# CCE仪表盘模板
云容器引擎（Cloud Container Engine，简称CCE）提供高度可扩展的、高性能的企业级Kubernetes集群。
CCE仪表盘模板支持[查看CCE日志节点操作]、[查看CCE日志K8s对象操作]、[查看CCE日志K8s事件查询]、[查看CCE日志K8s事件中心]、[查看CCE日志聚合检索]、[查看CCE日志账号操作审计]和[查看CCE日志审计中心]。
- 已采集CCE日志，详情请参见[云容器引擎CCE应用日志接入LTS](https://support.huaweicloud.com/usermanual-lts/lts_04_0511.html)。
- 日志配置结构化，详情请参见[设置云端结构化解析日志](https://support.huaweicloud.com/usermanual-lts/lts_0821.html)。
 #### 查看CCE日志节点操作
1. 登录[云日志服务控制台](https://console.huaweicloud.com/lts/?#/cts/manager/groups)，进入"日志管理"页面。
2. 在左侧导航栏中选择"仪表盘 "。
3. 在仪表盘模板下方，选择"CCE仪表盘模板 \> CCE日志节点操作"，查看图表详情。
   - 过滤节点名称，所关联的查询分析语句如下所示：
     select distinct("objectRef.name")
   - 过滤操作用户，所关联的查询分析语句如下所示：
     select distinct("user.username")
   - 过滤状态码，所关联的查询分析语句如下所示：
     select distinct("responseStatus.code")
   - 过滤操作类型，所关联的查询分析语句如下所示：
     select distinct("verb")
   - **节点数趋势** 图表所关联的查询分析语句如下所示：
     SELECT  time_series( TIME_PARSE(LEFT(requestReceivedTimestamp, 23),'yyyy-MM-dd''T''HH:mm:ss.SSS'), 'PT1H', 'yyyy-MM-dd HH', '0' ) as "dt",  count(DISTINCT("objectRef.name")) as "节点数" where "objectRef.resource" = 'nodes'  and "objectRef.subresource" = 'status'  and "verb" in ('update', 'patch') and "user.username" = 'system:node' group by   "dt" order by  "dt" desc limit  10000
   - **非系统用户操作趋势** 图表所关联的查询分析语句如下所示：
     SELECT time_series( TIME_PARSE(LEFT(requestReceivedTimestamp, 23),'yyyy-MM-dd''T''HH:mm:ss.SSS'), 'PT1H', 'yyyy-MM-dd HH', '0' ) as "dt", count(*) as "请求", "user.username"  where "objectRef.resource" = 'nodes' and "user.username" not in ( 'kube-controller-manager','kube-apiserver-kubelet-client','apiserver') and "user.username" not like  'system:%' and "verb" in ('create','delete','update','patch') group by "dt", "user.username" order by "dt","请求" desc limit 10000
   - **create操作状态码分布** 图表所关联的查询分析语句如下所示：
     select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" = 'create' group by "状态码"
   - **delete操作状态码分布** 图表所关联的查询分析语句如下所示：
     select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" = 'delete' group by "状态码"
   - **patch操作状态码分布** 图表所关联的查询分析语句如下所示：
     select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" = 'patch' group by "状态码"
   - **update操作状态码分布** 图表所关联的查询分析语句如下所示：
     select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" = 'update' group by "状态码"
   - **节点封锁/解除封锁操作状态码分布** 图表所关联的查询分析语句如下所示：
     select cast("responseStatus.code" as varchar) as "状态码", count(*)  as "count" where "requestObject" in ('{"spec":{"unschedulable":false}}','{"spec":{"unschedulable":true}}')  group by "状态码"
   - **Label操作状态码分布** 图表所关联的查询分析语句如下所示：
     select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where  "objectRef.resource" = 'nodes' and "verb" in ('patch','update') and "requestObject" = 'labels' and "requestObject" = 'metadata' group by "状态码"
   - **Taint操作状态码分布** 图表所关联的查询分析语句如下所示：
     select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" in ('patch','update') and "requestObject" = 'taints' group by "状态码"
   - **驱逐操作状态码分布** 图表所关联的查询分析语句如下所示：
     select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "objectRef.subresource" = 'eviction' and "objectRef.resource" = 'pods' and "verb" = 'create' group by "状态码"
   - **节点增删操作列表** 图表所关联的查询分析语句如下所示：
     select  "auditID" AS "Audit ID", "objectRef.name" AS "节点名", "verb" AS "操作动作", "stageTimestamp" AS "操作时间", "user.username" AS "操作账号", "responseStatus.code" AS "状态码"  where "objectRef.resource" = 'nodes' and "verb" in ('create','delete')
   - **Taint操作列表** 图表所关联的查询分析语句如下所示：
     select  "auditID" AS "Audit ID", "objectRef.name" AS "节点名","requestObject" AS "Taints",  "requestReceivedTimestamp" AS "操作时间", "user.username" AS "操作账号", "responseStatus.code" AS "状态码"  where "objectRef.resource" = 'nodes' and "verb" = 'patch' and "requestObject" = 'taints'
