# WAF仪表盘模板
Web应用防火墙（Web Application Firewall，WAF），通过对HTTP(S)请求进行检测，识别并阻断SQL注入、跨站脚本攻击、网页木马上传、命令/代码注入、文件包含、敏感文件访问、第三方应用漏洞攻击、CC攻击、恶意爬虫扫描、跨站请求伪造等攻击，保护Web服务安全稳定。
WAF仪表盘模板支持[查看WAF安全日志中心]和[查看WAF访问日志中心]。
- 已采集WAF日志，详情请参考[Web应用防火墙WAF接入LTS](https://support.huaweicloud.com/usermanual-lts/lts_04_0405.html)。
- 日志配置结构化，详情请参见[设置云端结构化解析日志](https://support.huaweicloud.com/usermanual-lts/lts_07_0079.html)。
 #### 查看WAF安全日志中心
1. 登录[云日志服务控制台](https://console.huaweicloud.com/lts/?#/cts/manager/groups)，进入"日志管理"页面。
2. 在左侧导航栏中选择"仪表盘"。
3. 在仪表盘模板下方，选择"WAF仪表盘模板 \> WAF安全日志中心"，查看图表详情。
   图1WAF安全日志中心
   ![](https://support.huaweicloud.com/usermanual-lts/zh-cn_image_0000002498549264.png "点击放大")
   - **CC攻击拦截** 图表所关联的查询分析语句如下所示：
     * | SELECT
        CASE
        WHEN
        diff [ 1 ] < 1000 THEN
        concat( cast( cast( diff [ 1 ] as DECIMAL(20,2)) AS VARCHAR ), ' 次' )
        WHEN diff [ 1 ] < 1000 * 1000 THEN
        concat( cast(cast( diff [ 1 ]/ 1000 as DECIMAL(20,2)) AS VARCHAR ), ' 千次' )
        WHEN diff [ 1 ] < 1000000000 THEN
        concat( cast( cast( diff [ 1 ]/ 1000000.0 as DECIMAL(20,2)) AS VARCHAR ), ' 百万次' )
        WHEN diff [ 1 ]/ 1000.0 < 1000000000 THEN
        concat( cast( cast( diff [ 1 ]/ 1000.0 / 1000000 as DECIMAL(20,2)) AS VARCHAR ), ' 十亿次' ) ELSE concat( cast ( cast( diff [ 1 ]/ 1000.0 / 1000 / 1000 / 1000 as DECIMAL(20,2)) AS VARCHAR ), ' 万亿次' )
        END AS
        "value"
        CASE WHEN diff [ 2 ]= 0 THEN 0 ELSE round( diff [ 3 ]- 1, 2 ) END AS ratio
        FROM
        ( SELECT compare ( "data", 86400 ) AS diff FROM ( SELECT count( 1 ) AS "data" FROM log WHERE attack != 'default') )
   - **攻击峰值** 图表所关联的查询分析语句如下所示：
     * | SELECT   diff [ 1 ] AS "VALUE",    CASE WHEN diff [ 2 ]= 0 THEN 0 ELSE round( diff [ 3 ]- 1, 2 ) END AS ratio    FROM    (    SELECT    compare ( "DATA" , 86400 ) AS diff    FROM    (    SELECT COALESCE    ( max( pv ), 0 ) AS "DATA"    FROM    ( SELECT from_unixtime(__time - __time%60000) AS dt, CEIL(count(1)/ 60.0) AS pv FROM log    WHERE action != ''    GROUP BY dt LIMIT 10000 )))
   - **攻击来源国家** 图表所关联的查询分析语句如下所示：
     * | SELECT
        diff [ 1 ] AS
        "VALUE"
        COALESCE ( diff [ 1 ]- diff [ 2 ], 0 ) AS "BEFORE"
        FROM
        SELECT
        compare ( "DATA", 86400 ) AS diff
        FROM
        ( SELECT count( DISTINCT ip_to_country ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END) ) AS "DATA" FROM log
        WHERE action != ''
   - **Web攻击拦截** 图表所关联的查询分析语句如下所示：
     * | SELECT
        CASE
        WHEN
        concat( cast( cast( diff [ 1 ]/ 1000 as DECIMAL(20,2)) AS VARCHAR ), ' 千次' )
        concat( cast( cast( diff [ 1 ]/ 1000.0 / 1000000 as DECIMAL(20,2)) AS VARCHAR ), ' 十亿次' ) ELSE concat( cast( cast( diff [ 1 ]/ 1000.0 / 1000 / 1000 / 1000 as DECIMAL(20,2)) AS VARCHAR ), ' 万亿次' )
        END AS
        "value"
        FROM
        ( SELECT compare ( "data", 86400 ) AS diff FROM ( SELECT count( 1 ) AS "data" FROM log WHERE action != '' ) )
   - **攻击者UV** 图表所关联的查询分析语句如下所示：
     * | SELECT
        CASE
