# 常见场景的委托权限策略
本节操作提供了DLI常见场景的委托权限策略，用于用户自定义权限时配置委托的权限策略。委托策略中的"Resource"根据需要具体情况进行替换。
 #### 数据清理委托权限配置
适用场景：数据清理委托，表生命周期清理数据及lakehouse表数据清理使用。该委托需新建后自定义权限，但委托名称固定为dli_data_clean_agency。
![](https://support.huaweicloud.com/usermanual-dli/public_sys-resources/note_3.0-zh-cn.png)
请在设置委托的授权范围时分别对OBS权限和DLI权限授权范围：
- OBS权限请选择"全局服务资源"
- DLI权限选择"指定区域项目资源"
    "Version": "1.1",
    "Statement": [
            "Effect": "Allow",
            "Action": [
                "obs:object:GetObject",
                "obs:object:DeleteObject",
                "obs:bucket:HeadBucket",
                "obs:bucket:ListBucket",
                "obs:object:PutObject"
    "Version": "1.1",
    "Statement": [
            "Effect": "Allow",
            "Action": [
                "dli:table:showPartitions",
                "dli:table:select",
                "dli:table:dropTable",
                "dli:table:alter",
                "dli:table:alterTableDropPartition"
 #### 访问和使用OBS的权限策略
适用场景：DLI Flink作业下载OBS对象、OBS/DWS数据源（外表）、日志转储、使用savepoint、开启checkpoint，DLI Spark作业下载OBS对象、读写OBS外表。
    "Version": "1.1",
    "Statement": [
            "Effect": "Allow",
            "Action": [
                "obs:bucket:GetBucketPolicy",
                "obs:bucket:GetLifecycleConfiguration",
                "obs:bucket:GetBucketLocation",
                "obs:bucket:ListBucketMultipartUploads",
                "obs:bucket:GetBucketLogging",
                "obs:object:GetObjectVersion",
                "obs:bucket:GetBucketStorage",
                "obs:bucket:GetBucketVersioning",
                "obs:object:GetObjectVersionAcl",
                "obs:object:ListMultipartUploadParts",
                "obs:bucket:GetBucketAcl",
                "obs:bucket:GetBucketStoragePolicy",
                "obs:object:AbortMultipartUpload",
                "obs:object:DeleteObjectVersion",
                "obs:object:GetObjectAcl",
                "obs:bucket:ListBucketVersions",
            "Resource": [
                "OBS:*:*:bucket:bucketName",//请替换bucketName为对应的桶名称
                "OBS:*:*:object:*"
            "Effect": "Allow",
            "Action": [
                "obs:bucket:ListAllMyBuckets"
 #### 使用DEW加密功能的权限
适用场景：DLI Flink、Spark作业场景使用DEW-CSMS凭证管理能力。
    "Version": "1.1",
    "Statement": [
            "Effect": "Allow",
            "Action": [
                "csms:secretVersion:get",
                "csms:secretVersion:list",
                "kms:dek:decrypt"
 #### 访问DLI Catalog元数据的权限
适用场景：DLI Flink、Spark作业场景，授权DLI访问DLI元数据。
    "Version": "1.1",
    "Statement": [
            "Effect": "Allow",
            "Action": [
                "dli:table:alterTableAddPartition",
                "dli:table:alterTableAddColumns",
                "dli:table:alterTableRenamePartition",
                "dli:table:delete",
                "dli:column:select",
                "dli:database:dropFunction",
                "dli:table:insertOverwriteTable",
                "dli:table:describeTable",
                "dli:database:explain",
                "dli:table:insertIntoTable",
                "dli:database:createDatabase",
                "dli:table:alterView",
                "dli:table:showCreateTable",
                "dli:table:alterTableRename",
                "dli:table:compaction",
                "dli:database:displayAllDatabases",
                "dli:database:dropDatabase",
                "dli:table:truncateTable",
                "dli:table:select",
                "dli:table:alterTableDropColumns",
                "dli:table:alterTableSetProperties",
                "dli:database:displayAllTables",
                "dli:database:createFunction",
                "dli:table:alterTableChangeColumn",
                "dli:database:describeFunction",
                "dli:table:showSegments",
                "dli:database:createView",
                "dli:database:createTable",
                "dli:table:showTableProperties",
                "dli:database:showFunctions",
                "dli:database:displayDatabase",
                "dli:table:alterTableRecoverPartition",
                "dli:table:update",
                "dli:table:alter",
 #### 访问LakeFormation Catalog元数据的权限
适用场景：DLI Spark作业场景，授权DLI访问LakeFormation Catalog元数据。
    "Version": "1.1",
    "Statement": [
            "Effect": "Allow",
            "Action": [
                "lakeformation:table:drop",
                "lakeformation:table:create",
                "lakeformation:policy:create",
                "lakeformation:database:create",
                "lakeformation:database:drop",
                "lakeformation:database:describe",
                "lakeformation:catalog:alter",
                "lakeformation:table:alter",
                "lakeformation:database:alter",
                "lakeformation:catalog:create",
                "lakeformation:function:describe",
                "lakeformation:catalog:describe",
                "lakeformation:function:create",
                "lakeformation:table:describe",
                "lakeformation:function:drop",
                "lakeformation:transaction:operate"
