# 数据模板
- 资产数据输入
  | 数据模板        | 字段名        | 字段说明        | 是否必填 |
  | { "type": "FunctionCall", "message": { "projectId": "080dd91ecc802xxxxxx01be5f9d68d", "jobId": "J_79519506820943xxx", "context": { "assetId": "assetId01", "analysisId": "analysisId01" }, "input": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } }, "timestamp": 1624440752632 }, "msgVersion": "1.0" } | type       | 数据类型，必须模板默认值，用户不能修改        | 是    |
  | { "type": "FunctionCall", "message": { "projectId": "080dd91ecc802xxxxxx01be5f9d68d", "jobId": "J_79519506820943xxx", "context": { "assetId": "assetId01", "analysisId": "analysisId01" }, "input": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } }, "timestamp": 1624440752632 }, "msgVersion": "1.0" } | message    | 消息体，必须模板默认值，用户不能修改        | 是    |
  | { "type": "FunctionCall", "message": { "projectId": "080dd91ecc802xxxxxx01be5f9d68d", "jobId": "J_79519506820943xxx", "context": { "assetId": "assetId01", "analysisId": "analysisId01" }, "input": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } }, "timestamp": 1624440752632 }, "msgVersion": "1.0" } | projectId  | 租户id，必须模板默认值，用户不能修改        | 是    |
  | { "type": "FunctionCall", "message": { "projectId": "080dd91ecc802xxxxxx01be5f9d68d", "jobId": "J_79519506820943xxx", "context": { "assetId": "assetId01", "analysisId": "analysisId01" }, "input": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } }, "timestamp": 1624440752632 }, "msgVersion": "1.0" } | jobId      | 当前实时分析任务id，必须模板默认值，用户不能修改        | 是    |
  | { "type": "FunctionCall", "message": { "projectId": "080dd91ecc802xxxxxx01be5f9d68d", "jobId": "J_79519506820943xxx", "context": { "assetId": "assetId01", "analysisId": "analysisId01" }, "input": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } }, "timestamp": 1624440752632 }, "msgVersion": "1.0" } | context    | 资产信息，必须模板默认值，用户不能修改        | 是    |
  | { "type": "FunctionCall", "message": { "projectId": "080dd91ecc802xxxxxx01be5f9d68d", "jobId": "J_79519506820943xxx", "context": { "assetId": "assetId01", "analysisId": "analysisId01" }, "input": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } }, "timestamp": 1624440752632 }, "msgVersion": "1.0" } | input      | 输入数据，必须包含算子配置的"参数名称"。例如input中包含"integer"字段。 ![](https://support.huaweicloud.com/usermanual-iotanalytics/figure/zh-cn_image_0000001280751938.png "点击放大")数据支持integer、double、string、object（josn）类型 | 是    |
  | { "type": "FunctionCall", "message": { "projectId": "080dd91ecc802xxxxxx01be5f9d68d", "jobId": "J_79519506820943xxx", "context": { "assetId": "assetId01", "analysisId": "analysisId01" }, "input": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } }, "timestamp": 1624440752632 }, "msgVersion": "1.0" } | timestamp  | 时间戳字段，Long类型，用户可自定义数值。        | 是    |
  | { "type": "FunctionCall", "message": { "projectId": "080dd91ecc802xxxxxx01be5f9d68d", "jobId": "J_79519506820943xxx", "context": { "assetId": "assetId01", "analysisId": "analysisId01" }, "input": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } }, "timestamp": 1624440752632 }, "msgVersion": "1.0" } | msgVersion | 消息版本，必须模板默认值，用户不能修改        | 是    |
- 管道数据输入
  | { "header": { "projectId": "080dd91ecc8026bxxxxx01be5f9d68d", "dataSourceId": "", "pipelineId": "J_79519506820943xxx", "rtaOutputName": "output01" }, "body": { "eventTime": "1624442214553", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | header        | 消息头，必须模板默认值，用户不能修改。                                                  | 是    |
  | { "header": { "projectId": "080dd91ecc8026bxxxxx01be5f9d68d", "dataSourceId": "", "pipelineId": "J_79519506820943xxx", "rtaOutputName": "output01" }, "body": { "eventTime": "1624442214553", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | projectId     | 租户id，必须模板默认值，用户不能修改。                                                 | 是    |
