# 恢复shardsvr2副本集
#### 准备目录
rm -rf /compile/cluster-restore/shd2\*
mkdir -p /compile/cluster-restore/shd21/data/db
mkdir -p /compile/cluster-restore/shd21/log
mkdir -p /compile/cluster-restore/shd22/data/db
mkdir -p /compile/cluster-restore/shd22/log
mkdir -p /compile/cluster-restore/shd23/data/db
mkdir -p /compile/cluster-restore/shd23/log
#### 操作步骤
1. 准备单节点配置文件和目录，以单节点方式启动进程。
   1. 配置文件如下（restoreconfig/single_40309.yaml）。
      net:
        bindIp: 127.0.0.1
        port: 40309
        unixDomainSocket: {enabled: false}
      processManagement: {fork: true, pidFilePath: /compile/cluster-restore/shd21/mongod.pid}
      storage:
        dbPath: /compile/cluster-restore/shd21/data/db/
        directoryPerDB: true
        engine: wiredTiger
        wiredTiger:
          collectionConfig: {blockCompressor: snappy}
          engineConfig: {directoryForIndexes: true, journalCompressor: snappy}
          indexConfig: {prefixCompression: true}
      systemLog: {destination: file, logAppend: true, logRotate: reopen, path: /compile/cluster-restore/shd21/log/mongod.log}
   1. 准备数据，将解压后的shardsvr2文件拷贝到单节点dbPath目录下。 cp -aR
      /compile/download/backups/cac1efc8e65e42ecad8953352321bfeein02_92b196d2401041a7af869a2a3cab7079no02/\* /compile/cluster-restore/shd21/data/db/
   2. 启动进程。 ./mongod -f restoreconfig/single_40309.yaml
2. 连接单节点，执行配置命令。
   连接命令：./mongo --host 127.0.0.1 --port 40309
   1. 执行如下命令，修改副本集配置信息。 var cf=db.getSiblingDB('local').system.replset.findOne();
      cf\['members'\]\[0\]\['host'\]='127.0.0.1:40309';
      cf\['members'\]\[1\]\['host'\]='127.0.0.1:40310';
      cf\['members'\]\[2\]\['host'\]='127.0.0.1:40311';
      cf\['members'\]\[0\]\['hidden'\]=false;
      cf\['members'\]\[1\]\['hidden'\]=false;
      cf\['members'\]\[2\]\['hidden'\]=false;
      cf\['members'\]\[0\]\['priority'\]=1;
      cf\['members'\]\[1\]\['priority'\]=1;
      cf\['members'\]\[2\]\['priority'\]=1;
      db.getSiblingDB('local').system.replset.remove({});
      db.getSiblingDB('local').system.replset.insert(cf)
   2. 执行如下命令，清理内置账号。 db.getSiblingDB('admin').dropAllUsers();
      db.getSiblingDB('admin').dropAllRoles();
   3. 执行如下命令，更新configsvr信息。 var vs = db.getSiblingDB('admin').system.version.find();
      while (vs.hasNext()) {
      var curr = vs.next();
      if (curr.hasOwnProperty('configsvrConnectionString')) {
      db.getSiblingDB('admin').system.version.update({'_id' : curr._id}, {$set: {'configsvrConnectionString': 'config/127.0.0.1:40303,127.0.0.1:40304,127.0.0.1:40305'}});
   4. 执行如下命令，关闭单节点进程。 db.getSiblingDB('admin').shutdownServer();
3. 搭建shardsvr2副本集。
   1. 准备副本集配置文件和目录，将shardsvr2节点的dbPath文件拷贝到其他两个节点目录下。 cp -aR /compile/cluster-restore/shd21/data/db/ /compile/cluster-restore/shd22/data/db/
      cp -aR /compile/cluster-restore/shd21/data/db/ /compile/cluster-restore/shd23/data/db/
   2. 修改shardsvr2-1节点配置文件，增加副本集配置属性（restoreconfig/shardsvr_40309.yaml）。 --- replication.replSetName 的值，参考[该章节](https://support.huaweicloud.com/usermanual-dds/dds_03_0082.html#dds_03_0082__li10561816431)中的shard的_id信息。
      net:
        bindIp: 127.0.0.1
        port: 40309
      replication: {replSetName: shard_2}
      sharding: {archiveMovedChunks: false, clusterRole: shardsvr}
      storage:
        engine: wiredTiger
        wiredTiger:
   3. 启动进程。 ./mongod -f restoreconfig/shardsvr_40309.yaml
   4. 修改shardsvr2-2节点配置文件，增加副本集配置属性（restoreconfig/shardsvr_40310.yaml）。 --- replication.replSetName 的值，参考[该章节](https://support.huaweicloud.com/usermanual-dds/dds_03_0082.html#dds_03_0082__li10561816431)中的shard的_id信息。
      net:
        bindIp: 127.0.0.1
        port: 40310
      processManagement: {fork: true, pidFilePath: /compile/cluster-restore/shd22/mongod.pid}
      storage:
        dbPath: /compile/cluster-restore/shd22/data/db/
        engine: wiredTiger
        wiredTiger:
      systemLog: {destination: file, logAppend: true, logRotate: reopen, path: /compile/cluster-restore/shd22/log/mongod.log}
   5. 启动进程。 ./mongod -f restoreconfig/shardsvr_40310.yaml
   6. 修改shardsvr2-3节点配置文件，增加副本集配置属性（restoreconfig/shardsvr_40311.yaml）。 --- replication.replSetName 的值，参考[该章节](https://support.huaweicloud.com/usermanual-dds/dds_03_0082.html#dds_03_0082__li10561816431)中的shard的_id信息。
      net:
        bindIp: 127.0.0.1
        port: 40311
      processManagement: {fork: true, pidFilePath: /compile/cluster-restore/shd23/mongod.pid}
      storage:
        dbPath: /compile/cluster-restore/shd23/data/db/
        engine: wiredTiger
        wiredTiger:
      systemLog: {destination: file, logAppend: true, logRotate: reopen, path: /compile/cluster-restore/shd23/log/mongod.log}
   7. 启动进程。 ./mongod -f restoreconfig/shardsvr_40311.yaml
4. 等待选主成功。
   执行命令rs.status()，查看是否已存在主节点Primary。
