# 异形件-钣金切割
#### 场景描述
钣金切割是指将钣金件放置在钢板上，使得使用的钢板最少，以最大化钢板利用率。
#### 准备工作
- 已注册华为云账号，且账号不能处于欠费或者冻结状态，获取项目ID
- 获取Token
- 获取EndPoint
#### 导入数据
使用第三方软件集成服务商（比如FastCAM）客户端软件生成钣金切割数据文件，上传到华为云钣金切割服务。需要至少包含以下字段：排版时间、钢板尺寸、钢板个数、钢板修边距、零件距零件间距、是否共线切割，是否容许空洞排版以及其他排版约束等。
    "task_name": "TESTTASK",
        "project_name": "TESTPRO",
        "user_id": "user_123456789",
        "time": 20,
        "item_spacing": 10,
        "plate_spacing": 20,
        "forbid_internal_nesting": 0,
        "common_cut_nest": 0,
        "leadin_before_nesting":2,
        "plates": [
            "plate_id": 0,
            "plate_name": "",
            "plate_length": 4000,
            "plate_width": 4000,
            "plate_count": 200
    "cams": [
            "item_id": 0,
            "item_name": "d:\rectangle.cam",
            "count": 2,
            "priority": 5,
            "rotation_type": 2,
            "flip": 0,
            "pair_collinear": 0,
            "collinear_entity_id": 0,
            "entities": [
                    "entity_id": 1,
                    "entity_type": 1,
                    "start_x": 0,
                    "start_y": 0,
                    "end_x": 3200,
                    "end_y": 0,
                    "circle_center_x": 0,
                    "circle_center_y": 0,
                    "dxf_name": "",
                    "entry_type": 0,
                    "ifoutside": 1,
                    "next_entity":4,
                    "last_entity":0
                    "entity_id": 2,
                    "entity_type": 1,
                    "start_x": 3200,
                    "start_y": 0,
                    "end_x": 3200,
                    "end_y": 1600,
                    "dxf_name": "",
                    "entry_type": 0,
                    "ifoutside": 1,
                    "next_entity":0,
                    "last_entity":3
                    "entity_id": 3,
                    "entity_type": -2,
                    "start_x": 3200,
                    "start_y": 1600,
                    "end_x": 0,
                    "end_y": 1600,
                    "circle_center_x": 1600,
                    "circle_center_y": 2200,
                    "dxf_name": "",
                    "entry_type": 0,
                    "ifoutside": 1,
                    "next_entity":2,
                    "last_entity":4
                    "entity_id": 4,
                    "entity_type": 1,
                    "start_x": 0,
                    "start_y": 1600,
                    "end_x": 0,
                    "end_y": 0,
                    "dxf_name": "",
                    "entry_type": 0,
                    "ifoutside": 1,
                    "next_entity":3,
                    "last_entity":1
            "item_id": 1,
            "item_name": "d:\rectangle2.cam",
            "count": 3,
            "priority": 5,
            "rotation_type": 2,
            "flip": 0,
            "entities":[
                    "entity_id": 1,
                    "entity_type": 1,
                    "start_x": 0,
                    "start_y": 0,
                    "end_x": 500,
                    "end_y": 0,
                    "dxf_name": "",
                    "entry_type": 0,
                    "ifoutside": 1,
                    "next_entity":2,
                    "last_entity":0
                    "entity_id": 2,
                    "entity_type": 1,
                    "start_x": 500,
                    "start_y": 0,
                    "end_x": 500,
                    "end_y": 500,
                    "dxf_name": "",
                    "entry_type": 0,
                    "ifoutside": 1,
                    "next_entity":3,
                    "last_entity":1
                    "entity_id": 3,
                    "entity_type": 1,
                    "start_x": 500,
                    "start_y": 500,
                    "end_x": 0,
                    "end_y": 0,
                    "dxf_name": "",
                    "entry_type": 0,
                    "ifoutside": 1,
                    "next_entity":0,
                    "last_entity":2
            "item_id": 2,
            "count": 2,
            "priority": 5,
            "rotation_type": 2,
            "flip": 0,
            "entities":[
                    "entity_id": 1,
                    "entity_type": 2,
                    "start_x": 500,
                    "start_y": 0,
                    "end_x": 500,
                    "end_y": 0,
                    "dxf_name": "",
                    "entry_type": 0,
                    "ifoutside": 1,
                    "next_entity":0,
                    "last_entity":0
    "total_cams":3,
#### 查询结果
待切割排版任务完成后，查询排版结果。华为云钣金排版服务将返回json格式排版结果文件，可以通过第三方软件服务商展示排版结果，生成适配切割机的切割文件。
      "task_id": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
      "task_type": "test_type",
      "task_name": "sss",
      "status": "RUNNING",
      "created_at": "2018-06-12T13:00:01Z",
      "updated_at": "2018-06-13T13:00:01Z",
      "result": {
        "average_ratio": 0.43922290579330253,
        "item_spacing": 10.0,
        "nesting": [
            "item_count": 7,
            "items": [
                "envelope_rect_center_x": 1605.0000000000018,
                "envelope_rect_center_y": 1959.4003744920346,
                "flip_x": 0,
                "flip_y": 0,
                "item_angle": 0.0,
                "envelope_rect_center_y": 3570.133437492032,
                "flip_x": 0,
                "flip_y": 0,
                "item_angle": 0.0,
                "envelope_rect_center_x": 505.0,
                "envelope_rect_center_y": 3348.425682497144,
                "flip_x": 0,
                "flip_y": 0,
                "item_angle": 0.0,
                "envelope_rect_center_x": 1136.003821693054,
                "envelope_rect_center_y": 1105.7330629999974,
                "flip_x": 0,
                "flip_y": 0,
                "item_angle": 0.0,
                "envelope_rect_center_x": 705.1606452469719,
                "envelope_rect_center_y": 2827.3374108695393,
                "flip_x": 0,
                "flip_y": 0,
                "item_angle": 0.0,
                "envelope_rect_center_x": 1001.5517970744211,
                "envelope_rect_center_y": 2606.6574946969886,
                "flip_x": 0,
                "flip_y": 0,
                "item_angle": 0.0,
                "envelope_rect_center_x": 269.9895399372879,
                "envelope_rect_center_y": 1355.7330629372852,
                "flip_x": 0,
                "flip_y": 0,
                "item_angle": 90.0,
            "plate_id": 0,
            "plate_length": 3980.0,
            "plate_name": "",
            "plate_ratio": 0.43922290579330253,
            "plate_width": 3980.0
        "plate_count": 1,
        "plate_spacing": 20.0,
        "time": 20,
        "total_item_count": 7
