# 准备工作
RPM包的更新方法有两种：使用**osmt** **update**命令更新和使用后台osmt-agent服务自动更新。此两种方法，都须先执行本节操作。
1. 确认repo源配置正常。 请检查默认的/etc/yum.repos.d/hce.repo配置文件中参数是否正确，正确的配置如下。
   [base]
   name=HCE $releasever base
   baseurl=https://repo.huaweicloud.com/hce/$releasever/os/$basearch/
   enabled=1
   gpgcheck=1
   gpgkey=https://repo.huaweicloud.com/hce/$releasever/os/RPM-GPG-KEY-HCE-2
   [updates]
   name=HCE $releasever updates
   baseurl=https://repo.huaweicloud.com/hce/$releasever/updates/$basearch/
   enabled=1
   gpgcheck=1
   gpgkey=https://repo.huaweicloud.com/hce/$releasever/updates/RPM-GPG-KEY-HCE-2
   [debuginfo]
   name=HCE $releasever debuginfo
   baseurl=https://repo.huaweicloud.com/hce/$releasever/debuginfo/$basearch/
   enabled=0
   gpgcheck=1
   gpgkey=https://repo.huaweicloud.com/hce/$releasever/debuginfo/RPM-GPG-KEY-HCE-2
   ![](https://support.huaweicloud.com/usermanual-hce/public_sys-resources/note_3.0-zh-cn.png)
   - 错误的配置内容可能会导致OSMT升级失败或非预期的升级行为。
   - HCE 3.0中，RPM-GPG-KEY-HCE-2换成RPM-GPG-KEY-HCE-3。
   - 使用时需要将$releasever和$basearch替换成环境实际配置，$releasever为OS版本号，可替换为2.0，$basearch为节点架构，可替换为aarch64或x86_64。
2. 执行**dnf update osmt -y**命令更新OSMT升级工具。
3. 配置/etc/osmt/osmt.conf文件。 OSMT根据配置文件osmt.conf的设置，对RPM包进行更新。请根据需要配置osmt.conf文件。
   [auto]
   #if auto_upgrade is True, the osmt-agent will auto upgrade rpms use osmt.conf and reboot between time interval we specified
   #the value of cycle_time means the  osmt-agent will check upgrade every cycle_time seconds, default 86400s(1 day)
   #When a configuration item has a line break, you need to leave a space or tab at the beginning of the line
   auto_upgrade = False
   cycle_time = 3600
   minimal_interval = 3600
   auto_upgrade_window = "22:00-05:00"
   auto_upgrade_interval = 1
   [Package]
   # There are three rules of filters, all enabled by default. severity will be effect only when the types contain security, it is the subtype of security.
   # The following are the three rules:
   #    1. white list has the highest priority, if whitelist is configured then ignore other rules and filter out the whitelist packages from the full list of packages to be upgrade
   #    2. Filter the update range by types, when the types contain security, further filter the severity of security updates severity, only upgrade the severity level of security.
   #    3. Filter blacklist to remove packages in blacklist from types filter results, and packages which depend on packages in blacklist will also be removed.
   # filters must contain at least one types rule, if the types rule is empty, the -a option will not upgrade any packages (by default all 3 filters are enabled).
   filters = "types, blacklist"
   whitelist = ""
   # types include: security, bugfix, enhancement, newpackage, unknown/other
   # if types is empty, no package will be upgrade
   types = "security"
   # severity is the subtype of security, include: low, moderate, important, critical
   severity = "important, critical"
   blacklist = ""
