# 支持与限制的命令
用户在连接到社区版文档数据库后，需要关注以下支持以及限制的命令。
更多信息，请参见[MongoDB官方文档](https://docs.mongodb.com/master/reference/command/?spm=a2c4g.11186623.2.7.652c53daMEfJMP)。
![](https://support.huaweicloud.com/usermanual-dds/public_sys-resources/note_3.0-zh-cn.png)
如下表所示，"√"表示当前版本支持该命令，"×"表示当前版本不支持该命令。
表1支持与限制的命令
| 命令类别                               | 命令名称                           | 3.4 | 4.0 | 4.2 | 备注        |
| Aggregates Commands                | aggregate                      | √   | √   | √   | -        |
| Aggregates Commands                | count                          | √   | √   | √   | -        |
| Aggregates Commands                | distinct                       | √   | √   | √   | -        |
| Aggregates Commands                | group                          | √   | √   | √   | -        |
| Aggregates Commands                | mapReduce                      | √   | √   | √   | 在DDS实例关联参数模板中设置参数"security.javascriptEnabled"的值为"true"后，可以使用该命令。更多信息，请参见[如何使用MapReduce命令](https://support.huaweicloud.com/dds_faq/dds_faq_0099.html)。 |
| Geospatial Commands                | geoNear                        | √   | √   | √   | -        |
| Geospatial Commands                | geoSearch                      | √   | √   | √   | -        |
| Query and Write Operation Commands | find                           | √   | √   | √   | -        |
| Query and Write Operation Commands | insert                         | √   | √   | √   | -        |
| Query and Write Operation Commands | update                         | √   | √   | √   | -        |
| Query and Write Operation Commands | delete                         | √   | √   | √   | -        |
| Query and Write Operation Commands | findAndModify                  | √   | √   | √   | -        |
| Query and Write Operation Commands | getMore                        | √   | √   | √   | -        |
| Query and Write Operation Commands | getLastError                   | √   | √   | √   | -        |
| Query and Write Operation Commands | resetError                     | √   | √   | √   | -        |
| Query and Write Operation Commands | getPrevError                   | √   | √   | √   | -        |
| Query and Write Operation Commands | parallelCollectionScan         | √   | √   | √   | -        |
| Query Plan Cache Commands          | planCacheListFilters           | √   | √   | √   | -        |
| Query Plan Cache Commands          | planCacheSetFilter             | √   | √   | √   | -        |
| Query Plan Cache Commands          | planCacheClearFilters          | √   | √   | √   | -        |
| Query Plan Cache Commands          | planCacheListQueryShapes       | √   | √   | √   | -        |
| Query Plan Cache Commands          | planCacheListPlans             | √   | √   | √   | -        |
| Query Plan Cache Commands          | planCacheClear                 | √   | √   | √   | -        |
| Authentication Commands            | logout                         | √   | √   | √   | -        |
| Authentication Commands            | authenticate                   | √   | √   | √   | -        |
| Authentication Commands            | copydbgetnonce                 | √   | √   | √   | -        |
| Authentication Commands            | getnonce                       | √   | √   | √   | -        |
| Authentication Commands            | authSchemaUpgrade              | x   | x   | x   | 系统内部命令。        |
| User Management Commands           | createUser                     | √   | √   | √   | -        |
| User Management Commands           | updateUser                     | √   | √   | √   | -        |
| User Management Commands           | dropUser                       | √   | √   | √   | -        |
| User Management Commands           | dropAllUsersFromDatabase       | √   | √   | √   | -        |
| User Management Commands           | grantRolesToUser               | √   | √   | √   | -        |
| User Management Commands           | revokeRolesFromUser            | √   | √   | √   | -        |
| User Management Commands           | usersInfo                      | √   | √   | √   | -        |
| Role Management Commands           | invalidateUserCache            | √   | √   | √   | -        |
| Role Management Commands           | createRole                     | √   | √   | √   | -        |
| Role Management Commands           | updateRole                     | √   | √   | √   | -        |
| Role Management Commands           | dropRole                       | √   | √   | √   | -        |
| Role Management Commands           | dropAllRolesFromDatabase       | √   | √   | √   | -        |
| Role Management Commands           | grantPrivilegesToRole          | √   | √   | √   | -        |
| Role Management Commands           | revokePrivilegesFromRole       | √   | √   | √   | -        |
| Role Management Commands           | grantRolesToRole               | √   | √   | √   | -        |
| Role Management Commands           | revokeRolesFromRole            | √   | √   | √   | -        |
| Role Management Commands           | rolesInfo                      | √   | √   | √   | -        |
| Replication Commands               | replSetElect                   | x   | x   | x   | 系统内部命令。        |
| Replication Commands               | replSetUpdatePosition          | x   | x   | x   | 系统内部命令。        |
| Replication Commands               | appendOplogNote                | x   | x   | x   | 系统内部命令。        |
| Replication Commands               | replSetFreeze                  | x   | x   | x   | 系统内部命令。        |
| Replication Commands               | replSetGetStatus               | √   | √   | √   | -        |
