# NGINX仪表盘模板
日志服务支持采集NGINX日志，并进行多维度分析。云日志服务支持日志采集向导一站式采集NGINX日志，并为NGINX日志配置结构化和仪表盘。Nginx (engine x) 是一个高性能的HTTP和反向代理web服务器，同时也提供了IMAP/POP3/SMTP服务。
NGINX仪表盘模板支持[查看NGINX秒级监控]、[查看NGINX访问中心]和[查看NGINX监控中心]。
- 已采集NGINX日志。
- 日志配置结构化，详情请参见[设置云端结构化解析日志](https://support.huaweicloud.com/usermanual-lts/lts_07_0079.html)。
 #### 查看NGINX秒级监控
1. 登录[云日志服务控制台](https://console.huaweicloud.com/lts/?#/cts/manager/groups)，进入"日志管理"页面。
2. 在左侧导航栏中选择"仪表盘"。
3. 在仪表盘模板下方，选择"NGINX仪表盘模板 \> NGINX秒级监控"，查看图表详情。
   图1NGINX秒级监控
   ![](https://support.huaweicloud.com/usermanual-lts/zh-cn_image_0000002530148835.png "点击放大")
   - **QPS** 图表所关联的查询分析语句如下所示：
     * | SELECT TIME_FORMAT(TIME_CEIL(__time,'PT1S'),'yyyy-MM-dd HH:mm:ss','+08:00') AS _time_ , COUNT(*) as QPS from log group by _time_
   - **成功率** 图表所关联的查询分析语句如下所示：
     * | SELECT __time,round(CASE WHEN "成功率" > 0 THEN "成功率" else 0 end,2) as "成功率" from (select TIME_FORMAT(TIME_CEIL(__time,'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time, sum(case when status < 400 then 1 else 0 end) * 100.0 / count(1) as '成功率' from log group by __time)
   - **延迟** 图表所关联的查询分析语句如下所示：
     * | SELECT __time,round(CASE WHEN "访问延迟" > 0 THEN "访问延迟" else 0 end,2) as "访问延迟",round(CASE WHEN "Upstream延迟" > 0 THEN "Upstream延迟" else 0 end,2) as "Upstream延迟" from (select TIME_FORMAT(TIME_CEIL(__time,'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time, avg(request_time)* 1000 as '访问延迟',avg(upstream_response_time)* 1000 as 'Upstream延迟' from log group by __time)
   - **流量** 图表所关联的查询分析语句如下所示：
     * | SELECT TIME_FORMAT(TIME_CEIL(__time,'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time , sum("request_length") as "请求流量", sum("body_bytes_sent") as "返回body流量" group by __time
   - **状态码** 图表所关联的查询分析语句如下所示：
     * | SELECT t.t as "time",
           CASE WHEN a."2XX" IS NOT NULL THEN  CAST(a."2XX" AS BIGINT) ELSE 0 END as "2XX",
           CASE WHEN b."3XX" IS NOT NULL THEN  CAST(b."3XX" AS BIGINT) ELSE 0 END as "3XX",
           CASE WHEN c."4XX" IS NOT NULL THEN  CAST(c."4XX" AS BIGINT) ELSE 0 END as "4XX",
           CASE WHEN d."5XX" IS NOT NULL THEN  CAST(d."5XX" AS BIGINT) ELSE 0 END as "5XX",
           CASE WHEN e."其他" IS NOT NULL THEN  CAST(e."其他" AS BIGINT)  ELSE 0 END as "其他"
           from (select TIME_CEIL(__time,'PT5S') as t from log group by t order by t asc  ) t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "2XX" from log WHERE "status" >= 200 and "status" < 300 group by t order by t asc ) a on t.t =a.t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "3XX" from log WHERE "status" >= 300 and "status" < 400 group by t order by t asc) b on t.t =b.t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "4XX" from log WHERE "status" >= 400 and "status" < 500 group by t order by t asc) c on t.t =c.t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "5XX" from log WHERE "status" >= 500 and "status" < 600 group by t order by t asc) d on t.t =d.t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "其他" from log WHERE "status" < 200 or "status" >= 600 group by t order by t asc) e on t.t =e.t
   - **后端响应码** 图表所关联的查询分析语句如下所示：
           from (
           SELECT TIME_CEIL(__time,'PT5S') as t from log group by t order by t asc
           ) t
           left join(
           SELECT TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "2XX" from log WHERE "upstream_status" >= 200 and "upstream_status" < 300 group by t order by t asc) a
           on t.t = a.t
           left join (