   # The rpm package that requires a system reboot to take effect after the upgrade
   need_reboot_rpms = "kernel,kernel-debug,kernel-debuginfo,kernel-debuginfo-common,kernel-devel,kernel-headers,kernel-ori,kernel-tools,kernel-tools-libs,glibc,glibc-utils,glibc-static,glibc-headers,glibc-devel,glibc-common,dbus,dbus-python,dbus-libs,dbus-glib-devel,dbus-glib,dbus-devel,systemd,systemd-devel,systemd-libs,systemd-python,systemd-sysv,grub2,grub2-efi,grub2-tools,openssl,openssl-devel,openssl-libs,gnutls,gnutls-dane,gnutls-devel,gnutls-utils,linux-firmware,openssh,openssh-server,openssh-clients,openssh-keycat,openssh-askpass,python-libs,python,grub2-pc,grub2-common,grub2-tools-minimal,grub2-pc-modules,grub2-tools-extra,grub2-efi-x64,grub2-efi-x64-cdboot,kernel-cross-headers,kernel-source,glibc-all-langpacks,dbus-common,dbus-daemon,dbus-tools,systemd-container,systemd-pam,systemd-udev,grub2-efi-aa64,grub2-efi-aa64-cdboot,grub2-efi-aa64-modules,openssl-perl,openssl-pkcs,kernel-tools-libs-devel,glibc-debugutils,glibc-locale-source,systemd-help,grub2-efi-ia32-modules,grub2-efi-x64-modules,grub2-tools-efi,grub2-help,openssl-pkcs11,grub2-efi-ia32-cdboot,osmt"
   preinstalled_only = False
   # Due to security requirements, the following packages need to be uninstalled during the upgrade
   need_uninstall_rpm_list = "elfutils-extra,gcc,make,tcpdump,binutils-extra,strace,gdb,gdb-headless,cpp,rpm-build,cups,ypserv,telnet,ypbind,libtool,appict,kmem_analyzer_tools,mcpp,flex,cmake,llvm,rpcgen,wireshark,netcat,nmap,ethereal"
   [backup]
   store_path = /var/log
   backup_dir = /etc,/usr,/boot,/var,/run
   exclude_dir =
   recover_service =
   #the minimum resources required(MB)
   [resource_needed]
   #min_req_boot_space = 100
   #min_req_backup_space = 8192
   #min_req_root_space = 1536
   #min_req_memory = 512
   [cmdline]
   cmdline_value =
   skip_swap = True
   [conflict]
   #conflict_rpm = test1,test2
   # These rpms conflict with the upgrade and must be removed if installed.
   conflict_rpms_list = "esc,initial-setup,python3-crypto,setroubleshoot,setroubleshoot-legacy,setroubleshoot-server,setroubleshoot-plugins,openresty-openssl111,openresty-openssl111-asan,openresty-openssl111-asan-devel,openresty-openssl111-debug,openresty-openssl111-debug-devel,openresty-openssl111-devel,openresty-zlib,openresty-zlib-asan,openresty-zlib-asan-devel,openresty-zlib-devel,dleyna-connector-dbus,dleyna-connector-dbus-devel,dleyna-core,dleyna-core-devel,dleyna-server,tracker,tracker-devel,tracker-miners,kabi-dw,sblim-sfcb,apull,elara,secpaver,ksh,python3-sssd,python3-editor,python3-Flask-SQLAlchemy,python3-bind"
   [strategy]
   timeout_action = "stop"
   timeout_action_before = 0
   [check]
   daemon_whitelist = "sysstat-collect.service, sysstat-summary.service, man-db-cache-update.service, systemd-tmpfiles-clean.service"
   check_systemd_running_jobs = True
   # the timeout of query systemd services
   query_timeout = 30
   check_rpm_packages = True
   check_file_attr = True
   check_gpgkey = True
   [chroot_config]
   chroot_switch = False
   chroot_path = "/root/sut_chroot"
   rpm_tar_name = "hce-upgrade_pack"
   sut_config_file = "/etc/sut/sut.conf"
   web_link_tar =
   表1osmt.conf主要配置项
   | 配置项               | 说明        |
