# 示例代码
#### Java语言
验证消息是否有效，其中signing_cert_url、signature是从[HTTP(S)消息格式](https://support.huaweicloud.com/usermanual-smn/smn_ug_a9002.html)描述获取的值，message为特定消息的签名键值。以下为示例代码，仅供参考。
private static void isMessageValid(String signing_cert_url, String signature, Map<String, String> message) {
InputStream in = null;
try {
URL url = new URL(signing_cert_url);
in = url.openStream();
CertificateFactory cf = CertificateFactory.getInstance("X.509");
X509Certificate cert = (X509Certificate) cf.generateCertificate(in);
Signature sig = Signature.getInstance(cert.getSigAlgName());
sig.initVerify(cert.getPublicKey());
sig.update(buildSignMessage(message).getBytes("UTF-8"));
byte[] sigByte = Base64.getDecoder().decode(signature);
if (sig.verify(sigByte)) {
System.out.println("Verify success");
} else {
System.out.println("Verify failed");
} catch (Exception e) {
throw new SecurityException("Verify method failed.", e);
} finally {
if (in != null) {
try {
in.close();
} catch (IOException e) {
e.printStackTrace();
![](https://support.huaweicloud.com/usermanual-smn/public_sys-resources/note_3.0-zh-cn.png)
使用Java 8 版本以下的用户，可以使用第三方jar包commons-codec.jar进行Base64解码。
并将上述样例代码中的"byte\[\] sigByte = Base64.getDecoder().decode(signature);"调整为"byte\[\] sigByte = Base64.decodeBase64(signature);"。
构建校验签名的示例代码
private static String buildSignMessage(Map<String, String> msg) {
String type = msg.get("type");
String message = null;
if ("Notification".equals(type)) {
message = buildNotificationMessage(msg);
} else if ("SubscriptionConfirmation".equals(type) || "UnsubscribeConfirmation".equals(type)) {
message = buildSubscriptionMessage(msg);
} else if ("HttpSubscriptionUserConfirm".equals(type)) {
message = buildSubscriptionUserConfirmMessage(msg);
} else if ("HttpSubscriptionUserUnsubscribe".equals(type)) {
message = buildSubscriptionUserUnsubscribeMessage(msg);
return message;
private static String buildSubscriptionMessage(Map<String, String> msg) {
String stringMessage = "message\n";
stringMessage += msg.get("message") + "\n";
stringMessage += "message_id\n";
stringMessage += msg.get("message_id") + "\n";
stringMessage += "subscribe_url\n";
stringMessage += msg.get("subscribe_url") + "\n";
stringMessage += "timestamp\n";
stringMessage += msg.get("timestamp") + "\n";
stringMessage += "topic_urn\n";
stringMessage += msg.get("topic_urn") + "\n";
stringMessage += "type\n";
stringMessage += msg.get("type") + "\n";
return stringMessage;
private static String buildNotificationMessage(Map<String, String> msg) {
stringMessage += msg.get("message").toString() + "\n";
stringMessage += msg.get("message_id").toString() + "\n";
if (msg.get("subject") != null) {
stringMessage += "subject\n";
stringMessage += msg.get("subject").toString() + "\n";
stringMessage += msg.get("timestamp").toString() + "\n";
stringMessage += msg.get("topic_urn").toString() + "\n";
stringMessage += msg.get("type").toString() + "\n";
private static String buildSubscriptionUserConfirmMessage(Map<String, String> msg) {
private static String buildSubscriptionUserUnsubscribeMessage(Map<String, String> msg) {
#### Node.js
const fs = require('fs');
const crypto = require('crypto');
const jsrsag = require('jsrsasign');
 * 校验消息签名
 * @param pemFile 签名文件存储路径(下载到本地证书文件路径)
 * @param signature 待验证的签名值
 * @param message 待验证的消息内容
 * @returns {boolean} true：签名值验证通过；false：签名值校验不通过
function verifyMessage(pemFile, signature, message) {
    const pubPem = fs.readFileSync(pemFile);
    const verify = crypto.createVerify(signatureAlgorithm(pubPem));
    verify.update(buildSignMessage(message));
    const verifyResult = verify.verify(pubPem, signature, 'base64');
    if (verifyResult) {
        console.log("verify success");
        return true;
    } else {
        console.log('verify failed, result: ' + verifyResult);
        return false;
 * 从证书中获取签名算法
function signatureAlgorithm(pubPem) {
    const certObject = new jsrsag.X509();
    certObject.readCertPEM(pubPem.toString());
    let algorithm = certObject.getSignatureAlgorithmField();
    if (algorithm.split('with').length > 1) {
