# instr
**数据库类型与版本**
- 源库类型与版本：Oracle所有版本。
- 目标库类型与版本：GaussDB V2.0-2.7之前版本。
**转换替代方案：**
CREATE OR REPLACE FUNCTION dsc_ora_ext.dsc_fn_instr
/* 1st param (i_str) is the text expression to search
   2nd param (i_substr) is the string to search for
   3rd param (i_startpos) is a nonzero INTEGER indicating where in string
       the function begins the search. When it is negative, then INSTR counts
   and searches backward from the end of string. Default value is 1.
   4th param (i_occurrence)An INTEGER indicating which occurrence of string
       the function should search for. It must be positive; Default value is 1.
     ( i_str           IN   TEXT
 , i_substr        IN   TEXT
 , i_startpos      IN   INTEGER = 1
 , i_occurrence    IN   INTEGER = 1 )
RETURN INTEGER
IMMUTABLE
AS
      v_search_str        TEXT;
      v_shift             INTEGER := 0;
      v_pos               INTEGER;
BEGIN
    IF i_str IS NULL OR i_substr IS NULL THEN
    -- if source string or substring is empty
   RETURN NULL;
    END IF;
    IF i_occurrence <= 0 THEN
   RAISE EXCEPTION 'ERROR-01428: argument -1 is out of range';
END IF;
    IF i_startpos = 0 THEN
        RETURN 0;
    END IF;
    /* When i_startpos is negative, then the function should count and
   searches backward from the end of string. */
    IF i_startpos < 0 THEN
        i_str    := REVERSE(i_str);
        i_substr := REVERSE(i_substr);
        v_pos    := -1 * i_startpos;
    ELSE
        v_pos := i_startpos;
    END IF;
    FOR idx IN 1..i_occurrence
LOOP
        v_shift      := v_shift + v_pos;
        v_search_str := SUBSTR(i_str, v_shift);
        v_pos        := STRPOS(v_search_str, i_substr);
        IF v_pos = 0 THEN
            RETURN 0;
        END IF;
    END LOOP;
    IF i_startpos > 0 THEN
       RETURN v_pos + v_shift - 1;
    ELSE
       RETURN LENGTH(i_str) - LENGTH(i_substr) - v_pos - v_shift + 3;
    END IF;
END;