           SELECT TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "3XX" from log WHERE "upstream_status" >= 300 and "upstream_status" < 400 group by t order by t asc) b
           on t.t =b.t
           left join (
           SELECT TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "4XX" from log WHERE "upstream_status" >= 400 and "upstream_status" < 500 group by t order by t asc) c
           on t.t =c.t
           left join (
           SELECT TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "5XX" from log WHERE "upstream_status" >= 500 and "upstream_status" < 600 group by t order by t asc) d
           on t.t =d.t
           left join (
           SELECT TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "其他" from log WHERE "upstream_status" < 200 or "upstream_status" >= 600 group by t order by t asc) e
           on t.t =e.t
 #### 查看NGINX访问中心
1. 在仪表盘模板下方，选择"NGINX仪表盘模板 \> NGINX访问中心"，查看图表详情。
   图2NGINX访问中心
   ![](https://support.huaweicloud.com/usermanual-lts/zh-cn_image_0000002530308821.png "点击放大")
   - **PV对比昨日** 图表所关联的查询分析语句如下所示：
     * | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "pv" , 86400) as diff from (select count(1) as "pv" from log))
   - **PV对比上周** 图表所关联的查询分析语句如下所示：
     * | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "pv" , 604800) as diff from (select count(1) as "pv" from log))
   - **UV对比昨日** 图表所关联的查询分析语句如下所示：
     * | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "uv" , 86400) as diff from (select APPROX_COUNT_DISTINCT(remote_addr) as "uv" from log))
   - **UV对比上周** 图表所关联的查询分析语句如下所示：
     * | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "uv" , 604800) as diff from (select APPROX_COUNT_DISTINCT(remote_addr) as "uv" from log))
   - **访问量PV分布(中国)** 图表所关联的查询分析语句如下所示：
     * | SELECT ip_to_province(remote_addr) as province, count(1) as pv where IP_TO_COUNTRY (remote_addr) = '中国'  group by province HAVING province not in ('','保留地址','*')
   - **访问量PV分布(世界)** 图表所关联的查询分析语句如下所示：
     * | SELECT ip_to_country(remote_addr) as country,COUNT(1) as PV GROUP BY country HAVING country not in ('','保留地址','*')
   - **访问量UV分布(中国)** 图表所关联的查询分析语句如下所示：
     * | SELECT ip_to_province(remote_addr) as province, APPROX_COUNT_DISTINCT(remote_addr) as UV where IP_TO_COUNTRY (remote_addr) = '中国'   group by province HAVING province not in ('','保留地址','*')
   - **访问量UV分布(世界)** 图表所关联的查询分析语句如下所示：
     * | SELECT ip_to_country(remote_addr) as country, APPROX_COUNT_DISTINCT(remote_addr) as uv group by country HAVING country not in ('','保留地址','*')
   - **平均时延分布（中国）** 图表所关联的查询分析语句如下所示：
     * | SELECT province,round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)"FROM (SELECT ip_to_province(remote_addr) as province,avg(request_time) * 1000 AS "平均延迟(ms)"WHERE  IP_TO_COUNTRY (remote_addr) = '中国'GROUP BY province HAVING province not in ('','保留地址','*'))
   - **平均时延分布（世界）** 图表所关联的查询分析语句如下所示：
     * | SELECT country,round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 2 ) AS "平均延迟(ms)"FROM (SELECT ip_to_country(remote_addr) as country,avg(request_time) * 1000 AS "平均延迟(ms)" GROUP BY country HAVING country not in ('','保留地址','*'))
   - **今日PV/UV** 图表所关联的查询分析语句如下所示：
     * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,PV,UV FROM (select TIME_CEIL(__time,'PT600S') AS _time_ , count(1) as PV,  APPROX_COUNT_DISTINCT(remote_addr) as UV from log WHERE __time <= CURRENT_TIMESTAMP  and __time >= DATE_TRUNC( 'DAY',(CURRENT_TIMESTAMP + INTERVAL '8' HOUR)) - INTERVAL '8' HOUR group by _time_ order by _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
