接口介绍
功能介绍
硬盘异常检测定时异步查询推理数据接口,调用接口查询当天或历史的推理结果。
URI
在平台首页创建的硬盘异常检测任务界面,查看“API调用”页签中的URI地址。
URI格式示例,如下所示:
https://telcloud.huawei.com/TrainConsoleService/apigw/inference/v1.0/{uuid}?appid={appid}
请求消息头
通过指定请求头中“X-Auth-Token”字段的token值来完成鉴权。token值的获取,请参见获取请求认证。
headers = {
"X-Auth-Token": "",
"Content-Type": "application/json",
响应
成功响应的样例,如下所示:
//返回成功 { "ret_code": 0, "isSuccess": true, "ret_data": [ { "disk_sn": "diskE", "failure": 1, "probability": 0.98, "threshold": 0, "reason": null }, { "disk_sn": "diskF", "failure": 1, "probability": 0.78, "threshold": 0, "reason": null }, { "disk_sn": "diskD", "failure": 1, "probability": 0.68, "threshold": 0, "reason": null } ] } //返回失败 { "error_message": "Failed to query the prediction result. Check the task ID and time", "ret_code":1, "isSuccess": false }