| Replication Commands               | replSetInitiate                | x   | x   | x   | 系统内部命令。        |
| Replication Commands               | replSetMaintenance             | x   | x   | x   | 系统内部命令。        |
| Replication Commands               | replSetReconfig                | x   | x   | x   | 系统内部命令。        |
| Replication Commands               | replSetStepDown                | x   | x   | x   | 系统内部命令。        |
| Replication Commands               | replSetSyncFrom                | x   | x   | x   | 系统内部命令。        |
| Replication Commands               | replSetRequestVotes            | x   | x   | x   | 系统内部命令。        |
| Replication Commands               | replSetDeclareElectionWinner   | x   | x   | x   | 系统内部命令。        |
| Replication Commands               | resync                         | x   | x   | x   | 系统内部命令。        |
| Replication Commands               | applyOps                       | x   | x   | x   | 系统内部命令。        |
| Replication Commands               | isMaster                       | √   | √   | √   | -        |
| Replication Commands               | replSetGetConfig               | x   | x   | x   | 系统内部命令。        |
| Sharding Commands                  | flushRouterConfig              | √   | √   | √   | 高危命令。        |
| Sharding Commands                  | addShard                       | x   | x   | x   | 越权操作。        |
| Sharding Commands                  | addShardToZone                 | √   | √   | √   | -        |
| Sharding Commands                  | balancerStart                  | √   | √   | √   | -        |
| Sharding Commands                  | balancerStatus                 | √   | √   | √   | -        |
| Sharding Commands                  | balancerStop                   | √   | √   | √   | -        |
| Sharding Commands                  | removeShardFromZone            | √   | √   | √   | -        |
| Sharding Commands                  | updateZoneKeyRange             | √   | √   | √   | -        |
| Sharding Commands                  | cleanupOrphaned                | x   | x   | x   | 高危命令。        |
| Sharding Commands                  | checkShardingIndex             | x   | x   | x   | 系统内部命令。        |
| Sharding Commands                  | enableSharding                 | √   | √   | √   | -        |
| Sharding Commands                  | listShards                     | x   | x   | x   | 系统内部命令。        |
| Sharding Commands                  | removeShard                    | x   | x   | x   | 高危命令。        |
| Sharding Commands                  | getShardMap                    | x   | x   | x   | 系统内部命令。        |
| Sharding Commands                  | getShardVersion                | √   | √   | √   | -        |
| Sharding Commands                  | mergeChunks                    | √   | √   | √   | -        |
| Sharding Commands                  | setShardVersion                | x   | x   | x   | 系统内部命令。        |
| Sharding Commands                  | shardCollection                | √   | √   | √   | -        |
| Sharding Commands                  | shardingState                  | x   | x   | x   | 系统内部命令。        |
| Sharding Commands                  | unsetSharding                  | x   | x   | x   | 系统内部命令。        |
| Sharding Commands                  | split                          | √   | √   | √   | -        |
| Sharding Commands                  | splitChunk                     | √   | √   | √   | -        |
| Sharding Commands                  | splitVector                    | √   | √   | √   | -        |
| Sharding Commands                  | moveChunk                      | √   | √   | √   | -        |
| Sharding Commands                  | movePrimary                    | √   | √   | √   | -        |
| Sharding Commands                  | isdbgrid                       | √   | √   | √   | -        |
| Administration Commands            | setFeatureCompatibilityVersion | √   | √   | √   | -        |
| Administration Commands            | renameCollection               | √   | √   | √   | -        |
| Administration Commands            | dropDatabase                   | √   | √   | √   | -        |
| Administration Commands            | listCollections                | √   | √   | √   | -        |
| Administration Commands            | drop                           | √   | √   | √   | -        |
| Administration Commands            | create                         | √   | √   | √   | -        |
| Administration Commands            | clone                          | x   | x   | x   | 系统内部命令。        |
| Administration Commands            | cloneCollection                | √   | √   | √   | -        |
| Administration Commands            | cloneCollectionAsCapped        | √   | √   | √   | -        |
| Administration Commands            | convertToCapped                | √   | √   | √   | -        |
| Administration Commands            | filemd5                        | √   | √   | √   | -        |
| Administration Commands            | createIndexes                  | √   | √   | √   | -        |
| Administration Commands            | listIndexes                    | √   | √   | √   | -        |
| Administration Commands            | dropIndexes                    | √   | √   | √   | -        |
| Administration Commands            | fsync                          | √   | √   | √   | -        |
| Administration Commands            | clean                          | x   | x   | x   | 系统内部命令。        |
| Administration Commands            | connPoolSync                   | x   | x   | x   | 系统内部命令。        |