        WHEN
        concat( cast( cast ( diff [ 1 ] AS INTEGER ) AS VARCHAR ), ' 个' )
        concat( cast( cast( diff [ 1 ]/ 1000 as DECIMAL(20,2)) AS VARCHAR ), ' 千个' )
        concat( cast( cast( diff [ 1 ]/ 1000000.0 as DECIMAL(20,2)) AS VARCHAR ), ' 百万个' )
        concat( cast( cast(diff [ 1 ]/ 1000.0 / 1000000 as DECIMAL(20,2)) AS VARCHAR ), ' 十亿' ) ELSE concat( cast( cast( diff [ 1 ]/ 1000.0 / 1000 / 1000 / 1000 as DECIMAL(20,2)) AS VARCHAR ), ' 万亿' )
        END AS "value",
        FROM
        SELECT
        FROM
        ( SELECT count( DISTINCT CASE WHEN sip = '-' THEN remote_ip ELSE sip END ) AS "data"
        FROM log
   - **攻击拦截** 图表所关联的查询分析语句如下所示：
     * | SELECT
        CASE
        WHEN
        concat( cast(cast( diff [ 1 ] as DECIMAL(20,2)) AS VARCHAR ), ' 次' )
        END AS
        "value",
        CASE WHEN diff [ 2 ]= 0 THEN 0 ELSE round( diff [ 3 ]- 1, 2 ) END AS "ratio"
        FROM
        SELECT
        FROM
        ( SELECT count( 1 ) AS "data" FROM log WHERE action != '')
   - **CC攻击** 图表所关联的查询分析语如下所示：
     * | SELECT
        ip_to_province (
        CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS province,
        count( 1 ) AS "攻击次数"
        GROUP BY
        province
   - **Web攻击** 图表所关联的查询分析语句如下所示：
     * | SELECT
        ip_to_province (
        WHERE action = 'block'
        GROUP BY
        province
   - **攻击类型分布** 图表所关联的查询分析语句如下所示：
     * | SELECT time_format(from_unixtime(__time - __time%60000),'yyyy-MM-dd HH:mm:ss','+08:00') AS dt, count( 1 ) AS cnt, CASE  WHEN action = 'block' THEN '拦截'  WHEN action = 'log' THEN '仅记录'  WHEN action = 'captcha' THEN '人机验证' END AS attack FROM log WHERE action != '' GROUP BY dt, attack ORDER BY dt
   - **CC攻击(世界)** 图表所关联的查询分析语句如下所示：
     * | SELECT
        ip_to_country (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS country,
        GROUP BY
        country
   - **Web攻击(世界)** 图表所关联的查询分析语句如下所示：
     * | SELECT
        GROUP BY
        country
 #### 查看WAF访问日志中心
1. 在仪表盘模板下方，选择"WAF仪表盘模板 \> WAF访问日志中心"，查看图表详情。
   图2WAF访问日志中心
   ![](https://support.huaweicloud.com/usermanual-lts/zh-cn_image_0000002498389458.png "点击放大")
   - **PV** 图表所关联的查询分析语句如下所示：
     * | SELECT       CASE               WHEN       diff [ 1 ] < 1000 THEN       concat( cast( cast(diff [ 1 ] AS DECIMAL(20,2)) AS VARCHAR ), ' 次' )        WHEN diff [ 1 ] < 1000 * 1000 THEN       concat( cast(cast( diff [ 1 ]/ 1000 AS DECIMAL(20,2)) AS VARCHAR ), ' 千次' )        WHEN diff [ 1 ] < 1000000000 THEN       concat( cast(cast(  diff [ 1 ]/ 1000000.0 AS DECIMAL(20,2)) AS VARCHAR ), ' 百万次' )        WHEN diff [ 1 ]/ 1000.0 < 1000000000 THEN       concat( cast(cast( diff [ 1 ]/ 1000 / 1000000.0 AS DECIMAL(20,2)) AS VARCHAR ), ' 十亿次' ) ELSE concat( cast(cast(  diff [ 1 ]/ 1000.0 / 1000 / 1000 / 1000 AS DECIMAL(20,2)) AS VARCHAR ), ' 万亿次' )        END AS        "VALUE"       ,       CASE WHEN diff [ 2 ]= 0 THEN 0 ELSE round(diff [ 3 ]- 1,2) END AS ratio        FROM       (       SELECT       compare ( DATA, 86400 ) AS diff        FROM       ( SELECT count( 1 ) AS DATA FROM log )        )