   | \[auto\]          | - auto_upgrade：指定更新RPM包更新方式。默认为False。 - True：使用**osmt** **update**命令更新和使用后台osmt-agent服务自动更新两种方式都支持。  - False：仅支持使用**osmt** **update**命令更新RPM包。    - auto_upgrade为True时，配套如下参数。 - cycle_time：检查是否有待更新软件包的周期，单位是秒。默认值为3600秒。  - minimal_interval：指定**osmt update -b**命令参数中开始时间和截止时间的最小时间间隔，单位是秒。默认值为3600秒。  - auto_upgrade_window：配置后台osmt-agent服务自动升级的时间窗，格式为"HH:MM-HH:MM"，表示升级的开始时间和截止时间。 如果截止时间小于开始时间，则表示本次升级时间段跨越自然日。如"22:00-05:00"表示升级时间段为当日22:00到次日凌晨5:00。   - auto_upgrade_interval：指定两次自动升级之间的最小间隔（单位：天）。    - auto_upgrade为False时，仅配套如下参数，执行配置文件时\[auto\]配置项中其他参数不生效。 - cycle_time：检查是否有待更新软件包的周期，单位是秒。默认值为3600秒。  - minimal_interval：指定**osmt update -b**命令参数中开始时间和截止时间的最小时间间隔，单位是秒。默认值为3600秒。    - motd_setup: 设置登录提示是否开启。默认为True。 - True：开启登录提示。  - False：关闭登录提示，设置后会立刻删除登录提示，并且不会再次生成。如果重新开启，需要使用**osmt update -s**或任意升级命令重新触发生成。     |
   | \[Package\]       | - filters：指定更新的范围，包括types、blacklist、whitelist。 例如filters = "blacklist"，指升级时不更新黑名单中的RPM包。 - types：待更新的RPM包类型。  - blacklist：RPM包黑名单列表。 设置黑名单后，不对黑名单中的RPM包进行更新。如果某RPM包依赖黑名单中的包，则不会升级此RPM包。   - whitelist：RPM包白名单列表。 如果不设置白名单或者黑名单列表，默认更新所有可更新的RPM包。 白名单优先级大于黑名单，如果某RPM包同时配置在白名单和黑名单，则会升级此RPM包。 说明： 如果使用命令指定了黑名单和白名单，以命令指定的黑名单和白名单为准，不再根据配置文件中的黑名单和白名单列表更新RPM包。     - need_reboot_rpms：升级后要重启的RPM包。 后台osmt-agent服务自动升级时，不会更新need_reboot_rpms中的RPM包。若要更新need_reboot_rpms列表中的RPM包，必须使用**osmt update --auto** **--reboot_config always** 或**osmt update --auto** **--reboot_config "重启时间"**命令更新。   - preinstalled_only：当设置成True时，只升级/etc/osmt/preinstalled.list中的RPM包。        |
   | \[backup\]        | - store_path：在该目录下创建备份目录。 升级过程中，OSMT会在store_path下创建.osbak目录，如果原先存在该目录，则需要先使用**osmt remove**将其删除。   - backup_dir：需要备份的目录。其中/etc、/usr、/boot、/var、/run为默认的需要备份的目录，且不可以删减。这些目录会在执行版本升级功能的时候自动进行备份。注意不能与exclude_dir中配置的目录相同，否则升级工具会在目录处理时产生冲突而终止升级流程。  - exclude_dir：不需要备份的目录。默认没有配置，一般建议配置成业务的数据目录，注意不能与backup_dir中配置的目录相同，否则升级工具会在目录处理时产生冲突而终止升级流程。  - recover_service：OSMT会检查升级前后此列表中服务的启用状态是否一致，如果服务的启用状态被修改，OSMT会尝试恢复此服务的状态。 说明： \[backup\]中的路径需要配置为绝对路径的形式。        |
   | \[cmdline\]       | cmdline_value：指定升级之后系统的启动项。请配置正确的启动项，确保系统能够正常启动。默认值为HCE的默认启动项。        |
   | \[conflict\]      | conflict_rpm：指定升级过程中冲突的软件包，升级时系统将自动删除冲突的软件包。        |
   | \[check\]         | - check_systemd_running_jobs：设置是否在升级前检查系统中有正在启动或正在停止的服务，默认为True。 - True：升级前检查系统中是否有正在启动或正在停止的服务。  - False：不检查系统中是否有正在启动或正在停止的服务。    - check_rpm_packages：设置是否在升级前检查系统中rpm包的状态，包括包的依赖是否缺失、是否存在重复的包。默认为True。 - True：升级前检查rpm包的状态。  - False：升级前不检查rpm包的状态。      - check_file_attr：设置是否在升级前检查系统文件是否有只读的属性。默认为True。 - True：升级前检查系统中文件是否有只读属性。  - False：升级前不检查系统中文件是否有只读属性。    - check_gpgkey：设置是否在升级前检查yum源配置中的gpgkey文件是否都存在。默认为True。 - True：升级前检查yum源配置中的gpgkey文件是否都存在。  - False：升级前不检查yum源配置中的gpgkey文件是否存在，跳过该检查步骤。        |
   | \[chroot_config\] | - chroot_switch：是否开启turbo方式的版本升级，默认为False。 - True：版本升级流程中开启turbo方式的升级。  - False：版本升级流程中不开启turbo方式的升级。    - chroot_path：设置turbo升级方式流程中的chroot环境目录。    - rpm_tar_name：设置turbo升级方式中预构建的tar包的名字。    - sut_config_file：设置sut的配置文件路径，默认是/etc/sut/sut.conf。    - web_link_tar：设置turbo升级方式中下载预构建的tar包的url地址。   说明： \[chroot_config\]中的所有配置仅适用于管理面的HCE版本升级方式，turbo方式指的是使用预构建出来的目标版本的tar包通过chroot方式在指定目录下进行版本升级。        |
   其他配置项不建议修改，详情请参见[/etc/osmt/osmt.conf配置文件说明](https://support.huaweicloud.com/usermanual-hce/hce_02_0032.html)。
