# 评审检查项
[评审检查项配置流程](https://support.huaweicloud.com/usermanual-projectman/codeartsreq_check3_02.html)
[配置评审检查项模板和评审检查项](https://support.huaweicloud.com/usermanual-projectman/codeartsreq_check3_03.html)
[配置评审检查项类型的字段](https://support.huaweicloud.com/usermanual-projectman/codeartsreq_check3_04.html)
[在工作项字段与工作流中配置该字段](https://support.huaweicloud.com/usermanual-projectman/codeartsreq_check3_05.html)
[配置该字段在新建页的行为](https://support.huaweicloud.com/usermanual-projectman/codeartsreq_check3_06.html)
[在评审设置中启用评审检查项](https://support.huaweicloud.com/usermanual-projectman/codeartsreq_check3_07.html)
[在工作项中使用评审检查项](https://support.huaweicloud.com/usermanual-projectman/codeartsreq_check3_08.html)
[在评审单中使用评审检查项](https://support.huaweicloud.com/usermanual-projectman/codeartsreq_check3_09.html)
