示例
创建namespace
为方便验证基本功能创建test-clickhouse-operator的namespace。
kubectl create namespace test-clickhouse-operator
Simple example
yaml文件如下:
apiVersion: "clickhouse.altinity.com/v1" kind: "ClickHouseInstallation" metadata: name: "simple-01"
使用如下命令创建:
kubectl apply -n test-clickhouse-operator -f https://raw.githubusercontent.com/Altinity/clickhouse-operator/master/docs/chi-examples/01-simple-layout-01-1shard-1repl.yaml
一段时间后,查看资源运行情况:
kubectl get pod -n test-clickhouse-operator
kubectl get service -n test-clickhouse-operator
连接ClickHouse Database:
kubectl -n test-clickhouse-operator exec -ti chi-simple-01-cluster-0-0-0 -- clickhouse-client
Simple Persistent Volume Example
在CCE使用PVC时,yaml文件需做一些适配:
- 使用云硬盘存储卷EVS
- 创建storageClass
CCE默认支持的csi-disk为SAS类型的云硬盘。 若想使用超高I/O类型的云硬盘,需要创建对应的storageClass。
vim csi disk ssd.yaml
复制以下内容:
allowVolumeExpansion: true apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: csi-disk-ssd parameters: csi.storage.k8s.io/csi-driver-name: disk.csi.everest.io csi.storage.k8s.io/fstype: ext4 everest.io/disk-volume-type: SSD everest.io/passthrough: "true" provisioner: everest-csi-provisioner reclaimPolicy: Delete volumeBindingMode: Immediate
保存后退出:
kubectl create -f csi-disk-ssd.yaml
- accessModes需填写为ReadWriteOnce。
- 添加storageClassName: csi-disk-ssd。
- 创建storageClass
- 使用文件存储卷SFS
- accessModes需填写为ReadWriteMany。
- 添加storageClassName: csi-nas。
下面以文件存储卷SFS为例,yaml文件如下:
apiVersion: "clickhouse.altinity.com/v1" kind: "ClickHouseInstallation" metadata: name: "pv-simple" spec: defaults: templates: dataVolumeClaimTemplate: data-volume-template logVolumeClaimTemplate: log-volume-template configuration: clusters: - name: "simple" layout: shardsCount: 1 replicasCount: 1 templates: volumeClaimTemplates: - name: data-volume-template spec: accessModes: - ReadWriteMany resources: requests: storage: 10Gi storageClassName: csi-nas - name: log-volume-template spec: accessModes: - ReadWriteMany resources: requests: storage: 10Gi storageClassName: csi-nas
使用如下命令创建:
kubectl -n test-clickhouse-operator create -f 03-persistent-volume-01-default-volume.yaml
一段时间后,查看资源运行情况:
kubectl get pvc -n test-clickhouse-operator
查看存储卷挂载情况:
kubectl -n test-clickhouse-operator exec -ti chi-pv-simple-simple-0-0-0 -c clickhouse bash
df -h
kubectl -n test-clickhouse-operator exec -ti chi-pv-simple-simple-0-0-0 -- clickhouse-client
Simple Load Balancer Example
apiVersion: "clickhouse.altinity.com/v1" kind: "ClickHouseInstallation" metadata: name: "ck-elb" spec: defaults: templates: dataVolumeClaimTemplate: data-volume-nas serviceTemplate: chi-service-elb configuration: clusters: - name: "ck-elb" templates: podTemplate: pod-template-with-nas layout: shardsCount: 1 replicasCount: 1 templates: podTemplates: - name: pod-template-with-nas spec: containers: - name: clickhouse image: yandex/clickhouse-server:21.6.3.14 volumeMounts: - name: data-volume-nas mountPath: /var/lib/clickhouse volumeClaimTemplates: - name: data-volume-nas spec: accessModes: - ReadWriteMany resources: requests: storage: 20Gi storageClassName: csi-nas serviceTemplates: - name: chi-service-elb metadata: annotations: kubernetes.io/elb.class: union kubernetes.io/elb.autocreate: >- {"type":"public","bandwidth_name":"cce-bandwidth-ck","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp"} spec: ports: - name: http port: 8123 - name: client port: 9000 type: LoadBalancer
添加加粗部分内容。其中annotations kubernetes.io/elb.autocreate支持以下参数:
参数 |
参数类型 |
描述 |
name |
String |
自动创建的负载均衡的名称。 取值范围:1-64个字符,小写字母,数字,下划线,小写字母开头,小写字母或者数字结尾。 |
type |
String |
负载均衡实例网络类型,公网或者私网。
bandwidth_name |
String |
带宽的名称,默认值为:cce-bandwidth-******。 取值范围:1-64个字符,小写字母,数字,下划线,小写字母开头,小写字母或者数字结尾。 |
bandwidth_chargemode |
String |
带宽付费模式。
bandwidth_size |
Integer |
带宽大小 |
bandwidth_sharetype |
String |
带宽共享方式。
eip_type |
String |
弹性公网IP类型 |