   - **7日PV/UV** 图表所关联的查询分析语句如下所示：
     * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,PV,UV FROM (select  TIME_CEIL(__time,'PT600S') AS _time_ , count(1) as PV,  APPROX_COUNT_DISTINCT(remote_addr) as UV from log WHERE __time <= CURRENT_TIMESTAMP  and __time >= DATE_TRUNC( 'DAY',(CURRENT_TIMESTAMP + INTERVAL '8' HOUR)) - INTERVAL '8' HOUR - INTERVAL '7' DAY group by _time_ order by _time_ ) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
   - **区域访问TOP10(省份)** 图表所关联的查询分析语句如下所示：
     * | SELECT ip_to_province(remote_addr) as "province", count(1) as "访问次数" group by "province" HAVING "province" <> '-1' order by "访问次数" asc limit 10
   - **区域访问TOP10(城市)** 图表所关联的查询分析语句如下所示：
     * | SELECT ip_to_city(remote_addr) as "city", count(1) as "访问次数" group by "city" HAVING  "city" <> '-1' order by "访问次数" asc  limit 10
   - **Host访问TOP10** 图表所关联的查询分析语句如下所示：
     * | SELECT  host as "Host", count(1) as "PV" group by "Host" order by "PV" asc limit 10
   - **UserAgent访问TOP10** 图表所关联的查询分析语句如下所示：
     * | SELECT http_user_agent as "UserAgent", count(1) as "PV" group by "UserAgent" order by "PV" asc limit 10
   - **设备占比(终端)** 图表所关联的查询分析语句如下所示：
     * | SELECT case when regexp_like(lower(http_user_agent), 'iphone|ipod|android|ios') then '移动端' else 'PC端' end as type , count(1) as total group by  type
   - **设备占比(系统)** 图表所关联的查询分析语句如下所示：
     * | SELECT case when regexp_like(lower(http_user_agent), 'iphone|ipod|ios') then 'IOS' when regexp_like(lower(http_user_agent), 'android') then 'Android' else 'other' end as type , count(1) as total group by  type HAVING type != 'other'
   - **TOP URL** 图表所关联的查询分析语句如下所示：
     * | SELECT request_uri , count(1) as PV, APPROX_COUNT_DISTINCT(remote_addr) as UV, round(sum( case when status < 400 then 1 else 0 end ) * 100.0 / count(1), 2) as "访问成功率" group by request_uri ORDER by PV desc
   - **TOP 访问IP** 图表所关联的查询分析语句如下所示：
     * | SELECT remote_addr as "来源IP",ip_to_country(remote_addr) as "国家",ip_to_province(remote_addr) as "省份",ip_to_city(remote_addr) as "城市",ip_to_provider(remote_addr) as "运营商",count(1) as "PV",http_user_agent as "UserAgent采样",request_uri as "URL采样" group by remote_addr,http_user_agent,request_uri ORDER by "PV" desc
 #### 查看NGINX监控中心
1. 在仪表盘模板下方，选择"NGINX仪表盘模板 \> NGINX监控中心"，查看图表详情。
   图3NGINX监控中心
   ![](https://support.huaweicloud.com/usermanual-lts/zh-cn_image_0000002498388888.png "点击放大")
   - **访问量PV** 图表所关联的查询分析语句如下所示：
     * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,PV FROM ( SELECT TIME_CEIL ( __time, 'PT300S' ) AS _time_, count( 1 ) AS PV FROM log GROUP BY _time_ )  WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
   - **请求成功率** 图表所关联的查询分析语句如下所示：
     * | SELECT ROUND(sum(case when status < 400 then 1 else 0 end) * 100.0 / count(1),2) as cnt
   - **平均延迟** 图表所关联的查询分析语句如下所示：
     * | SELECT round(avg(request_time) * 1000, 3) as cnt
   - **4XX请求数** 图表所关联的查询分析语句如下所示：
     * | SELECT COUNT(1) as cnt WHERE "status" >= 400 and "status" < 500
   - **404请求数** 图表所关联的查询分析语句如下所示：
     * | SELECT COUNT(1) as cnt WHERE "status" = 404
   - **429请求数** 图表所关联的查询分析语句如下所示：
     * | SELECT COUNT(1) as cnt WHERE "status" = 429
   - **504请求数** 图表所关联的查询分析语句如下所示：
     * | SELECT COUNT(1) as cnt WHERE "status" = 504
   - **5XX请求数** 图表所关联的查询分析语句如下所示：
     * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,cnt FROM ( SELECT TIME_CEIL ( __time, 'PT300S' ) AS _time_, count( 1 ) AS cnt FROM log where "status" >= 500 GROUP BY _time_ )  WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
   - **状态码分布** 图表所关联的查询分析语句如下所示：
     * | SELECT status, COUNT(1) AS rm GROUP BY status
   - **访问量UV** 图表所关联的查询分析语句如下所示：
     * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,UV FROM (select TIME_CEIL(__time,'PT600S') AS _time_ , APPROX_COUNT_DISTINCT(remote_addr) as UV  from log group by _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
     * | SELECT TIME_FORMAT(_time_,'yyyy-MM-dd HH:mm:ss','+08:00') AS _time_,round( CASE WHEN "入流量" > 0 THEN "入流量" ELSE 0 END, 2 ) AS "入流量",round( CASE WHEN "出流量" > 0 THEN "出流量" ELSE 0 END, 2 ) AS "出流量" FROM (SELECT TIME_CEIL(__time,'PT600S') AS _time_,sum(request_length) / 1024.0 AS "入流量",sum(bytes_sent) / 1024.0 AS "出流量" group by  _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
   - **访问失败率** 图表所关联的查询分析语句如下所示：
     * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,round( CASE WHEN "失败率" > 0 THEN "失败率" ELSE 0 END, 2 ) AS "失败率",round( CASE WHEN "5XX比例" > 0 THEN "5XX比例" ELSE 0 END, 2 ) AS "5XX比例" from (select TIME_CEIL(__time,'PT600S') AS _time_,sum(case when status >= 400 then 1 else 0 end) * 100.0 / count(1) as '失败率' , sum(case when status >=500 THEN 1 ELSE 0 END)*100.0/COUNT(1) as '5XX比例' group by  _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
     * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,round( CASE WHEN "平均" > 0 THEN "平均" ELSE 0 END, 2 ) AS "平均",round( CASE WHEN "P50" > 0 THEN "P50" ELSE 0 END, 2 ) AS "P50",round( CASE WHEN "P90" > 0 THEN "P90" ELSE 0 END, 2 ) AS "P90",round( CASE WHEN "P99" > 0 THEN "P99" ELSE 0 END, 2 ) AS "P99",round( CASE WHEN "P9999" > 0 THEN "P9999" ELSE 0 END, 2 ) AS "P9999" from (select TIME_CEIL(__time,'PT600S') as _time_,avg(request_time) * 1000 as "平均", APPROX_QUANTILE_DS("request_time", 0.50)*1000 as "P50", APPROX_QUANTILE_DS("request_time", 0.90)*1000 as "P90" ,APPROX_QUANTILE_DS("request_time", 0.99)*1000 as 'P99',APPROX_QUANTILE_DS("request_time", 0.9999)*1000 as 'P9999' group by  _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
   - **Host请求TOP** 图表所关联的查询分析语句如下所示：
     * | SELECT "host", pv, uv, round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "入流量(KB)" > 0 THEN "入流量(KB)" ELSE 0 END, 3 ) AS "入流量(KB)", round( CASE WHEN "出流量(KB)" > 0 THEN "出流量(KB)" ELSE 0 END, 3 ) AS "出流量(KB)"  FROM ( SELECT "host", count( 1 ) AS pv, APPROX_COUNT_DISTINCT ( remote_addr ) AS uv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", sum( request_length ) / 1024.0 AS "入流量(KB)", sum( bytes_sent ) / 1024.0 AS "出流量(KB)"  WHERE "host" != ''  GROUP BY "host" ) ORDER BY pv DESC
   - **Host延迟TOP** 图表所关联的查询分析语句如下所示：
     * | SELECT "host", pv, round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)", round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM ( SELECT "host", count( 1 ) AS pv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)",APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "host" != ''  GROUP BY "host" ) ORDER BY "平均延迟(ms)" desc
   - **Host失败率TOP** 图表所关联的查询分析语句如下所示：
     * | SELECT "host", pv,round( CASE WHEN "访问失败率(%)" > 0 THEN "访问失败率(%)" ELSE 0 END, 2 ) AS "访问失败率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)", round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)"  FROM ( SELECT "host", count( 1 ) AS pv, sum( CASE WHEN "status" >= 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问失败率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "host" != ''  GROUP BY "host"  ) ORDER BY "访问失败率(%)" desc
