更新时间:2022-05-11 GMT+08:00
使用示例
查看Node和Namespace
# kubectl get node 10.7.1.192 Ready <none> 104d v1.15.11 10.7.122.60 Ready <none> 104d v1.15.11 10.7.13.128 Ready <none> 84d v1.15.11 196b3f9a-e097-4120-a8f8-8d2b172ea917 NotReady edge 27d # kubectl get namespace NAME STATUS AGE default Active 104d e78acc02d9d141eda5ca8e88fa35f6f8 Active 104d ief-system Active 104d kube-node-lease Active 104d kube-public Active 104d kube-system Active 104d
创建Deployment
Deployment的描述方式与开源Kubernetes一致,Deployment部署到哪个边缘节点,由IEF的调度器选择。注意此种方式创建的应用不允许通过IEF界面进行更新。
apiVersion: extensions/v1beta1
kind: Deployment
namespace: e78acc02d9d141eda5ca8e88fa35 # namespace值为铂金版总览页面“命名空间”字段内容
labels:
app: nginx # app值必须添加,且必须为metadata.name的值,即Deployment的名称
replicas: 1
selector:
matchLabels:
app: nginx
template:
labels:
app: nginx
containers:
- name: container-1
image: nginx:latest
imagePullPolicy: IfNotPresent
ports:
- containerPort: 80
hostPort: 8080
protocol: TCP
创建Deployment到指定节点
部署Deployment到指定节点可以使用亲和性配置,根据节点ID将Deployment部署到指定节点。建议使用此种方式部署Deployment。注意此种方式创建的应用不允许通过IEF界面进行更新。
kind: Deployment
namespace: e78acc02d9d141eda5ca8e88fa35f6f8 # namespace值为铂金版总览页面“命名空间”字段内容
labels:
replicas: 1
selector:
matchLabels:
app: nginx
template:
labels:
app: nginx
affinity:
nodeAffinity:
requiredDuringSchedulingIgnoredDuringExecution:
nodeSelectorTerms:
- matchExpressions:
- key: edgecloud.huawei.com/node_id # key值必须为edgecloud.huawei.com/node_id
operator: In
values:
- {node_id} # 此处取值为边缘节点ID
containers:
- name: container-1
image: nginx:latest
ports:
- containerPort: 80
hostPort: 8080
protocol: TCP
创建Job
apiVersion: batch/v1
kind: Job
labels:
job-name: nginx-job
template:
labels:
job-name: nginx-job
containers:
- name: container-1
image: swr.cn-north-7.myhuaweicloud.com/paas_ief_fwx310702/nginx:latest
restartPolicy: Never
创建Service
apiVersion: v1
kind: Service
type: ClusterIP # Service类型只支持ClusterIP类型
ports:
- port: 80
name: http-nginx # port名称需要符合istio要求,即<协议>-<名称>,如http-name
targetPort: 30009
protocol: TCP
selector:
app: nginx
创建完成后,可以通过“应用网格 > 服务列表”页面查询到Service的内部URL。
父主题: Kubernetes原生接口开放