   - **UV** 图表所关联的查询分析语句如下所示：
     * | SELECT       CASE               WHEN       diff [ 1 ] < 1000 THEN       concat( cast( cast( diff [ 1 ] AS DECIMAL(20,2)) AS VARCHAR ), ' 次' )        WHEN diff [ 1 ] < 1000 * 1000 THEN       concat( cast( cast( diff [ 1 ]/ 1000 AS DECIMAL(20,2)) AS VARCHAR ), ' 千次' )        WHEN diff [ 1 ] < 1000000000 THEN       concat( cast( cast( diff [ 1 ]/ 1000000.0 AS DECIMAL(20,2)) AS VARCHAR ), ' 百万次' )        WHEN diff [ 1 ]/ 1000.0 < 1000000000 THEN       concat( cast( cast( diff [ 1 ]/ 1000 / 1000000.0 AS DECIMAL(20,2)) AS VARCHAR ), ' 十亿次' ) ELSE concat( cast( cast(  diff [ 1 ]/ 1000.0 / 1000 / 1000 / 1000 AS DECIMAL(20,2)) AS VARCHAR ), ' 万亿次' )        END AS        "VALUE"       ,       CASE               WHEN diff [ 2 ]= 0 THEN       0 ELSE round( diff [ 3 ]- 1, 2 )       END AS ratio        FROM       (       SELECT       compare ( DATA, 86400 ) AS diff        FROM       ( SELECT count( DISTINCT CASE WHEN sip = '-' THEN remote_ip ELSE sip END ) AS "DATA" FROM log )        )
   - **流入流量** 图表所关联的查询分析语句如下所示：
     * | SELECT       CASE               WHEN       diff [ 1 ] < 102 THEN       concat( cast( cast( diff [ 1 ] AS DECIMAL(20,2)) AS VARCHAR ), ' B' )        WHEN diff [ 1 ] < 1024 * 1024 THEN       concat( cast( cast( diff [ 1 ]/ 1024 AS DECIMAL(20,2)) AS VARCHAR ), ' KB' )        WHEN diff [ 1 ] < 1024 * 1024 * 1024 THEN       concat( cast( cast( diff [ 1 ]/ 1024.0 / 1024 AS DECIMAL(20,2)) AS VARCHAR ), ' MB' )        WHEN diff [ 1 ]/ 1024.0 < 1024 * 1024 * 1024 THEN       concat( cast( cast( diff [ 1 ]/ 1024.0 / 1024 / 1024 AS DECIMAL(20,2)) AS VARCHAR ), ' GB' ) ELSE concat( cast( cast( diff [ 1 ]/ 1024.0 / 1024 / 1024 / 1024 AS DECIMAL(20,2)) AS VARCHAR ), ' TB' )        END AS        "VALUE"       ,       CASE               WHEN diff [ 2 ]= 0 THEN       0 ELSE round( diff [ 3 ]- 1, 2 )       END AS ratio        FROM       (       SELECT       compare ( "DATA", 86400 ) AS diff        FROM       ( SELECT COALESCE ( sum( try_cast(request_length as bigint) ), 0 ) AS "DATA" FROM log )        )
   - **网络in带宽峰值** 图表所关联的查询分析语句如下所示：
     * | SELECT CASE     WHEN   diff [ 1 ] < 102 THEN    concat( cast( cast(  diff [ 1 ] AS DECIMAL(20,2)) AS VARCHAR ), ' B/s' )     WHEN diff [ 1 ] < 1024 * 1024 THEN    concat( cast( cast(  diff [ 1 ]/ 1024  AS DECIMAL(20,2)) AS VARCHAR ), ' KB/s' )     WHEN diff [ 1 ] < 1024 * 1024 * 1024 THEN    concat( cast( cast( diff [ 1 ]/ 1024.0 / 1024  AS DECIMAL(20,2)) AS VARCHAR ), ' MB/s' )     WHEN diff [ 1 ]/ 1024.0 < 1024 * 1024 * 1024 THEN    concat( cast( cast(  diff [ 1 ]/ 1024.0 / 1024 / 1024  AS DECIMAL(20,2)) AS VARCHAR ), ' GB/s' ) ELSE concat( cast( cast(  diff [ 1 ]/ 1024.0 / 1024 / 1024 / 1024  AS DECIMAL(20,2)) AS VARCHAR ), ' TB/s' )    END AS "VALUE",  CASE        WHEN diff [ 2 ]= 0 THEN    0 ELSE round( diff [ 3 ]- 1, 2 )    END AS ratio   FROM   (   SELECT    compare ( "DATA", 86400 ) AS diff    FROM    (    SELECT COALESCE     ( max( "DATA" ), 0 ) AS "DATA"     FROM     (     SELECT time_format(from_unixtime(__time - __time%60000),'yyyy-MM-dd HH:mm:ss','+08:00') AS dt,      sum( try_cast( request_length AS BIGINT ) )/ 60.0 AS "DATA"      FROM      log      GROUP BY      dt       LIMIT 10000      ))   )
