# ER仪表盘模板
企业路由器（Enterprise Router, ER）可以连接虚拟私有云（Virtual Private Cloud, VPC）或本地网络来构建中心辐射型组网，是云上大规格、高带宽、高性能的集中路由器。企业路由器使用边界网关协议（Border Gateway Protocol, BGP），支持路由学习、动态选路以及链路切换，极大的提升网络的可扩展性及运维效率，从而保证业务的连续性。
云日志服务支持日志采集向导一站式采集ER日志，支持多维度分析，并为ER日志配置结构化和仪表盘。该仪表盘主要展示ER日志的TOP20包数统计、TOP20流量统计、流日志条数等信息。
- 已采集ER流量日志，详情请参见[企业路由器ER接入LTS](https://support.huaweicloud.com/usermanual-lts/lts_07_0040.html)。
- 日志配置结构化，详情请参见[设置云端结构化解析日志](https://support.huaweicloud.com/usermanual-lts/lts_07_0079.html)。
#### ER流量日志中心
1. 登录[云日志服务控制台](https://console.huaweicloud.com/lts/?#/cts/manager/groups)，进入"日志管理"页面。
2. 在左侧导航栏中选择"仪表盘"。
3. 在仪表盘模板下方，选择"ER仪表盘模板 \> ER流量日志中心"，查看图表详情。
   图1ER流量日志中心
   ![](https://support.huaweicloud.com/usermanual-lts/zh-cn_image_0000002530139887.png "点击放大")
   - 过滤实例ID图，所关联的查询分析语句如下所示：
     * | SELECT DISTINCT(instance_id)
   - 过滤连接ID图，所关联的查询分析语句如下所示：
     * | SELECT DISTINCT(resource_id)
   - 流量方向图展示为静态过滤器，可按照入方向和出方向的流量进行过滤。
   - 过滤源IP图，所关联的查询分析语句如下所示：
     * | SELECT DISTINCT(srcaddr)
   - 过滤目的IP图，所关联的查询分析语句如下所示：
     * | SELECT DISTINCT(dstaddr)
   - 过滤协议类型图，所关联的查询分析语句如下所示：
     * | SELECT DISTINCT(protocol)
   - **TOP20包数统计** 图表所关联的查询分析语句如下所示：
     * | SELECT "srcaddr" as "源地址", "dstaddr" as "目的地址",  sum("packets") as "包数", "resource_id" as "连接ID", "instance_id" as "实例ID" group by "instance_id", "resource_id", "srcaddr", "dstaddr" order by "包数" desc limit 20
   - **TOP20流量统计** 图表所关联的查询分析语句如下所示：
     * | SELECT "srcaddr" as "源地址", "dstaddr" as "目的地址",  sum("bytes") as "字节数", "resource_id" as "连接ID", "instance_id" as "实例ID" group by "instance_id", "resource_id", "srcaddr", "dstaddr" order by "字节数" desc limit 20
   - **流日志条数** 图表所关联的查询分析语句如下所示：
     * | SELECT time_series(__time, 'PT1H', 'yyyy-MM-dd HH:mm:ss', '0', '+08:00') as "时间", count(*) as "流日志条数" group by "时间" order by "时间"
   - **流日志详情** 图表所关联的查询分析语句如下所示：
     * | SELECT "instance_id" as "实例ID", "resource_id" as "连接ID", "project_id" as "项目ID", "srcaddr" as "源IP", "dstaddr" as "目的IP", "srcport" as "源端口",  "dstport" as "目的端口", "protocol" as "协议类型", "direct" as "流量方向", "packets" as "包数", "bytes" as "字节数",  TIME_FORMAT( MILLIS_TO_TIMESTAMP("start"*1000), 'yyyy-MM-dd HH:mm:ss', '+08:00') as "开始时间", TIME_FORMAT( MILLIS_TO_TIMESTAMP("end"*1000) , 'yyyy-MM-dd HH:mm:ss', '+08:00') as "结束时间"