   - **驱逐操作列表** 图表所关联的查询分析语句如下所示：
     select  "auditID" AS "Audit ID", "objectRef.name" AS "pod", "sourceIPs" AS "源地址",  "requestReceivedTimestamp" AS "操作时间", "user.username" AS "操作账号", "responseStatus.code" AS "状态码"  where "objectRef.resource" = 'pods' and "verb" = 'create' and "objectRef.subresource" = 'eviction'
   - **Label操作列表** 图表所关联的查询分析语句如下所示：
     select  "auditID" AS "Audit ID", "objectRef.name" AS "节点名", "requestObject" AS "Label", "requestReceivedTimestamp" AS "操作时间", "user.username" AS "操作账号", "responseStatus.code" AS "状态码"  where "objectRef.resource" = 'nodes' and "verb" = 'patch' and "requestObject" = 'labels'
   - **封锁操作列表** 图表所关联的查询分析语句如下所示：
     select "auditID" AS "Audit ID", "objectRef.name" AS "节点名",  "requestReceivedTimestamp" AS "操作时间", "user.username" AS "操作账号", "responseStatus.code" AS "状态码" where "verb" = 'patch' and "objectRef.resource" = 'nodes' and "requestObject" ='true' and "requestObject" = 'unschedulable'
   - **取消封锁操作列表** 图表所关联的查询分析语句如下所示：
     select "auditID" AS "Audit ID", "objectRef.name" AS "节点名",  "requestReceivedTimestamp" AS "操作时间", "user.username" AS "操作账号", "responseStatus.code" AS "状态码" where "verb" = 'patch' and "objectRef.resource" = 'nodes' and "requestObject" not in ('true','taints','unschedulable')
 #### 查看CCE日志K8s对象操作
1. 在仪表盘模板下方，选择"CCE仪表盘模板 \> CCE日志K8s对象操作"，查看图表详情。
   - 过滤命名空间，所关联的查询分析语句如下所示：
     select distinct("objectRef.namespace")
   - 过滤资源对象，所关联的查询分析语句如下所示：
   - 过滤资源类型，所关联的查询分析语句如下所示：
     select distinct("objectRef.resource")
   - **重要操作趋势** 图表所关联的查询分析语句如下所示：
     SELECT REPLACE(LEFT(requestReceivedTimestamp, 16),'T',' ') AS "dt", "verb" as "操作类型", count(*)  as "count" where "verb" in ('create','delete','update','patch') and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "dt","操作类型" order by "dt" limit 10000
     SELECT REPLACE(LEFT(requestReceivedTimestamp, 16),'T',' ') AS "dt", count(*) as "请求次数","user.username" WHERE "user.username" not in ('kube-controller-manager','kube-apiserver-kubelet-client','apiserver') and "user.username" not like 'system:%'  and  "verb" in ('create','delete','update','patch')  and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','secrets','pvcs')  group by "dt", "user.username"  limit 10000
   - **create操作资源类型分布** 图表所关联的查询分析语句如下所示：
     select "objectRef.resource" as "资源类型", count(*) as "count" where "verb" = 'create' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims')  group by  "objectRef.resource"
   - **delete操作资源类型分布** 图表所关联的查询分析语句如下所示：
     select "objectRef.resource" as "资源类型", count(*) as "count" where "verb" = 'delete' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims')  group by  "objectRef.resource"
   - **update操作资源类型分布** 图表所关联的查询分析语句如下所示：
     select "objectRef.resource" as "资源类型", count(*) as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims')  group by  "objectRef.resource"
   - **patch操作资源类型分布** 图表所关联的查询分析语句如下所示：
     select "objectRef.resource" as "资源类型", count(*) as "count" where "verb" = 'patch' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims')  group by  "objectRef.resource"
   - **create操作用户分布** 图表所关联的查询分析语句如下所示：
     select "user.username" as "操作用户", count(*)  as "count" where "verb" = 'create' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by  "user.username"
   - **delete操作用户分布** 图表所关联的查询分析语句如下所示：
     select "user.username" as "操作用户", count(*) as "count" where "verb" = 'delete' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by  "user.username"
   - **update操作用户分布** 图表所关联的查询分析语句如下所示：