  | { "header": { "projectId": "080dd91ecc8026bxxxxx01be5f9d68d", "dataSourceId": "", "pipelineId": "J_79519506820943xxx", "rtaOutputName": "output01" }, "body": { "eventTime": "1624442214553", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | dataSourceId  | 数据源id，必须模板默认值，用户不能修改。                                                | 是    |
  | { "header": { "projectId": "080dd91ecc8026bxxxxx01be5f9d68d", "dataSourceId": "", "pipelineId": "J_79519506820943xxx", "rtaOutputName": "output01" }, "body": { "eventTime": "1624442214553", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | pipelineId    | 管道任务id，必须模板默认值，用户不能修改。                                               | 是    |
  | { "header": { "projectId": "080dd91ecc8026bxxxxx01be5f9d68d", "dataSourceId": "", "pipelineId": "J_79519506820943xxx", "rtaOutputName": "output01" }, "body": { "eventTime": "1624442214553", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | rtaOutputName | RTA 的数据名称，必须模板默认值，用户不能修改。                                            | 是    |
  | { "header": { "projectId": "080dd91ecc8026bxxxxx01be5f9d68d", "dataSourceId": "", "pipelineId": "J_79519506820943xxx", "rtaOutputName": "output01" }, "body": { "eventTime": "1624442214553", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | body          | 输入数据，必须包含算子配置的"参数名称"。例如input中包含"integer"字段。                          | 是    |
  | { "header": { "projectId": "080dd91ecc8026bxxxxx01be5f9d68d", "dataSourceId": "", "pipelineId": "J_79519506820943xxx", "rtaOutputName": "output01" }, "body": { "eventTime": "1624442214553", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | eventTime     | 时间戳字段，Long类型，用户可自定义数值。                                               | 是    |
  | { "header": { "projectId": "080dd91ecc8026bxxxxx01be5f9d68d", "dataSourceId": "", "pipelineId": "J_79519506820943xxx", "rtaOutputName": "output01" }, "body": { "eventTime": "1624442214553", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | data          | 管道输出字段集合，数据支持integer、double、string、object（josn）类型。用户可自定义data内部字段名和值。 | 是    |
- 资产数据输入（旧）
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | type                 | 数据类型，必须模板默认值，用户不能修改                                   | 是    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | message              | 消息体，必须模板默认值，用户不能修改                                    | 是    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | projectId            | 租户id，必须模板默认值，用户不能修改                                   | 是    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | viewId               | 视图id，必须模板默认值，用户不能修改                                   | 是    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | viewName             | 视图名称                                                  | 否    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | assetId              | 资产id                                                  | 否    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | assetName            | 资产名称                                                  | 否    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | assetCategory        | 资产目录                                                  | 否    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | measurePointId       | 测点id                                                  | 否    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | measurePointName     | 测点名称                                                  | 否    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | measurePointCategory | 测点目录                                                  | 否    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | valueType            | 数据类型，数据支持integer、double、string、object（josn）类型，用户自行定义。 | 是    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | value                | 数据值，数据支持integer、double、string、object（josn）类型，用户自行定义。  | 是    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | eventTime            | 时间字段，用户可自定义数值。                                        | 是    |
