更新时间:2021-09-18 GMT+08:00
Java代码样例
Java代码样例,如下所示:
package main.java.com.huawei.softcom.ai.dfp; import java.security.cert.CertificateException; import java.security.cert.X509Certificate; import javax.net.ssl.SSLContext; import javax.net.ssl.TrustManager; import javax.net.ssl.X509TrustManager; import org.apache.http.HttpEntity; import org.apache.http.HttpResponse; import org.apache.http.client.HttpClient; import org.apache.http.client.methods.HttpPost; import org.apache.http.conn.ClientConnectionManager; import org.apache.http.conn.scheme.Scheme; import org.apache.http.conn.scheme.SchemeRegistry; import org.apache.http.conn.ssl.SSLSocketFactory; import org.apache.http.entity.StringEntity; import org.apache.http.impl.client.DefaultHttpClient; import org.apache.http.util.EntityUtils; /** * 利用HttpClient进行post请求的工具类 * @ClassName: HttpClientUtil * @Description:用户需要填写userName,passWord,taskId,url,data的值 * */ @SuppressWarnings("deprecation") public class DiskPredictClient { private static String userName = "xxxxxx"; private static String X-Auth-Token= "xxxxxx"; private static String taskId = "xxxx"; private static String url = "xxxxx", private static String data = "[{\r\n" + " \"diskSn\": \"test\",\r\n" + " \"predictDate\": \"20200112\",\r\n" + " \"predictResult\": \"correct\",\r\n" + " \"predictDesc\": \"test\"\r\n" + " \"},\r\n" + " \"{\r\n" + " \"diskSn\": \"test2\",\r\n" + " \"predictDate\": \"20200112\",\r\n" + " \"predictResult\": \"correct\",\r\n" + " \"predictDesc\": \"test\"\r\n" + " \"}]"; @SuppressWarnings("deprecation") class SSLClient extends DefaultHttpClient { public SSLClient() throws Exception{ super(); SSLContext ctx = SSLContext.getInstance("TLS"); X509TrustManager tm = new X509TrustManager() { @Override public void checkClientTrusted(X509Certificate[] chain, String authType) throws CertificateException { } @Override public void checkServerTrusted(X509Certificate[] chain, String authType) throws CertificateException { } @Override public X509Certificate[] getAcceptedIssuers() { return null; } }; ctx.init(null, new TrustManager[]{tm}, null); SSLSocketFactory ssf = new SSLSocketFactory(ctx,SSLSocketFactory.ALLOW_ALL_HOSTNAME_VERIFIER); ClientConnectionManager ccm = this.getConnectionManager(); SchemeRegistry sr = ccm.getSchemeRegistry(); sr.register(new Scheme("https", 443, ssf)); } } @SuppressWarnings("resource") public String doPost(String url,String jsonstr,String charset){ HttpClient httpClient = null; HttpPost httpPost = null; String result = null; try{ httpClient = new SSLClient(); httpPost = new HttpPost(url); httpPost.addHeader("Content-Type", "application/json"); StringEntity se = new StringEntity(jsonstr); se.setContentType("application/json"); httpPost.setEntity(se); HttpResponse response = httpClient.execute(httpPost); if(response != null){ HttpEntity resEntity = response.getEntity(); if(resEntity != null){ result = EntityUtils.toString(resEntity,charset); } } }catch(Exception ex){ ex.printStackTrace(); } return result; } public static void main(String[] args){ String request_data = "{\r\n" + " \"taskId\":" + taskId + ",\r\n" + " \"userId\":" + '"'+ userName + '"'+ ",\r\n" + " \"datas\":" + data + "\r\n" + " }"; String httpOrgCreateTestRtn = new DiskPredictClient().doPost(url, request_data, "utf-8"); System.out.println(httpOrgCreateTestRtn); } }
父主题: 硬盘故障预测反馈接口
