# 识别结果后处理
#### 提取特定字段导入Excel
本示例调用身份证识别API，并从获取到的JSON结果中，提取所需的字段，填入至Excel。
- 前提条件
  - [开通身份证识别](https://support.huaweicloud.com/usermanual-ocr/ocr_08_0002.html)。
  - 参考[本地调用](https://support.huaweicloud.com/usermanual-ocr/ocr_08_0007.html)，安装OCR Python SDK。并执行**pip install xlsxwriter**命令安装依赖包。
  - 登录"[我的凭证](https://console.huaweicloud.com/iam/#/myCredential) \> 访问密钥"页面，获取AK、SK。可以新增访问密钥，或使用已有的访问密钥。访问密钥为credentials.csv文件，包含AK/SK信息。
    ![](https://support.huaweicloud.com/usermanual-ocr/zh-cn_image_0000001192206676.png "点击放大")
- 代码示例
  # -*- coding: utf-8 -*-
  import base64
  import xlsxwriter
  from huaweicloudsdkcore.auth.credentials import BasicCredentials
  from huaweicloudsdkocr.v1.region.ocr_region import OcrRegion
  from huaweicloudsdkcore.exceptions import exceptions
  from huaweicloudsdkocr.v1 import *
  from huaweicloudsdkcore.http.http_config import HttpConfig
  def recognize_id_card_request():
      try:
          request = RecognizeIdCardRequest()
          request.body = IdCardRequestBody(
              image=image_base64
          response = client.recognize_id_card(request)
          return response
      except exceptions.ClientRequestException as e:
          print(e.status_code)
          print(e.request_id)
          print(e.error_code)
          print(e.error_msg)
  def get_credential():
      return BasicCredentials(ak, sk)
  def get_client():
      config = HttpConfig.get_default_config()
      config.ignore_ssl_verification = True
      return OcrClient.new_builder(OcrClient) \
          .with_credentials(credentials) \
          .with_region(OcrRegion.CN_NORTH_4) \
          .with_http_config(config) \
          .build()
  def image_to_base64(imagepath):
      将本地图片转化为base64编码
      with open(imagepath, "rb") as bin_data:
          image_data = bin_data.read()
      base64_data = base64.b64encode(image_data).decode("utf-8")
      return base64_data
  def response_to_execl(save_file, data):
      :param save_file: 文件名
      :param data: result data
      # 处理调用API返回的result数据
      keys_list = list(data["result"].keys())
      values_list = list(data["result"].values())
      options = {'in_memory': True}
      with xlsxwriter.Workbook(save_file, options) as workbook:
          worksheet = workbook.add_worksheet()
          worksheet.set_column('A1:A20', 23)
          worksheet.set_column('B1:B20', 100)
          worksheet.write_column('A1', keys_list)
          worksheet.write_column('B1', values_list)
      workbook.close()
  if __name__ == '__main__':
      # 填写访问密钥AK、SK
      ak = "填写AK"
      sk = "填写SK"
      # Init Auth Info
      credentials = get_credential()
      # Create OcrClient
      client = get_client()
      image_base64 = image_to_base64(r"图片的路径，例如D:\local\test.png")
      # request id card service
      response = recognize_id_card_request().to_dict()
      # 数据保存在execl上
      response_to_execl(r"excel路径，例如D:\local\test.xlsx", response)
#### 使用PDF进行文字识别
本示例将PDF文件转换为图片，并调用网络图片识别API，获取识别结果。
- 前提条件
  - [开通网络图片识别](https://support.huaweicloud.com/usermanual-ocr/ocr_08_0002.html)。
  - 参考[本地调用](https://support.huaweicloud.com/usermanual-ocr/ocr_08_0007.html)，安装OCR Python SDK。并执行**pip install fitz** 命令和**pip install PyMuPDF==1.18.0**命令安装依赖包。
    ![](https://support.huaweicloud.com/usermanual-ocr/zh-cn_image_0000001192526660.png "点击放大")
- 代码示例
  import os
  import base64
  import fitz
  import io
  from PIL import Image
  from glob import glob
  class CovertPdfToJpg:
      def __init__(self, file_path, save_root):
          self.file_path = file_path
          self.save_root = save_root
      @staticmethod
      def open_pdf(file):
          return fitz.open(file)
      @staticmethod
      def get_trans(doc, page, min_side=0, max_side=0, rotate=0.0):
          """ 创建scale对象 """
          region = doc[page].rect
          scale = 1
          if max_side > min_side > 0:
              scale = min_side / min(region.width, region.height)
              if max(region.width, region.height) * scale > max_side:
                  scale = max_side / max(region.width, region.height)
          trans = fitz.Matrix(scale, scale).preRotate(rotate)
          return trans
      def page2pix(self, doc, page, trans):
          """ 根据给定的参数，解析当前页作为图片数据 """
          return doc[page].getPixmap(matrix=trans, alpha=False)
      def pdf_to_jpg(self, width=1024, height=1400):
          """ 将pdf格式图片，转化为jpg格式 """
          doc = self.open_pdf(self.file_path)
          save_dir = os.path.join(self.save_root)
          if not os.path.exists(save_dir):
              os.makedirs(save_dir)
          print("document", len(doc), doc.pageCount)
          for i in range(len(doc)):
              trans = self.get_trans(doc, i, width, height, rotate=0)
              try:
                  pdf = self.page2pix(doc, i, trans)
              except:
                  continue
              image = pdf.getPNGData()
              image = Image.open(io.BytesIO(image))
              print(os.path.join(
                  save_dir, os.path.basename(self.file_path).replace('.pdf', '') + '_' + str(i + 1) + '.jpg'))
              image.save(
                  os.path.join(save_dir, os.path.basename(self.file_path).replace('.pdf', '') + '_' + str(i + 1) + '.jpg'))
          return
  def recognize_general_text_request():
      try:
          request = RecognizeGeneralTextRequest()
          request.body = GeneralTextRequestBody(
              image=image_base64
          response = client.recognize_general_text(request)
          print(response)
          print(e.request_id)
          print(e.error_code)
          print(e.error_msg)
  def get_client():
          .build()
  def url_to_base64(imagepath):
      return base64_data
      # 填写访问密钥AK、SK
      ak = "填写AK"
      sk = "填写SK"
      # Init Auth Info
      # Create OcrClient
      df_path = r"本地pdf文件路径，例如D:\local\test.pdf"
      save_path = r"转换后的图片路径，例如D:\local"
      covert_pdf_to_jpg = CovertPdfToJpg(df_path, save_path)
      covert_pdf_to_jpg.pdf_to_jpg()
      jpgs = glob(os.path.join(save_path, "*.jpg"))
      for jpg in jpgs:
          image_base64 = url_to_base64(jpg)
  ![](https://support.huaweicloud.com/usermanual-ocr/public_sys-resources/note_3.0-zh-cn.png)
  如果运行过程出现"AttributeError: 'Document' object has no attribute 'pageCount'"报错，可以卸载原有的**PyMuPDF**依赖包，并安装1.18.0版本解决。