        algorithm = algorithm.split('with')[1] + '-' + algorithm.split('with')[0];
    return algorithm;
function buildSignMessage(msg) {
    const type = msg.type;
    let message = '';
    if (type === 'Notification') {
    } else if (type === 'SubscriptionConfirmation' || type === 'UnsubscribeConfirmation') {
    } else if (type === 'HttpSubscriptionUserConfirm') {
    } else if (type === 'HttpSubscriptionUserUnsubscribe') {
    return message;
function buildNotificationMessage(msg) {
    let signMessage = 'message\n' + msg.message + '\n';
    signMessage += 'message_id\n' + msg.message_id + '\n';
    if (msg.subject) {
        signMessage += 'subject\n' + msg.subject + '\n';
    signMessage += 'timestamp\n' + msg.timestamp + '\n';
    signMessage += 'topic_urn\n' + msg.topic_urn + '\n';
    signMessage += 'type\n' + msg.type + '\n';
    return signMessage;
function buildSubscriptionMessage(msg) {
    signMessage += 'subscribe_url\n' + msg.subscribe_url + '\n';
    return signMessage;
function buildSubscriptionUserConfirmMessage(msg) {
    return signMessage;
function buildSubscriptionUserUnsubscribeMessage(msg) {
    return signMessage;
该示例代码已在Nodejs v14.17.5版本上测试通过。
#### Go语言
package demo
import (
"bytes"
"crypto"
"crypto/rsa"
"crypto/x509"
"encoding/base64"
"encoding/json"
"encoding/pem"
"fmt"
"io/ioutil"
type Message struct {
Signature        string  `json:"signature"`
Subject          *string `json:"subject"`
TopicUrn         string  `json:"topic_urn"`
MessageId        string  `json:"message_id"`
SignatureVersion string  `json:"signature_version"`
Type             string  `json:"type"`
Message          string  `json:"message"`
SubscribeUrl     string  `json:"subscribe_url"`
UnsubscribeUrl   string  `json:"unsubscribe_url"`
SigningCertUrl   string  `json:"signing_cert_url"`
Timestamp        string  `json:"timestamp"`
func VerifyMessage(pemFile string, message string) bool {
msg := Message{}
err := json.Unmarshal([]byte(message), &msg)
if err != nil {
fmt.Println("Convert json to struct failed")
return false
pemContent, err := ioutil.ReadFile(pemFile)
if err != nil {
fmt.Println("Read pem file failed")
return false
certDerblock, _ := pem.Decode(pemContent)
if certDerblock == nil {
fmt.Println("Decode pem file failed")
return false
cert, err := x509.ParseCertificate(certDerblock.Bytes)
if err != nil {
fmt.Println("Parse cert failed")
return false
msgString := buildMessage(&msg)
msgHash := crypto.SHA256.New()
msgHash.Write([]byte(msgString))
msgHashSum := msgHash.Sum(nil)
decodeSign, _ := base64.StdEncoding.DecodeString(msg.Signature)
publicKey := cert.PublicKey.(*rsa.PublicKey)
err = rsa.VerifyPKCS1v15(publicKey, crypto.SHA256, msgHashSum, decodeSign)
if err != nil {
fmt.Println("Verify failed")
return false
} else {
fmt.Println("Verify success")
return true
func buildMessage(msg *Message) string {
if msg.Type == "Notification" {
return buildNotificationMessage(msg)
} else if msg.Type == "SubscriptionConfirmation" || msg.Type == "UnsubscribeConfirmation" {
return buildSubscriptionMessage(msg)
} else if msg.Type == "HttpSubscriptionUserConfirm" {
return buildSubscriptionUserConfirmMessage(msg)
} else if msg.Type == "HttpSubscriptionUserUnsubscribe" {
return buildSubscriptionUserUnsubscribeMessage(msg)
return ""
func buildNotificationMessage(msg *Message) string {
buf := bytes.Buffer{}
buf.WriteString("message\n" + msg.Message + "\n")
buf.WriteString("message_id\n" + msg.MessageId + "\n")
// msg中存在Subject字段不存在的场景，需要特殊处理
if msg.Subject != nil {
buf.WriteString("subject\n" + *msg.Subject + "\n")
buf.WriteString("timestamp\n" + msg.Timestamp + "\n")
buf.WriteString("topic_urn\n" + msg.TopicUrn + "\n")
buf.WriteString("type\n" + msg.Type + "\n")
return buf.String()
func buildSubscriptionMessage(msg *Message) string {
buf.WriteString("subscribe_url\n" + msg.SubscribeUrl + "\n")
return buf.String()
func buildSubscriptionUserConfirmMessage(msg *Message) string {
return buf.String()
func buildSubscriptionUserUnsubscribeMessage(msg *Message) string {
return buf.String()
该示例代码已在go 1.15版本上测试通过。