   - **URL请求TOP** 图表所关联的查询分析语句如下所示：
     * | SELECT request_uri, pv,uv, round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "入流量(KB)" > 0 THEN "入流量(KB)" ELSE 0 END, 3 ) AS "入流量(KB)", round( CASE WHEN "出流量(KB)" > 0 THEN "出流量(KB)" ELSE 0 END, 3 ) AS "出流量(KB)"  FROM ( SELECT request_uri, count( 1 ) AS pv, APPROX_COUNT_DISTINCT ( remote_addr ) AS uv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", sum( request_length ) / 1024.0 AS "入流量(KB)", sum( bytes_sent ) / 1024.0 AS "出流量(KB)"  WHERE "host" != ''  GROUP BY request_uri  ) ORDER BY pv desc
   - **URL延迟TOP** 图表所关联的查询分析语句如下所示：
     * | SELECT request_uri, pv,round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)",round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)",round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)",round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM (SELECT request_uri, count( 1 ) AS pv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "host" != ''  GROUP BY request_uri  ) ORDER BY "平均延迟(ms)" desc
   - **URL失败率TOP** 图表所关联的查询分析语句如下所示：
     * | SELECT request_uri, pv, round( CASE WHEN "访问失败率(%)" > 0 THEN "访问失败率(%)" ELSE 0 END, 2 ) AS "访问失败率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)",round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)", round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM( SELECT request_uri, count( 1 ) AS pv, sum( CASE WHEN "status" >= 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问失败率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "host" != '' GROUP BY request_uri  )ORDER BY "访问失败率(%)" desc
   - **后端请求TOP** 图表所关联的查询分析语句如下所示：
     * | SELECT addr,pv,round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)",round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)",round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)",round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM (SELECT upstream_addr as addr,count( 1 ) AS pv,sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)",avg( request_time ) * 1000 AS "平均延迟(ms)",APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)",APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "host" != '' GROUP BY addr having length(upstream_addr) > 2) ORDER BY "平均延迟(ms)" desc
   - **后端延迟TOP** 图表所关联的查询分析语句如下所示：
     * | SELECT addr, pv, uv, round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "入流量(KB)" > 0 THEN "入流量(KB)" ELSE 0 END, 3 ) AS "入流量(KB)", round( CASE WHEN "出流量(KB)" > 0 THEN "出流量(KB)" ELSE 0 END, 3 ) AS "出流量(KB)"  FROM ( SELECT upstream_addr as addr, count( 1 ) AS pv, APPROX_COUNT_DISTINCT ( remote_addr ) AS uv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", sum( request_length ) / 1024.0 AS "入流量(KB)", sum( bytes_sent ) / 1024.0 AS "出流量(KB)"  WHERE "host" != ''  GROUP BY addr  having length(upstream_addr) > 2) ORDER BY "pv" desc
   - **后端失败率TOP** 图表所关联的查询分析语句如下所示：
     * | SELECT addr, pv, round( CASE WHEN "访问失败率(%)" > 0 THEN "访问失败率(%)" ELSE 0 END, 2 ) AS "访问失败率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)", round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)"  FROM ( SELECT upstream_addr as addr, count( 1 ) AS pv, sum( CASE WHEN "status" >= 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问失败率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "host" != ''  GROUP BY addr having length(upstream_addr) > 2)ORDER BY "访问失败率(%)" desc
