# SELECT Subquery Syntax
#### The Subquery as Scalar Operand
示例
SELECT (SELECT id FROM test1 where id=1);
SELECT (SELECT id FROM test2 where id=1)FROM test1;
SELECT UPPER((SELECT name FROM test1 limit 1)) FROM test2;
#### Comparisons Using Subqueries
语法
non_subquery_operand comparison_operator (subquery)
comparison_operator ：= > < >= <= <> != <=> like
示例
select name from test1 where id > (select id from test2 where id=1);
select name from test1 where id = (select id from test2 where id=1);
select id from test1 where name like (select name from test2 where id=1);
#### Subqueries with ANY, IN, NOT IN, SOME,ALL,Exists,NOT Exists
语法
operand comparison_operator SOME (subquery)
operand comparison_operator ALL (subquery)
operand comparison_operator ANY (subquery)
operand IN (subquery)
operand not IN (subquery)
operand exists (subquery)
operand not exists (subquery)
示例
select id from test1 where id > any (select id from test2);
select id from test1 where id > some (select id from test2);
select id from test1 where id > all (select id from test2);
select id from test1 where id in (select id from test2);
select id from test1 where id not in (select id from test2);
select id from test1 where exists (select id from test2 where id=1);
select id from test1 where not exists (select id from test2 where id=1);
#### Derived Tables (Subqueries in the FROM Clause)
语法
SELECT ... FROM (subquery) [AS] tbl_name ...
示例
select id from (select id,name from test2 where id>1) a  order by a.id;
#### 语法限制
- Derived Tables 必须拥有一个别名。
- Derived Tables 不可以成为 Correlated Subqueries，即不能包含子查询外部表的引用。
- 标量子查询在一些场景下当前不能得到正确结果，建议改写为join，同时可提高性能。
- 不支持 HAVING 子句中的子查询，JOIN ON 条件中的子查询。
- 不支持Row Subqueries。