   - **网络out带宽峰值** 图表所关联的查询分析语句如下所示：
     * | SELECT CASE WHEN diff [ 1 ] < 102 THEN concat( cast( cast(  diff [ 1 ] AS DECIMAL(20,2)) AS VARCHAR ), ' B/s' )  WHEN diff [ 1 ] < 1024 * 1024 THEN concat(cast( cast(  diff [ 1 ]/ 1024  AS DECIMAL(20,2)) AS VARCHAR ), ' KB/s' ) WHEN diff [ 1 ] < 1024 * 1024 * 1024 THEN concat( cast( cast(  diff [ 1 ]/ 1024.0 / 1024  AS DECIMAL(20,2)) AS VARCHAR ), ' MB/s' ) WHEN diff [ 1 ]/ 1024.0 < 1024 * 1024 * 1024 THEN concat( cast( cast(  diff [ 1 ]/ 1024.0 / 1024 / 1024 AS DECIMAL(20,2)) AS VARCHAR ), ' GB/s' ) ELSE concat( cast( cast(  diff [ 1 ]/ 1024.0 / 1024 / 1024 / 1024  AS DECIMAL(20,2)) AS VARCHAR ), ' TB/s' ) END AS "value", case when diff [ 2 ]= 0 then 0 else round( diff [ 3 ]- 1, 2 ) END AS "ratio" FROM ( SELECT compare ( "DATA", 86400 ) AS diff FROM ( SELECT COALESCE ( max( bytes_out ), 0 ) AS "DATA" FROM ( SELECT time_format(from_unixtime(__time - __time%60000),'yyyy-MM-dd HH:mm:ss','+08:00') AS dt, sum( try_cast(body_bytes_sent as double precision) )/ 60.0 AS bytes_out FROM log GROUP BY dt LIMIT 10000 )))
   - **流量带宽趋势** 图表所关联的查询分析语句如下所示：
     * | SELECT time_format(from_unixtime(__time - __time%600000),'yyyy-MM-dd HH:mm:ss','+08:00') AS dt, round( sum( try_cast( request_length AS double precision ) )/ 1024.0 / 600, 2 ) AS "流入流量(KB/s)", round( sum( try_cast( body_bytes_sent AS double precision ) )/ 1024.0 / 600, 2) AS "流出流量(KB/s)"  GROUP BY  dt ORDER BY  dt   LIMIT 1000
   - **PV/UV趋势** 图表所关联的查询分析语句如下所示：
     * | SELECT time_format(from_unixtime(__time - __time%3600000),'yyyy-MM-dd HH:mm:ss','+08:00') AS dt, count( 1 ) AS PV, COUNT( DISTINCT ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END )) AS UV  FROM log  GROUP BY  dt  ORDER BY  dt   LIMIT 1000
   - **访问状态分布** 图表所关联的查询分析语句如下所示：
     * | SELECT time_format(from_unixtime(__time - __time%3600000),'yyyy-MM-dd HH:mm:ss','+08:00') AS dt, count( 1 ) AS cnt, concat( cast( cast("response_code" as BIGINT) / 100 AS VARCHAR ), 'XX' ) AS "status"  GROUP BY  dt,  cast("response_code" as BIGINT) / 100  ORDER BY  dt   LIMIT 10000
   - **访问来源** 图表所关联的查询分析语句如下所示：
     * | SELECT       ip_to_country (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS country,       count( 1 ) AS "访问次数"        GROUP BY      country  having   country != ''
   - **流入流量来源（中国）** 图表所关联的查询分析语句如下所示：
     * | SELECT       ip_to_province (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS region,       round( sum( try_cast(request_length as double precision) )/ 1024.0 / 1024, 4 ) AS "流入流量(MB)"        GROUP BY region  having    region != ''
   - **流入流量来源（世界）** 图表所关联的查询分析语句如下所示：
     * | SELECT       ip_to_country (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS region,       round( sum( try_cast(request_length as double precision) )/ 1024.0 / 1024, 4 ) AS "流入流量(MB)"        GROUP BY       region having region != ''