  | { "type": "MeasPointValue", "message": { "projectId": "092b845deb00dxxxxxx0181be20fa1", "viewId": "trace_test", "viewName": "", "assetId": "", "assetName": "", "assetCategory": "", "measurePointId": "", "measurePointName": "", "measurePointCategory": "", "valueType": "", "value": "", "eventTime": "20210623T181127+0800" }, "msgVersion": "1.0" } | msgVersion           | 消息版本，必须模板默认值，用户不能修改。                                  | 是    |
- 数据存储数据源（旧）
  | { "header": { "projectId": "092b845deb00d45cxxxxxx1be20fa1", "dataSourceId": "", "pipelineId": "", "dataStoreId": "0264bbad-xxxx-4f5d-xxxx-5d87c1bfaa90" }, "body": { "deviceId": "", "eventTime": "1624503993013", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | header       | 消息头，必须模板默认值，用户不能修改。                                                  | 是    |
  | { "header": { "projectId": "092b845deb00d45cxxxxxx1be20fa1", "dataSourceId": "", "pipelineId": "", "dataStoreId": "0264bbad-xxxx-4f5d-xxxx-5d87c1bfaa90" }, "body": { "deviceId": "", "eventTime": "1624503993013", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | projectId    | 租户id，必须模板默认值，用户不能修改。                                                 | 是    |
  | { "header": { "projectId": "092b845deb00d45cxxxxxx1be20fa1", "dataSourceId": "", "pipelineId": "", "dataStoreId": "0264bbad-xxxx-4f5d-xxxx-5d87c1bfaa90" }, "body": { "deviceId": "", "eventTime": "1624503993013", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | dataSourceId | 数据源id，必须模板默认值，用户不能修改。                                                | 是    |
  | { "header": { "projectId": "092b845deb00d45cxxxxxx1be20fa1", "dataSourceId": "", "pipelineId": "", "dataStoreId": "0264bbad-xxxx-4f5d-xxxx-5d87c1bfaa90" }, "body": { "deviceId": "", "eventTime": "1624503993013", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | pipelineId   | 管道任务id，必须模板默认值，用户不能修改。                                               | 是    |
  | { "header": { "projectId": "092b845deb00d45cxxxxxx1be20fa1", "dataSourceId": "", "pipelineId": "", "dataStoreId": "0264bbad-xxxx-4f5d-xxxx-5d87c1bfaa90" }, "body": { "deviceId": "", "eventTime": "1624503993013", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | dataStoreId  | 数据存储id，必须模板默认值，用户不能修改。                                               | 是    |
  | { "header": { "projectId": "092b845deb00d45cxxxxxx1be20fa1", "dataSourceId": "", "pipelineId": "", "dataStoreId": "0264bbad-xxxx-4f5d-xxxx-5d87c1bfaa90" }, "body": { "deviceId": "", "eventTime": "1624503993013", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | body         | 输入数据，必须包含算子配置的"参数名称"。例如input中包含"integer"字段。                          | 是    |
  | { "header": { "projectId": "092b845deb00d45cxxxxxx1be20fa1", "dataSourceId": "", "pipelineId": "", "dataStoreId": "0264bbad-xxxx-4f5d-xxxx-5d87c1bfaa90" }, "body": { "deviceId": "", "eventTime": "1624503993013", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | deviceId     | 设备id，用户可自定义。                                                         | 否    |
  | { "header": { "projectId": "092b845deb00d45cxxxxxx1be20fa1", "dataSourceId": "", "pipelineId": "", "dataStoreId": "0264bbad-xxxx-4f5d-xxxx-5d87c1bfaa90" }, "body": { "deviceId": "", "eventTime": "1624503993013", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | eventTime    | 时间戳字段，Long类型，用户可自定义数值。                                               | 是    |
  | { "header": { "projectId": "092b845deb00d45cxxxxxx1be20fa1", "dataSourceId": "", "pipelineId": "", "dataStoreId": "0264bbad-xxxx-4f5d-xxxx-5d87c1bfaa90" }, "body": { "deviceId": "", "eventTime": "1624503993013", "data": { "integer": "", "double": "", "string": "", "object": { "a": "", "b": "" } } } } | data         | 管道输出字段集合，数据支持integer、double、string、object（josn）类型。用户可自定义data内部字段名和值。 | 是    |
