更新时间:2021-09-18 GMT+08:00
Java代码样例
Java代码样例,如下所示:
package main.java.com.huawei.softcom.ai.dfp;
import java.security.cert.CertificateException;
import java.security.cert.X509Certificate;
import javax.net.ssl.SSLContext;
import javax.net.ssl.TrustManager;
import javax.net.ssl.X509TrustManager;
import org.apache.http.HttpEntity;
import org.apache.http.HttpResponse;
import org.apache.http.client.HttpClient;
import org.apache.http.client.methods.HttpPost;
import org.apache.http.conn.ClientConnectionManager;
import org.apache.http.conn.scheme.Scheme;
import org.apache.http.conn.scheme.SchemeRegistry;
import org.apache.http.conn.ssl.SSLSocketFactory;
import org.apache.http.entity.StringEntity;
import org.apache.http.impl.client.DefaultHttpClient;
import org.apache.http.util.EntityUtils;
 * 利用HttpClient进行post请求的工具类
 * @ClassName: HttpClientUtil
 * @Description:用户需要填写userName,passWord,taskId,url,data的值
@SuppressWarnings("deprecation")
public class DiskPredictClient {
    private static String userName = "xxxxxx";
    private static String passWord = "xxxxxx";
    private static String taskId = "0";
    private static String url = "xxxxxx";
    private static String data = "[{\r\n" +
		"	\"disk_capacity\": \"820.6184120178223\",\r\n" +
		"	\"disk_media_type\": \"HDD\",\r\n" +
		"	\"disk_production\": \"6800V3\",\r\n" +
		"	\"disk_data_source\": \"huawei\",\r\n" +
		"	\"disk_pot\": \"31615\",\r\n" +
		"	\"disk_collect_time\": \"20191205022933\",\r\n" +
		"	\"disk_sn\": \"disk_001\",\r\n" +
		"	\"device_sn\": \"device_001\",\r\n" +
		"	\"disk_errorcount_nonmedium_ec\": \"0\",\r\n" +
		"	\"disk_slow_type\": null,\r\n" +
		"	\"disk_firmware_version\": \"A440\",\r\n" +
		"	\"disk_slot\": \"8\",\r\n" +
		"	\"disk_manufacturer\": \"HITACHI\",\r\n" +
		"	\"disk_model\": \"HUC109090CSS600\",\r\n" +
		"	\"disk_failure_status\": \"0\",\r\n" +
		"	\"disk_selftest_failure_count\": \"0\",\r\n" +
		"	\"disk_glist_count\": \"0\",\r\n" +
		"	\"disk_bms_count\": \"0\",\r\n" +
		"	\"disk_temperature_current\": \"30\",\r\n" +
		"	\"disk_temperature_reference\": \"85\",\r\n" +
		"	\"r_ecsd\": \"0\",\r\n" +
		"	\"r_ecpd\": \"0\",\r\n" +
		"	\"r_operations\": \"0\",\r\n" +
		"	\"r_ec\": \"0\",\r\n" +
		"	\"r_times\": \"1019321\",\r\n" +
		"	\"r_processed\": \"8443956112248\",\r\n" +
		"	\"r_uce\": \"0\",\r\n" +
		"	\"w_ecsd\": \"0\",\r\n" +
		"	\"w_ecpd\": \"0\",\r\n" +
		"	\"w_operations\": \"0\",\r\n" +
		"	\"w_ec\": \"0\",\r\n" +
		"	\"w_times\": \"158125\",\r\n" +
		"	\"w_processed\": \"10701100018960\",\r\n" +
		"	\"w_uce\": \"0\",\r\n" +
		"	\"v_ecsd\": \"0\",\r\n" +
		"	\"v_ecpd\": \"8\",\r\n" +
		"	\"v_operations\": \"0\",\r\n" +
		"	\"v_ec\": \"8\",\r\n" +
		"	\"v_times\": \"1904211\",\r\n" +
		"	\"v_processed\": \"99871936124480\",\r\n" +
		"	\"v_uce\": \"0\",\r\n" +
		"	\"disk_ie_asc\": \"0\",\r\n" +
		"	\"disk_ie_ascq\": \"0\",\r\n" +
		"	\"disk_dha_logic_status\": null,\r\n" +
		"	\"disk_dha_link_status\": null,\r\n" +
		"	\"slow_type\": null,\r\n" +
		"	\"m_ip\": \"10.128.241.145\",\r\n" +
		"	\"created_dt\": \"2019-12-06T04: 13: 44\",\r\n" +
		"	\"dha_log\": [],\r\n" +
		"	\"interfacetype\": \"SAS\"\r\n" +
    class SSLClient extends DefaultHttpClient {
        public SSLClient() throws Exception{
            super();
            SSLContext ctx = SSLContext.getInstance("TLS");
            X509TrustManager tm = new X509TrustManager() {
                    @Override
                    public void checkClientTrusted(X509Certificate[] chain,
                            String authType) throws CertificateException {
                    @Override
                    public void checkServerTrusted(X509Certificate[] chain,
                    @Override
                    public X509Certificate[] getAcceptedIssuers() {
                        return null;
            ctx.init(null, new TrustManager[]{tm}, null);
            SSLSocketFactory ssf = new SSLSocketFactory(ctx,SSLSocketFactory.ALLOW_ALL_HOSTNAME_VERIFIER);
            ClientConnectionManager ccm = this.getConnectionManager();
            SchemeRegistry sr = ccm.getSchemeRegistry();
            sr.register(new Scheme("https", 443, ssf));
    @SuppressWarnings("resource")
    public String doPost(String url,String jsonstr,String charset){
        HttpClient httpClient = null;
        HttpPost httpPost = null;
        String result = null;
        try{
            httpClient = new SSLClient();
            httpPost = new HttpPost(url);
            httpPost.addHeader("Content-Type", "application/json");
            httpPost.addHeader("Authorization", userName + ":" + passWord);
            httpPost.addHeader("X-ACCESS-ADDRESS", "/diskCheck/v1.0/diskCheck-impl/pythonServer");
            StringEntity se = new StringEntity(jsonstr);
            se.setContentType("application/json");
            httpPost.setEntity(se);
            HttpResponse response = httpClient.execute(httpPost);
            if(response != null){
                HttpEntity resEntity = response.getEntity();
                if(resEntity != null){
                    result = EntityUtils.toString(resEntity,charset);
        }catch(Exception ex){
            ex.printStackTrace();
        return result;
public static void main(String[] args){
        String request_data = "{\r\n" +
		"		\"taskId\":" + taskId + ",\r\n" +
		"		\"userId\":" + '"'+ userName  + '"'+ ",\r\n" +
		"		\"data\":" + data + "\r\n" +
        String httpOrgCreateTestRtn = new DiskPredictClient().doPost(url, request_data, "utf-8");
        System.out.println(httpOrgCreateTestRtn);
分享:
    相关产品
关闭导读
