret. items: - key: username # Name of the referenced key. path: my-group/my-username # Mapping path of the secret key - Create a workload.
- After the workload runs properly, the username and password files will be generated in the /etc/foo directory.
- Run the following command to view the username or password file in the pod:
kubectl exec nginx-secret-*** -- cat /etc/foo/usernameThe expected output is the same as the content in the secret.