| Administration Commands            | connectionStatus               | √   | √   | √   | -        |
| Administration Commands            | compact                        | x   | x   | x   | 高危命令。        |
| Administration Commands            | collMod                        | √   | √   | √   | -        |
| Administration Commands            | reIndex                        | √   | √   | √   | -        |
| Administration Commands            | setParameter                   | x   | x   | x   | 系统配置命令。        |
| Administration Commands            | getParameter                   | √   | √   | √   | -        |
| Administration Commands            | repairDatabase                 | x   | x   | x   | 高危命令。        |
| Administration Commands            | repairCursor                   | x   | x   | x   | 系统内部命令。        |
| Administration Commands            | touch                          | √   | √   | √   | -        |
| Administration Commands            | shutdown                       | x   | x   | x   | 高危命令。        |
| Administration Commands            | logRotate                      | x   | x   | x   | 高危命令。        |
| Administration Commands            | killOp                         | √   | √   | √   | -        |
| Administration Commands            | releaseFreeMemory              | √   | √   | √   | -        |
| Diagnostic Commands                | availableQueryOptions          | √   | √   | √   | -        |
| Diagnostic Commands                | buildInfo                      | √   | √   | √   | -        |
| Diagnostic Commands                | collStats                      | √   | √   | √   | -        |
| Diagnostic Commands                | connPoolStats                  | x   | x   | x   | 系统内部命令。        |
| Diagnostic Commands                | cursorInfo                     | x   | x   | x   | 系统内部命令。        |
| Diagnostic Commands                | dataSize                       | √   | √   | √   | -        |
| Diagnostic Commands                | dbHash                         | x   | x   | x   | 系统内部命令。        |
| Diagnostic Commands                | dbStats                        | √   | √   | √   | -        |
| Diagnostic Commands                | diagLogging                    | x   | x   | x   | 系统内部命令。        |
| Diagnostic Commands                | driverOIDTest                  | x   | x   | x   | 系统内部命令。        |
| Diagnostic Commands                | explain                        | √   | √   | √   | -        |
| Diagnostic Commands                | features                       | √   | √   | √   | -        |
| Diagnostic Commands                | getCmdLineOpts                 | x   | x   | x   | 系统内部命令。        |
| Diagnostic Commands                | getLog                         | x   | x   | x   | 系统内部命令。        |
| Diagnostic Commands                | hostInfo                       | x   | x   | x   | 系统内部命令。        |
| Diagnostic Commands                | isSelf                         | x   | x   | x   | 系统内部命令。        |
| Diagnostic Commands                | listCommands                   | √   | √   | √   | -        |
| Diagnostic Commands                | listDatabases                  | √   | √   | √   | -        |
| Diagnostic Commands                | netstat                        | x   | x   | x   | 系统内部命令。        |
| Diagnostic Commands                | ping                           | √   | √   | √   | -        |
| Diagnostic Commands                | profile                        | √   | √   | √   | -        |
| Diagnostic Commands                | serverStatus                   | √   | √   | √   | -        |
| Diagnostic Commands                | shardConnPoolStats             | x   | x   | x   | 系统内部命令。        |
| Diagnostic Commands                | top                            | √   | √   | √   | -        |
| Diagnostic Commands                | validate                       | x   | x   | x   | 系统配置命令。        |
| Diagnostic Commands                | whatsmyuri                     | √   | √   | √   | -        |
| Internal Commands                  | handshake                      | x   | x   | x   | 系统内部命令。        |
| Internal Commands                  | _recvChunkAbort                | x   | x   | x   | 系统内部命令。        |
| Internal Commands                  | _recvChunkCommit               | x   | x   | x   | 系统内部命令。        |
| Internal Commands                  | _recvChunkStart                | x   | x   | x   | 系统内部命令。        |
| Internal Commands                  | _recvChunkStatus               | x   | x   | x   | 系统内部命令。        |
| Internal Commands                  | _replSetFresh                  | x   | x   | x   | 系统内部命令。        |
| Internal Commands                  | mapreduce.shardedfinish        | x   | x   | x   | 系统内部命令。        |
| Internal Commands                  | _transferMods                  | x   | x   | x   | 系统内部命令。        |
| Internal Commands                  | replSetHeartbeat               | x   | x   | x   | 系统内部命令。        |
| Internal Commands                  | replSetGetRBID                 | x   | x   | x   | 系统内部命令。        |
| Internal Commands                  | _migrateClone                  | x   | x   | x   | 系统内部命令。        |
| Internal Commands                  | replSetElect                   | x   | x   | x   | 系统内部命令。        |
| Internal Commands                  | writeBacksQueued               | x   | x   | x   | 系统内部命令。        |
| Internal Commands                  | writebacklisten                | x   | x   | x   | 系统内部命令。        |
| System Events Auditing Commands    | logApplicationMessage          | x   | x   | x   | 系统内部命令。        |
