# 支持的插件列表
![](https://support.huaweicloud.com/usermanual-taurusdb-pg/public_sys-resources/note_3.0-zh-cn.png)
如下表格中的数据来源于TaurusDB for PostgreSQL引擎各版本下，最新小版本支持的插件列表。您可以通过**SELECT name FROM pg_available_extensions;**语句，查看当前实例支持的插件列表。
使用mysql_fdw、dblink、pgsql-ogr-fdw、postgres_fdw和tds_fdw等需要跨数据库实例访问的插件时，要求两个数据库实例的服务端IP必须在同一个VPC和子网内。
#### 支持的插件列表
表1支持的插件列表
| 插件名称        | PostgreSQL 16                                          |
| address_standardizer          | 3.4.3  |
| address_standardizer_data_us | 3.4.3   |
| amcheck                        | 1.3   |
| auth_delay                      | 2        |
| autoinc                         | 1      |
| dblink                         | 1.2     |
| dict_int                        | 1       |
| dict_xsyn                     | 1        |
| fuzzystrmatch                 | 1.2    |
| hll                           | 2.18     |
| insert_username              | 1       |
| intagg                        | 1.1     |
| intarray                      | 1.5      |
| ip4r                         | 2.4.2  |
| isn                             | 1.2    |
| jsonb_plperl                   | 1      |
| lo                              | 1.1     |
| moddatetime                  | 1       |
| mysql_fdw                    | 2.9.1  |
| orafce                          | 4.14    |
| pageinspect                    | 1.12      |
| passwordcheck                  | 2        |
| pgAudit                       | 16      |
| pg_bigm                         | 1.2     |
| pg_buffercache                | 1.4      |
| pg_cron                       | 1.6.2   |
| pg_freespacemap               | 1.2     |
| pg_hint_plan                   | 1.6.1   |
| pg_partman                    | 5.0.1 |
| pg_prewarm                      | 1.2     |
| pg_qualstats                     | 2.1.1     |
| pg_repack                     | 1.5.2 |
| pg_roaringbitmap                | 0.5.4   |
| pg_stat_statements            | 1.1    |
| pg_sugry                       | 1        |
| pg_trgm                       | 1.6     |
| pg_visibility                 | 1.2    |
| pgl_ddl_deploy                | 2.2.1    |
| pgrouting                      | 3.6.1     |
| pgrowlocks                     | 1.2   |
| pg_sql_history                | 1.2       |
| pgstattuple                    | 1.5     |
| plpgsql                       | 1       |
| plperl                           | 1       |
| plproxy                       | 2.11.0 |
| postgis                        | 3.4.3   |
| postgis_raster                | 3.4.3  |
| postgis_sfcgal                 | 3.4.3   |
| postgis_topology               | 3.4.3  |
| postgres_fdw                  | 1.1      |
| rds_hwdrs_ddl                    | 1        |
| rds_hwdrs_privs                | 1        |
| rds_pg_sql_ccl                 | 1       |
| rum                           | 1.3.13   |
| seg                             | 1.4    |
| sslinfo                         | 1.2     |
| tablefunc                      | 1       |
| tcn                            | 1       |
| tds_fdw                        | 2.0.4  |
| test_decoding                   | 2       |
| tsm_system_rows                | 1      |
| tsm_system_time                | 1       |
| unaccent                      | 1.1     |
| uuid-ossp                       | 1.1     |
| xml2                         | 1.1       |