     select "user.username" as "操作用户", count(*)  as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by  "user.username"select "user.username" as "操作用户", count(*)  as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by  "user.username"
   - **patch操作用户分布** 图表所关联的查询分析语句如下所示：
     select "user.username" as "操作用户", count(*)  as "count"  where "verb" = 'patch' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by  "user.username"
     select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "verb" = 'create' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by  "responseStatus.code"
     select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "verb" = 'delete' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by  "responseStatus.code"
     select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by  "responseStatus.code"
     select cast("responseStatus.code" as varchar) as "状态码", count(*)  as "count" where "verb" = 'patch' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by  "responseStatus.code"
   - **create操作趋势** 图表所关联的查询分析语句如下所示：
     SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "资源类型", count(*)  as "count" where "verb" = 'create' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims')  group by dt, "objectRef.resource" order by dt limit 10000
   - **delete操作趋势** 图表所关联的查询分析语句如下所示：
     SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "资源类型", count(*)  as "count" where "verb" = 'delete' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims')  group by dt, "objectRef.resource" order by dt limit 10000
   - **update操作趋势** 图表所关联的查询分析语句如下所示：
     SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "资源类型", count(*) as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims')  group by dt, "objectRef.resource" order by dt limit 10000
   - **patch操作趋势** 图表所关联的查询分析语句如下所示：
     SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "资源类型", count(*)  as "count" where "verb" = 'patch' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims')  group by dt, "objectRef.resource" order by dt limit 10000
 #### 查看CCE日志K8s事件查询
1. 在仪表盘模板下方，选择"CCE仪表盘模板 \> CCE日志K8s事件查询"，查看图表详情。
   - 事件等级分为Warning、Normal、Error。
   - 过滤事件类型，所关联的查询分析语句如下所示：
     select distinct("name")
   - 过滤集群ID，所关联的查询分析语句如下所示：
     select distinct("cluster_id")
     select distinct("namespace")
   - 过滤名称，所关联的查询分析语句如下所示：
     select distinct("resource_name")
   - **事件总数** 图表所关联的查询分析语句如下所示：
     SELECT TIME_FORMAT( "_time_", 'yyyy-MM-dd HH:mm:ss', '' ) as "_time_","total" FROM ( SELECT TIME_CEIL ( __time, 'PT1H' ) AS "_time_", count( 1 ) AS "total" FROM log GROUP BY "_time_" )
   - **普通事件数** 图表所关联的查询分析语句如下所示：
     SELECT TIME_FORMAT( "_time_", 'yyyy-MM-dd HH:mm:ss', '' ) as "_time_","total" FROM ( SELECT TIME_CEIL ( __time, 'PT1H' ) AS "_time_", count( 1 ) AS "total" FROM log where "type" = 'Normal' GROUP BY "_time_" )
   - **警告事件数** 图表所关联的查询分析语句如下所示：
     SELECT TIME_FORMAT( "_time_", 'yyyy-MM-dd HH:mm:ss', '' ) as "_time_","total" FROM ( SELECT TIME_CEIL ( __time, 'PT1H' ) AS "_time_", count( 1 ) AS "total" FROM log where "type" = 'Warning' GROUP BY "_time_" )
   - **错误事件数** 图表所关联的查询分析语句如下所示：
     SELECT TIME_FORMAT( "_time_", 'yyyy-MM-dd HH:mm:ss', '' ) as "_time_","total" FROM ( SELECT TIME_CEIL ( __time, 'PT1H' ) AS "_time_", count( 1 ) AS "total" FROM log  where "type" = 'Error' GROUP BY "_time_" )
   - **重要事件分布** 图表所关联的查询分析语句如下所示：
     select "name",count(1) as 'total' from log group by "name"
   - **重要事件** **统计** 图表所关联的查询分析语句如下所示：
     SELECT "type" as "等级", "name" as "类型", count(1) as "总数", "reason" as "详细内容" from log where "type" != 'Normal'  group by "type", "name", "reason" order by "总数" desc
   - **Pod重要事件统计**图表所关联的查询分析语句如下所示：