   - **来源网络提供商** 图表所关联的查询分析语句如下所示：
     * | SELECT      ip_to_provider (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS provider,       cast(round( sum( try_cast(request_length as bigint) )/ 1024.0 / 1024.0, 3 ) AS double precision) AS mb_in       GROUP BY       provider        HAVING       ip_to_provider (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) != '*'        ORDER BY       mb_in DESC        LIMIT 10
   - **访问域名** 图表所关联的查询分析语句如下所示：
     * | SELECT       http_host,       count( 1 ) AS "被访问次数"        GROUP BY       http_host        ORDER BY       "被访问次数" DESC        LIMIT 30
   - **响应最慢的URL** 图表所关联的查询分析语句如下所示：
     * | SELECT http_host AS "网站",url_extract_path (COALESCE ( url, '/' )) AS URL,sum( request_time )/ count( 1 ) AS "响应时间(毫秒)",count( 1 ) AS "访问次数" GROUP BY http_host, url ORDER BY "响应时间(毫秒)" DESC  LIMIT 100
   - **访问最多的客户端** 图表所关联的查询分析语句如下所示：
     * | SELECT ip AS "客户端", client AS "地理网络", concat(  cast( ( CASE WHEN pv IS NULL THEN 0 ELSE pv END ) AS VARCHAR ),  ' (',  cast( CASE WHEN head_pv is null THEN 0 ELSE ( CASE WHEN head_pv > 0 THEN head_pv ELSE 0 END ) END AS VARCHAR ),  '/',  cast( CASE WHEN get_pv is null THEN 0 ELSE ( CASE WHEN get_pv > 0 THEN get_pv ELSE 0 END ) END AS VARCHAR ),  '/',  cast( CASE WHEN put_pv is null THEN 0 ELSE ( CASE WHEN put_pv > 0 THEN put_pv ELSE 0 END ) END AS VARCHAR ),  '/',  cast( CASE WHEN post_pv is null THEN 0 ELSE ( CASE WHEN post_pv > 0 THEN post_pv ELSE 0 END ) END AS VARCHAR ),  '/',  cast( CASE WHEN delete_pv is null THEN 0 ELSE ( CASE WHEN delete_pv > 0 THEN delete_pv ELSE 0 END ) END AS VARCHAR ),  '/',  ')'  ) AS "PV (Head, Get, Put, Post, Delete方法)", error_count AS "错误访问次数"  FROM  (  SELECT   ip,   client,   sum( CASE WHEN "method" = 'PUT' AND "status" < 400 THEN pv ELSE 0 END ) AS put_pv,   sum( CASE WHEN "method" = 'GET' AND "status" < 400 THEN pv ELSE 0 END ) AS get_pv,   sum( CASE WHEN "method" = 'POST' AND "status" < 400 THEN pv ELSE 0 END ) AS post_pv,   sum( CASE WHEN "method" = 'DELETE' AND "status" < 400 THEN pv ELSE 0 END ) AS delete_pv,   sum( CASE WHEN "method" = 'HEAD' AND "status" < 400 THEN pv ELSE 0 END ) AS head_pv,   sum( throughput ) AS throughput,   sum( pv ) AS pv,   sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) AS error_count   FROM   (   SELECT   CASE         WHEN     sip = '-' THEN      remote_ip ELSE sip       END AS ip,     "method",    CASE            WHEN ip_to_country ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END )= '香港' THEN       '中国香港'        WHEN ip_to_province ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END )= '*' THEN        '未知IP'         WHEN ip_to_provider ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END )= '内网IP' THEN         '内网IP' ELSE concat( ip_to_country ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END ), '/', ip_to_province ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END ), '/',         CASE    WHEN ip_to_city
