# 示例函数(Python)
#### 评估由配置变更触发的示例函数
Config服务检测到自定义组织合规规则范围内的资源发生更改时，会调用函数的示例如下：
import time
import http.client
from huaweicloudsdkcore.auth.credentials import GlobalCredentials
from huaweicloudsdkcore.exceptions.exceptions import ConnectionException
from huaweicloudsdkcore.exceptions.exceptions import RequestTimeoutException
from huaweicloudsdkcore.exceptions.exceptions import ServiceResponseException
from huaweicloudsdkconfig.v1.region.config_region import ConfigRegion
from huaweicloudsdkconfig.v1.config_client import ConfigClient
from huaweicloudsdkconfig.v1 import PolicyResource, PolicyStateRequestBody
from huaweicloudsdkconfig.v1 import UpdatePolicyStateRequest
合规规则评估逻辑: 返回“Compliant” 或 “NonCompliant”
本示例中, 当资源类型为ecs.cloudservers, 且该ecs的vpcId字段不是合规规则参数所指定的vpcId时, 会返回不合规, 否则返回合规。
def evaluate_compliance(resource, parameter):
    if resource.get("provider") != "ecs" or resource.get("type") != "cloudservers":
        return "Compliant"
    vpc_id = resource.get("properties", {}).get("metadata", {}).get("vpcId")
    return "Compliant" if vpc_id == parameter.get("vpcId") else "NonCompliant"
def update_policy_state(context, domain_id, evaluation):
    auth = GlobalCredentials(ak=context.getAccessKey(), sk=context.getSecretKey(), domain_id=domain_id)
    client = ConfigClient.new_builder() \
        .with_credentials(credentials=auth) \
        .with_region(region=ConfigRegion.value_of(region_id="cn-north-4")) \
        .build()
    try:
        response = client.update_policy_state(evaluation)
        return 200
    except ConnectionException as e:
        print("A connect timeout exception occurs while the Config performs some operations, exception: ", e.error_msg)
        return e.status_code
    except RequestTimeoutException as e:
        print("A request timeout exception occurs while the Config performs some operations, exception: ", e.error_msg)
    except ServiceResponseException as e:
        print("There is service error, exception: ", e.status_code, e.error_msg)
def handler(event, context):
    domain_id = "<manager_domain_id>"
    resource = event.get("invoking_event", {})
    parameters = event.get("rule_parameter")
    compliance_state = evaluate_compliance(resource, parameters)
    request_body = UpdatePolicyStateRequest(PolicyStateRequestBody(
        policy_resource = PolicyResource(
            resource_id = resource.get("id"),
            resource_name = resource.get("name"),
            resource_provider = resource.get("provider"),
            resource_type = resource.get("type"),
            region_id = resource.get("region_id"),
            domain_id = event.get("domain_id")
        trigger_type = event.get("trigger_type"),
        compliance_state = compliance_state,
        policy_assignment_id = event.get("policy_assignment_id"),
        policy_assignment_name = event.get("policy_assignment_name"),
        evaluation_time = event.get("evaluation_time"),
        evaluation_hash = event.get("evaluation_hash")
    for retry in range(5):
        status_code = update_policy_state(context, domain_id, request_body)
        if status_code == http.client.TOO_MANY_REQUESTS:
            print("TOO_MANY_REQUESTS: retry again")
            time.sleep(1)
        elif status_code == http.client.OK:
            print("Update policyState successfully.")
            break
        else:
            print("Failed to update policyState.")
            break
#### 评估由周期执行触发的示例函数
Config针对周期执行的自定义组织合规规则，会调用函数的示例如下：
import time
import http.client
from huaweicloudsdkiam.v3.region.iam_region import IamRegion
from huaweicloudsdkiam.v3 import IamClient, ShowDomainLoginPolicyRequest
合规规则评估逻辑：返回“Compliant”或“NonCompliant”。
本示例中, 当账号设置的登录会话失效时间大于30分钟, 会返回不合规, 否则返回合规。
实现方式是调用IAM服务的接口ShowDomainLoginPolicy。
该场景下，可能需要适当增加函数的执行超时时间和内存限制。
def evaluate_compliance(ak, sk, domain_id):
    credentials = GlobalCredentials(ak, sk)
    client = IamClient.new_builder() \
        .with_credentials(credentials) \
        .with_region(IamRegion.value_of("cn-north-4")) \
        .build()
    try:
        request = ShowDomainLoginPolicyRequest()
        request.domain_id = domain_id
        response = client.show_domain_login_policy(request)
        session_timeout = response.login_policy.session_timeout
        print("session_timeout", session_timeout)
        if not session_timeout:
            return "NonCompliant"
        return "NonCompliant" if session_timeout > 30 else "Compliant"
    except exceptions.ClientRequestException as e:
        print(e.status_code)
        print(e.request_id)
        print(e.error_code)
        print(e.error_msg)
        .build()
    try:
        return 200
    ak = "<user_ak>"
    sk = "<user_sk>"
    if resource.get("name") != "Account":
        return
    compliance_state = evaluate_compliance(ak, sk, event.get("domain_id"))
            time.sleep(1)
            break
        else:
            break
#### 依赖包
如果依赖包缺失，则需要手动导入依赖包，详见[配置依赖包](https://support.huaweicloud.com/usermanual-functiongraph/functiongraph_01_2119.html)。在上述示例中，使用到的依赖包为**huaweicloudsdkiam** 和**huaweicloudsdkconfig**。