     SELECT "type" as "等级", "name" as "类型",  count(1) as "总数", "reason" as "详细内容"  from log where "type" != 'Normal'  and "resource_kind" = 'Pod' group by  "type",  "name", "reason" order by "总数" desc
   - **最近100条事件** 图表所关联的查询分析语句如下所示：
     select TIME_FORMAT( __time, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as "Time","type" as "等级", "name" as "类型", "reason" as "详细内容", "namespace" as "命名空间" from log order by __time desc limit 100
 #### 查看CCE日志K8s事件中心
1. 在仪表盘模板下方，选择"CCE仪表盘模板 \> CCE日志K8s事件中心"，查看图表详情。
   - 事件等级分为Warning和Normal。
   - **Conntrack Full** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where  "name"= 'ConntrackFull'  ) )
   - **事件同步异常** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where  "name"= 'NTPIsDown') )
   - **节点Pid不足** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where  "name" in ('PIDPressure','NodeHasPIDPressure') ) )
   - **节点FD不足** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where  "name"= 'NodeHasFDPressure') )
   - **节点磁盘空间不足** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where  "name"= 'NodeHasDiskPressure') )
   - **Pod OOM** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where   "reason" in ('OOMKilling','PodOOMKilling')) )
   - **DockerHung** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where  "name"= 'Failed' and "reason" = 'DockerHung') )
   - **节点重启** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where  "name"= 'NodeRebooted') )
   - **镜像拉取失败** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where  "name"= 'Failed' and "reason" = 'ImagePullBackOff') )
   - **节点OOM** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where  "name" = 'SystemOOM') )
   - **Pod启动失败** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where  "name"= 'Failed' and "resource_kind" = 'Pod' and  "reason" = 'ImagePullBackOff') )
   - 事**件分布** 图表所关联的查询分析语句如下所示：
     select "type", count(*) as "事件数" group by "type"
   - **Warning事件趋势** 图表所关联的查询分析语句如下所示：
     select time_series(__time, 'PT1H', 'yyyy-MM-dd HH', '0') as "dt",count(1) as "count"  from log  where "type" = 'Warning'  group by "dt" order by "dt"
   - **Error事件趋势** 图表所关联的查询分析语句如下所示：
     select time_series(__time, 'PT1H', 'yyyy-MM-dd HH', '0') as "dt",count(1) as "count" from log  where "type" = 'Error' group by "dt" order by "dt"
   - **Pod OOM事件列表** 所关联的查询分析语句如下所示：
     select TIME_FORMAT( __time, 'yyyy-MM-dd HH:mm:ss', '+08:00') as "Time", "resource_kind" as "事件目标", "name" as "类型", "resource_name" as "目标名", "reason" as "详细内容" from log where "name" in ('OOMKilling','PodOOMKilling') order by __time desc limit 100
   - **Pod驱动事件列表** 所关联的查询分析语句如下所示：
     select TIME_FORMAT( __time, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as "Time", "resource_kind" as "事件目标", "name" as "类型", "resource_name" as "目标名", "reason" as "详细内容" from log where "name" = 'NodeControllerEviction' order by __time desc limit 100
   - **重要事件列表** 所关联的查询分析语句如下所示：
     select TIME_FORMAT( __time, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as "Time", "type" as "等级", "resource_kind" as "事件目标", "name" as "类型", "resource_name" as "目标名", "reason" as "详细内容" from log where "type" in ('Warning','Error') order by __time desc limit 100
 #### 查看CCE日志聚合检索
1. 在仪表盘模板下方，选择"CCE仪表盘模板 \> CCE日志聚合检索"，查看图表详情。
   - 过滤请求URL，所关联的查询分析语句如下所示：
     select distinct("requestURI")
   - 过滤userAgent，所关联的查询分析语句如下所示：
     select distinct("userAgent")
   - **操作用户分布趋势** 图表所关联的查询分析语句如下所示：
     SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "user.username" as "操作用户", count(*) as "count" group by dt, "user.username" order by dt limit 10000
   - **命名空间分布趋势** 图表所关联的查询分析语句如下所示：
     SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.namespace" as "命名空间", count(*) as "count"  group by dt, "objectRef.namespace" order by dt limit 10000
   - **操作类型分布趋势** 图表所关联的查询分析语句如下所示：
   - **状态码分布趋势** 图表所关联的查询分析语句如下所示：
     SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, cast("responseStatus.code" as varchar) as "返回码", count(*)  as "count" group by dt, "返回码" order by dt limit 10000
   - **资源类型分布趋势** 图表所关联的查询分析语句如下所示：
     SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "资源类型", count(*) as "count" group by dt, "objectRef.resource" order by dt limit 10000 SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "资源类型", count(*) as "count" group by dt, "objectRef.resource" order by dt limit 10000
   - **重要操作列表** 所关联的查询分析语句如下所示：
     select  "auditID" AS "Audit ID", "verb" AS "操作类型", "requestReceivedTimestamp" AS "开始时间", "stageTimestamp" AS "结束时间", "user.username" AS "操作账号", "sourceIPs" AS "操作源","userAgent","objectRef.namespace" AS "命名空间", CONCAT(CONCAT("objectRef.resource", '/'), "objectRef.subresource") AS "操作对象", "objectRef.name" AS "资源名", "responseStatus.code" AS "返回码"
 #### 查看CCE日志账号操作审计
1. 在仪表盘模板下方，选择"CCE仪表盘模板 \> CCE日志账号操作审计"，查看图表详情。
   - 过滤用户名，所关联的查询分析语句如下所示：
   - **资源创建数** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where "verb" = 'create') )
   - **资源修改数** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(*)   as "total" from log where "verb" in ('update','patch')) )
   - **资源删除数** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(*)   as "total" from log where "verb" = 'delete') )
   - **操作命名空间分布** 图表所关联的查询分析语句如下所示：
     select case when "objectRef.namespace" is null then '_all__' else "objectRef.namespace" end as ns, count(1) as total group by  ns  limit 10000
   - **删除资源分布** 图表所关联的查询分析语句如下所示：
     SELECT "objectRef.resource" as "resource", count(1) as "count" where  "verb" = 'delete' group by "resource"
   - **操作轨迹** 图表所关联的查询分析语句如下所示：
     select case  when "操作" is null then '无' else "操作" end as "操作", "时间", v from  (select concat(CASE WHEN "objectRef.subresource" is null then "objectRef.resource" else "objectRef.subresource"  end, '[', verb, ']'  ) as "操作", time_series(__time, 'PT1H', 'yyyy-MM-dd HH', '0') as "时间", count(1) as v  from  log where "verb" in ('create', 'patch',  'update', 'delete')  group by "操作", "时间" order by "时间" desc  limit  10000  )
   - **资源操作分布** 图表所关联的查询分析语句如下所示：
     select CASE WHEN "objectRef.subresource" is null then "objectRef.resource" else "objectRef.subresource" end as "资源", verb as "操作", count(1) as total where "verb" in ('create','update','patch','delete') group by "资源", "操作" limit 10000
   - **创建资源列表** 所关联的查询分析语句如下所示：
     SELECT "auditID" as "事件ID", time_format("__time",'yyyy-MM-dd HH:mm:ss') as "操作时间", "requestURI" as "资源", "objectRef.name" as "资源名", "responseStatus.code" as "状态码","sourceIPs" as "源地址", "requestObject" as "详细内容" where "verb" = 'create' order by __time desc limit 1000
   - **修改资源列表** 所关联的查询分析语句如下所示：
     SELECT auditID as "事件ID", time_format("__time",'yyyy-MM-dd HH:mm:ss') as "操作时间","requestURI" as "资源", "objectRef.name" as "资源名", "responseStatus.code" as "状态码","sourceIPs" as "源地址", requestObject as "详细内容" where "verb" in ('update','patch') order by __time desc limit 1000
   - **资源访问列表** 所关联的查询分析语句如下所示：
     SELECT auditID as "事件ID", time_format("__time",'yyyy-MM-dd HH:mm:ss') as "操作时间", "requestURI" as "资源", "objectRef.name" as "资源名", "responseStatus.code" as "状态码","sourceIPs" as "源地址", requestObject as "详细内容" where "verb" in ('get','list') order by __time desc limit 1000
   - **资源删除列表** 所关联的查询分析语句如下所示：
     SELECT auditID as "事件ID", time_format("__time",'yyyy-MM-dd HH:mm:ss') as "操作时间", "requestURI" as "资源", "objectRef.name" as "资源名", "responseStatus.code" as "状态码","sourceIPs" as "源地址", requestObject as "详细内容" where "verb" = 'delete' order by __time desc limit 1000
 #### 查看CCE日志审计中心
1. 在仪表盘模板下方，选择"CCE仪表盘模板 \> CCE日志审计中心"，查看图表详情。
   - 过滤UserAgent，所关联的查询分析语句如下所示：
   - **总审计记录数** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log ) )
   - **操作用户数** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc"  from (select compare( total , 86400) as diff from( select count(distinct("user.username")) as total from log ) )
   - **活跃节点数** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(DISTINCT "user.username") as total     from log where "objectRef.resource" = 'nodes' and "objectRef.subresource" = 'status' and "verb" in ('update','put','patch') and "user.username" in ('node','system')) )
   - **异常访问次数** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where "responseStatus.code" >= 400) )
   - **敏感操作次数** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1)  as "total" from log where ("verb" = 'create' AND "objectRef.subresource" = 'exec') OR ("verb" = 'create' AND "objectRef.subresource" = 'attach' AND "objectRef.resource" = 'pods') OR ("objectRef.resource" = 'secrets' AND "verb"= 'get' AND ( "user.username" != 'apiserver') AND ("user.username" not like 'system:node:%')) OR ("verb"= 'delete' AND ( "user.username" not like 'system:node:%') AND ( "user.username" not like 'system:serviceaccount:kube-system:%') AND ( "user.username" != 'system:apiserver') AND ( "user.username" != 'system:apiserver') AND ( "user.username" != 'system:kube-scheduler') AND ("user.username" != 'system:kube-controller-manager'))) )
   - **创建操作次数** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where verb = 'create') )
   - **更新操作次数** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc"  from (select compare( total , 86400) as diff from( select count(1) as total from log where verb in ('update','patch')) )
   - **删除操作次数** 图表所关联的查询分析语句如下所示：
     select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where verb = 'delete') )
   - **操作用户分布** 图表所关联的查询分析语句如下所示：
     select "user.username" as "用户名", count(*) as "count"  group by "用户名" order by "count" desc
   - **命名空间分布** 图表所关联的查询分析语句如下所示：
     select "objectRef.namespace" as "命名空间", count(*) as "count"  group by "命名空间"
   - **资源类型分布** 图表所关联的查询分析语句如下所示：
     select "objectRef.resource" as "资源类型", count(*) as "count"  group by "资源类型" order by "count" desc limit 20
   - **操作类型分布** 图表所关联的查询分析语句如下所示：
     select verb as "操作类型", count(*) as "count" group by "操作类型" order by "count" desc
   - **节点操作分布** 图表所关联的查询分析语句如下所示：
     select "verb" as "操作类型", count(*) as "count" where  "objectRef.resource" = 'nodes' AND ("verb" in ('create','delete') ) group by "操作类型" order by "count" desc
   - **工作负载操作分布** 图表所关联的查询分析语句如下所示：
     select "verb" as "操作类型", count(*) as "count" where "verb" in ('create', 'delete') and "objectRef.resource" in ('deployments','statefulsets','daemonsets','jobs','cronjobs') group by "操作类型" order by "count" desc
   - **Service/Ingress操作分布** 图表所关联的查询分析语句如下所示：
     select "verb" as "操作类型", count(*) as "count" where "verb" in ('create', 'delete') and "objectRef.resource" in ('ingresses','services') group by "verb"  order by "count" desc
     SELECT REPLACE(LEFT("stageTimestamp", 16),'T',' ') AS "dt", "verb", count(*) as "count" where "verb" in ('create','delete','update','patch') group by "dt", "verb" order by "dt" limit 10000
     SELECT REPLACE(LEFT("stageTimestamp", 16),'T',' ') AS "dt", count(*) as "count", "user.username" as "用户名称" where "user.username" not in ('kube-controller-manager','kube-apiserver-kubelet-client','system','apiserver') group by "dt", "用户名称" order by "dt" limit 10000
